peterthomson
Posted: Sat Sep 08, 2012 4:57 am Post subject: Electrical problem with 912ULS |
A friend's engine has abt 300 hrs.
There is no spark at the plugs.
The AC voltage into the ignition modules is abt 9v.
The DC output from the modules to the coils seems to be about 2v.
Can anyone assist with past experience on this?
thanks
Peter
CH701
912ULS 850hrs (no problems) [quote][b]
Roger Lee
Posted: Sat Sep 08, 2012 7:00 am Post subject: Re: Electrical problem with 912ULS |
Hi Peter,
Will the engine start at all?
Because of our dual ignition system it would be rare that all this would go out at one time. it is usually a broken wire.
The spark is so hard to see on a 912 it is best looked at in a darkened atmosphere. The voltage into the regulator with the two yellow wires should be between 18-22 volts AC. If you can't get the engine started or at least up to 240rpm then that would be hard to measure.
 Download |
| Filename: |
ROAN_Generator troubleshooting.pdf |
27.99 KB |
| Downloaded: |
441 Time(s) |
 Download |
| Filename: |
How to diagnos an ignition problem.docx |
15.64 KB |
| Downloaded: |
469 Time(s) |
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
rickofudall
Posted: Sun Sep 09, 2012 11:39 am Post subject: Electrical problem with 912ULS |
Peter, Roger et al, One of the many things impressed upon me at Rotax school was that one should never, ever attempt to try and see the spark by grounding a plug and cranking the engine. Unless you have an extra grand lying around for a new ignition module. First, as Roger noted, it's almost impossible to see. Second, a $10 tool, an Ignition Spark Tester replaces the weak spark with a bright light that makes the test safe and easy to do.
Ignition Spark Testers are available from sources as varied as Harbor Freight and Snap On.
Rick Girard
On Sat, Sep 8, 2012 at 10:00 AM, Roger Lee <ssadiver1(at)yahoo.com (ssadiver1(at)yahoo.com)> wrote:
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
Roger Lee
Posted: Sun Sep 09, 2012 12:58 pm Post subject: Re: Electrical problem with 912ULS |
I fully agree. If it is done wrong you can cause damage. I never look for spark and have such a tool to check wire/plug continuity.
Tucson, Az.
Cell 520-349-7056 |
