dean.psiropoulos(at)veriz Guest
Posted: Thu Jun 08, 2006 9:34 pm Post subject: Power and audio input jacks |
I'm taking a poll:
What it the most popular power jack used in portable electronics today? I
am planning on putting two power outlets in, one is the cigarette lighter
plug. I thought I'd use one of the smaller common power jacks for a second
source as well. Good idea or should I just put in another cigarette lighter
plug?
Audio input jacks for my stereo audio panel...again what is the most popular
style of stereo plug used in portable electronics today? I'm guessing it's
the mini plug like that used on computer speakers but not sure.
Dean Psiropoulos
RV-6A N197DM
Still a few holes needed in panel.
gholland(at)gemini-resour Guest
Posted: Thu Jun 08, 2006 10:06 pm Post subject: Power and audio input jacks |
Dean Hi! From UK
I have standard Cigarette Lighter type 12V Auxiliary. May put another in or
with care use dual input adapter occasionally. The people I know who have
fitted the very neat 12V socket have always had to make up an adapter to the
12V auxiliary type! I've limited my in-line fuse to 3 Amps.
For audio into Intercom I using the mini plug and socket. Works really well
into my PS 500.
Gerry
G-FIZY
Posted: Thu Jun 08, 2006 10:55 pm Post subject: Power and audio input jacks |
| Quote: | > What it the most popular power jack used in portable electronics today?
I worried about the same problem as I designed my panel. The funny thing
about the small DC coaxial power jacks (like Radio Shack's 274-1563) is that
they are designed for the device receiving the power, not sourcing it. There
is the center post, a gap and the surrounding metal ring. There is not much
to prevent a stray piece of metal bridging the two contacts. What you want
is something like a panel-mounted version of the plugs at the end of the
cords on your typical AC adapter/brick. But then you would still need a cord
to go from the panel to the accessory. And there are a lot of different
outside and inside diameters: 3.5/1.1mm, 5mm/2.1mm, 5/2.5mm, 5.5/2.1mm,
5.5/2.5mm, etc.
The biggest problem with the cigarette lighter outlet is their size. So you
could consider placing a smaller connector on the panel whose plug would run
off to an in-line (cord-mounted) lighter outlet. But some of the things that
plug into a lighter outlet are relatively heavy. So the panel connector you
choose had better be fairly robust and lock the plug in - something like a
female version of Radio Shack's 274-002 (if it existed).
In the end I bit the bullet and just found room for two lighter outlets. If
you want a pair of very high quality, locking lighter outlet and plugs take
a look at the SEALINK 12VRC and 12VPG:
http://www.marinco.com/docs/specs/12VRC.pdf
The whole product line is at http://tinyurl.com/pcxl4
You can buy these at Del City (www.delcity.net) as PN 73540 and 73542:
http://www.delcity.net/delcity/servlet/catalog?parentid=789160&page=1
(tiny URL http://tinyurl.com/mdfxc)
Or just Google on "sealink 12vrc"
-- Craig
rv8ch
DEAN PSIROPOULOS wrote:
| Quote: | What it the most popular power jack used in portable electronics today? I
plug?
I'm not sure about popularity, but I'm installing some of
these in my RV8:
http://www.powerletproducts.com/
They seem to be used on millions of motorcycles, and
are of much higher quality than the cigar lighter type.
The powerlet products people are also very good folks.
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
8.3 KB |
8035 Time(s) |
_________________ Mickey Coggins
http://www.rv8.ch/ |
bferrell(at)123mail.net Guest
Posted: Fri Jun 09, 2006 2:34 am Post subject: Power and audio input jacks |
Where'd you find a bulkhead-style plug? I"m having trouble locating one.
Brett
brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Fri Jun 09, 2006 4:04 am Post subject: Power and audio input jacks |
On Jun 9, 2006, at 12:26 AM, DEAN PSIROPOULOS wrote:
<dean.psiropoulos(at)verizon.net>
I'm taking a poll:
today?
The most popular and generally available is the cigarette lighter
plug but it is big and bulky, a real waste of real estate. But if you
go away from that you are no longer standard.
But if that doesn't concern you then you can pick and choose. In the
ham radio world there are some ideas. Take a look at the power
distribution stuff from West Mountain Radio. Very nicely done for
being able to plug and unplug 12VDC devices. They fit well with Bob's
view of power distribution. They even have a neat little module for
cycle testing batteries for capacity.
Brian Lloyd 361 Catterline Way
brian-yak AT lloyd DOT com Folsom, CA 95630
— Antoine de Saint-Exupéry
_________________ Brian Lloyd
brian-yak at lloyd dot com
- Antoine de Saint-Exupery |
nuckollsr(at)cox.net Guest
Posted: Fri Jun 09, 2006 4:14 am Post subject: Power and audio input jacks |
Consider these parts also available from Radio Shack . . .
http://www.aeroelectric.com/Pictures/Connectors/274-010.jpg
http://www.aeroelectric.com/Pictures/Connectors/274-013.jpg
and
http://www.aeroelectric.com/Pictures/Connectors/hh_pwr.jpg
At 12:48 AM 6/9/2006 -0600, you wrote:
<craig(at)craigandjean.com>
5.5/2.5mm, etc.
-- Craig
-- incoming mail is certified Virus Free.
Checked by AVG Anti-Virus.
< What is so wonderful about scientific truth...is that >
< the authority which determines whether there can be >
< debate or not does not reside in some fraternity of >
< scientists; nor is it divine. The authority rests >
< with experiment. >
< --Lawrence M. Krauss >
harley(at)agelesswings.co Guest
Posted: Fri Jun 09, 2006 4:35 am Post subject: Power and audio input jacks |
A little further research on their site shows they also have right angle plugs...another good idea!
[img]cid:part1.05000604.08090402(at)agelesswings.com[/img]
And if you ABSOLUTELY want to have a device usable in both types of sockets, there is a plug that fits both the cigarette lighter and theirs for $15:
[img]cid:part2.08040506.03060400(at)agelesswings.com[/img]
Looks like they can supply a means to hook up or adapt anything you want. Good site!
(And, no.,..I don't have an association with them...just like the ideas!)
Harley
Harley wrote: | Quote: | Thanks, for the link, Mickey...
Now that's what I'm talking about! Not quite like the RX-8s, but I like 'em! I knew there had to be something out there I liked.
They are smaller than the traditional cigarette socket/plug (which is a good thing for our aircraft, no?), but they also have adapters so you can plug your cigarette lighter plug accessories into their power plugs and not have to wire one of their plugs onto the accessory and then not be able to use it elsewhere!
Looks like they are my choice.
Go to this page and click on the items in the picture to see all the possible hookups and combinations.
www.powerletproducts.com/products/ptb.php
Again, nice find, Mickey...These guys think the way I do!
Harley Dixon
8.11 KB |
8031 Time(s) |
9.09 KB |
388 Time(s) |
jschroeder(at)perigee.net Guest
Posted: Fri Jun 09, 2006 5:10 am Post subject: Power and audio input jacks |
Dean -
Based on a whole bunch of wall-warts, cables, and power supplies I have
around here - and after wiring our airplane, I would recommend using the
"cigar lighter" type for your power jacks. All cars have them and most
electronics that have DC sources and made for cars use this type. You can
always get them. I know, they look like hell and are too big, but until
the auto/electronics industry start producing another kind, I'd stick with
those. There is a standard being used on most new airliners these days but
the jacks and plugs are harder to find. Again, when the electronics
industry starts producing the plugs and/or adaptors in quantity ... .
On Fri, 09 Jun 2006 01:26:20 -0400, DEAN PSIROPOULOS
<dean.psiropoulos(at)verizon.net> wrote:
I'm taking a poll:
I
second
lighter
plug?
popular
it's
Dean Psiropoulos
RV-6A N197DM
pwmac(at)sisna.com Guest
Posted: Fri Jun 09, 2006 7:01 am Post subject: Power and audio input jacks |
Be aware that the auto store cig lighter receptacles come in various
non standard sizes. Expect to buy several brands to fit your gadget
securely. The bad ones are oversized so small vibrations cause the
thing to become disconnected. Some gadgets came with a plastic sleeve
to allow fit for an oversized receptacle you might buy. The sometimes
work, but not always. Sometimes just buying a new end for your gadget
will allow a better fit. Lots of pitfalls using these things.
Regards, Paul
At 07:05 AM 6/9/2006, you wrote:
<jschroeder(at)perigee.net>
Dean -
>I'm taking a poll:
>I
>second
>lighter
>plug?
>popular
>it's
>Dean Psiropoulos
>RV-6A N197DM
robh(at)hyperion-ef.us Guest
Posted: Fri Jun 09, 2006 1:22 pm Post subject: Power and audio input jacks |
The correct (searchable) ACS part number is 11-01294
Best regards,
Rob Housman
A070
Airframe complete
Irvine, CA
Posted: Sat Jun 10, 2006 4:23 am Post subject: Power and audio input jacks |
Thanks, but I was really looking for the audio jacks, for MP3 input in,
and/or cell-phone interfaces to my PMA8000. Thanks.
Brett
rv8ch
Posted: Sat Jun 10, 2006 3:29 pm Post subject: Power and audio input jacks |
| Quote: | They are smaller than the traditional cigarette socket/plug (which is a
They also have these that are all aluminum for $30:
I originally bought the "military style" (PSO-003) connectors,
but I ended up sending them back. I think they would be fine
on something like a dune buggy or snowmobile or sand rail,
but are severe overkill for the inside of a cockpit. The
screws tops are hard to get off and on, and the chain
tends to bunch up when you spin the cap.
I sent them back to Powerlet, and they gave me full credit,
and shipped the other model with the flip caps (PSO-001) to
me in Switzerland at their expense. That's what I meant when
I said they were good people to deal with!
These connectors are small, and there are *tons* of accessories
that use this type of connector in the motorcycle world. They
have a lot of the same types of requirements we do. As you
mentioned, there are adapters to the cigar lighter connector,
and a lot of other connectors.
http://www.powerletproducts.com/products/cables.php
I bought a cigar lighter adapter, and one for the SAE type
cable, which works perfectly with the battery tender.
BTW, I think I learned about these on either this list or
one of the other fine lists I try to read regularly.
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
icubob(at)newnorth.net Guest
Posted: Sun Jun 11, 2006 3:48 am Post subject: Power and audio input jacks |
hi all, here is another twist to the plug thread. i have a program that
slaves my palm pilot to a cheap handheld gps. it turns the palm into a hsi
and has a 15000 point database. the program was $30. amyway, although there
are a lot of wiring harnesses out there that connect the gps to the palm and
to external power [cig lighter] i have only found one harness that supplies
power to both the palm and the gps. the others supply only the gps. the
''good one'' i found is $90!!. the others are $20. has anyone found a
harness that powers both the gps and the palm and is not made of GOLD?
bob noffs
