sean(at)stephensville.com Guest
Posted: Mon Apr 09, 2012 4:50 pm Post subject: Door Gutter and McMaster Seals |
I've read Les' document on using McMaster Carr door seals. He trimmed
off the entire radius on the door gutter. I ordered the same 1/4 inch
with 3/8 inch bulb seals he used.
I have yet to trim off the full radius as he did, but it seems that if I
do, there will me no way the 3/8 inch bulb will be enough to actually
touch and seal against the door. Seems the gap between the gutter and
the door would be too large.
His doc showed the older green canopy instead of the pink. Is there a
difference there? Did others using the McMaster seals trim off the full
radius on the gutter and have it work with the 3/8 inch bulb?
-Sean #40303 (very dim light at the end of the tunnel)
kearney
Posted: Mon Apr 09, 2012 5:18 pm Post subject: Door Gutter and McMaster Seals |
Hi Sean
There is a very big difference - I believe it is the colour.
Cheers
Les
Ps. I was told by someone who knows that there really isn't any difference.
On 2012-04-09, at 6:48 PM, Sean Stephens <sean(at)stephensville.com> wrote:
I've read Les' document on using McMaster Carr door seals. He trimmed off the entire radius on the door gutter. I ordered the same 1/4 inch with 3/8 inch bulb seals he used.
I have yet to trim off the full radius as he did, but it seems that if I do, there will me no way the 3/8 inch bulb will be enough to actually touch and seal against the door. Seems the gap between the gutter and the door would be too large.
His doc showed the older green canopy instead of the pink. Is there a difference there? Did others using the McMaster seals trim off the full radius on the gutter and have it work with the 3/8 inch bulb?
bill.peyton
Posted: Mon Apr 09, 2012 6:01 pm Post subject: Re: Door Gutter and McMaster Seals |
Sean,
Part of installing the seal is to build up the area on both sides of the old gutter rail. Once you cut it flat it needs to be extended out and thickened both on the inside and the out. Ultimately, the seal will be about 50% compressed when you are complete. Here is how my seal fits.
2.14 MB |
16299 Time(s) |
_________________ Bill
WA0SYV
Aviation Partners, LLC |
rleffler
Posted: Mon Apr 09, 2012 6:18 pm Post subject: Door Gutter and McMaster Seals |
There are differences, but they arent significant. The pink tops are slightly better finished. Only important if you aren't using a headliner.
There appears to be two different pink top molds, as well as the green mold, that have the step up behind the front seat line in different places. it makes delivering an after market overhead more difficult.
I'm not aware of any differences around the door gutter.
On Apr 9, 2012, at 9:17 PM, Les Kearney <kearney(at)shaw.ca> wrote:
Hi Sean
Cheers
Les
> Thanks,
_________________ Bob Leffler
N410BL - Phase I
rleffler
Posted: Mon Apr 09, 2012 6:27 pm Post subject: Door Gutter and McMaster Seals |
Be careful on ordering the trim. If I remember Les's doc, the picture showed a version of the seal with the barb on the exterior. You'll want the version that has the barb on the inside of the door frame. You don't want the barb to add thickness to the seal into between the free and the door.
Go to Ivan Kristense's phanfare.com photo site. In the middle o f his door photos, there is a video showing in detail how to trim the door gutter.
I cut off the full radius and my doors are very tight fitting with the seals on. I have a pink top.
On Apr 9, 2012, at 8:48 PM, Sean Stephens <sean(at)stephensville.com> wrote:
N410BL - Phase I
kearney
Posted: Mon Apr 09, 2012 8:01 pm Post subject: Door Gutter and McMaster Seals |
Hi Again
Bob is right about my seals. That being said, I did make mine work. I am not sure if the barb orientation makes a significant difference but would probably go with the inside barb if I was doing things again.
Cheers
Les
Cheers
Les
On 2012-04-09, at 8:27 PM, Bob Leffler <rv(at)thelefflers.com> wrote:
> Thanks,
Posted: Mon Apr 09, 2012 8:16 pm Post subject: Door Gutter and McMaster Seals |
Ivan's pictures were a big help. After looking at them and the video it
seems like the following rough steps can be taken.
- Once the doors are trimmed to fit, mark the interior edge of the
gutter for a consistent gap (less than 3/8 for the bulb)
- Sand down the radius to marks on interior edge of gutter and trim/sand
gutter width to dimensions at various locations given by Ivan
- Fill/sand to achieve necessary gutter thickness of 1/4 inch for
attaching seal
Thanks for pointing me to Ivan's pictures.
-Sean
On 4/9/12 9:27 PM, Bob Leffler wrote:
> Thanks,
Posted: Mon Apr 09, 2012 11:12 pm Post subject: Door Gutter and McMaster Seals |
We were the first to use the McM seal. We started a grinder and added a spacer for even reveal. Seemed to work out well on the old top.
Robin
367.07 KB |
16266 Time(s) |
443.72 KB |
16266 Time(s) |
27.74 KB |
16266 Time(s) |
mauledriver(at)nc.rr.com Guest
Posted: Tue Apr 10, 2012 3:06 am Post subject: Door Gutter and McMaster Seals |
That all sounds about right. Getting the barb on the right side helps.
Two other things:
If you plan any sort of fabric covering for the door, you have to account for that in the bulb gap. Flightline's interior would be an example
Don't trim for final length until you are absolutely finished with the gap work. Any gap work increases the length of seal. You can patch it, or better yet just buy the full 50/100 foot length so you can do it 2 or 3 times, then sell extra to a friend. DAHIK
On Apr 10, 2012, at 12:15 AM, Sean Stephens <sean(at)stephensville.com> wrote:
Ivan's pictures were a big help. After looking at them and the video it seems like the following rough steps can be taken.
- Once the doors are trimmed to fit, mark the interior edge of the gutter for a consistent gap (less than 3/8 for the bulb)
- Sand down the radius to marks on interior edge of gutter and trim/sand gutter width to dimensions at various locations given by Ivan
- Fill/sand to achieve necessary gutter thickness of 1/4 inch for attaching seal
-Sean
> Sent from my iPad
>> Thanks,
rnewman(at)tcwtech.com Guest
Posted: Tue Apr 10, 2012 3:36 am Post subject: Door Gutter and McMaster Seals |
I used the McMaster seals as well, but did the following:
After grinding the gutter lip down, I took a scrap piece of door seal about
3 foot long and filled it (about 50% full) with epoxy/structural filler mix
and applied it to the door frame. When cured I had the perfect mating
detail for the door seal as part of the cabin top. Step and repeat
around the door frame opening then discard the scrap seal and use new seal
for the final installation.
The following album has the details, seal pictures start about 1/3 of
the way into the album.
https://picasaweb.google.com/aviator1964/DoorsLatchesSeals?authuser=0&feat=directlink
Bob Newman
N541RV flying
jkreidler
Joined: 13 Feb 2008 Posts: 151 Location: Sheboygan Falls WI
Posted: Tue Apr 10, 2012 4:35 am Post subject: Re: Door Gutter and McMaster Seals |
We each build our own airplanes and make our own decisions β please donβt take this as criticism just food for thought. I had a conversation with Ken K. regarding drilling holes in the gutter in order to add sun visors the cabin top, specifically the cabin top posts. Ken indicated that one of the challenges in the design was getting the cabin top to pass the inverted drop test. He was visibly uncomfortable with the idea of drilling any holes in the gutter to mount visors, for those who have had conversations with Ken K. in person you may know the wince he gives.
By removing the entire inside radius of the gutter in order to install the McMaster Carr style seal you are significantly changing the section modulus of the cabin top post and COULD be significantly increasing the likelihood of a cabin top failure in a roll over type accident. Just something to consider as you make what may seem to be a harmless improvement to the design.
Again, these are your decisions β I am only trying to provide an alternate perspective to the decision.
Thanks β Jason
_________________ Jason Kreidler
4 Partner Build - Sheboygan Falls, WI
Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler
N44YH - Flying - #40617 |
hotwheels
Posted: Tue Apr 10, 2012 5:33 am Post subject: Re: Door Gutter and McMaster Seals |
Maybe it's obvious, but maybe not... After cutting the door edges flush and sanding, I used an ~18" section of door seal as a mold. Filling each section with structural epoxy made for a really tight fit and minimal additional prep work to get the seal right. Just add cosmetic filler to blend into the cabin top and door edges. I bought lots more edge than required as it tends to get tired and look wavy after fitting lots of times (you can see some of that in the photos). Save the good stuff for the end.
Jay
finishing up
933.68 KB |
16233 Time(s) |
513.66 KB |
16233 Time(s) |
338.81 KB |
16233 Time(s) |
317.18 KB |
16233 Time(s) |
johngoodman
Posted: Tue Apr 10, 2012 6:38 am Post subject: Re: Door Gutter and McMaster Seals |
I ran into the same problem with fabric covering the door - I didn't account for it and ended up with the door seal too tight, so I had to trim the fabric short.
As a side note, everyone please try to size down your photos before posting, it takes too much side scrolling to read the message. All it takes is one huge photo.
Kelly McMullen
Posted: Thu Apr 12, 2012 9:06 pm Post subject: Door Gutter and McMaster Seals |
Giving due consideration to the desirability of keeping the gutter,
one has to consider the other weather striping options. The stock Vans
stuff doesn't look all that hot. Other suggestions?
On Tue, Apr 10, 2012 at 5:35 AM, jkreidler
<jason.kreidler(at)regalbeloit.com> wrote:
| Quote: | By removing the entire inside radius of the gutter in order to install the McMaster Carr style seal you are significantly changing the section modulus of the cabin top post and COULD be significantly increasing the likelihood of a cabin top failure in a roll over type accident. Just something to consider as you make what may seem to be a harmless improvement to the design.
Again, these are your decisions I am only trying to provide an alternate perspective to the decision.
Thanks Jason
A&P/IA, EAA Tech Counselor
KCHD |
jkreidler
Posted: Fri Apr 13, 2012 3:52 am Post subject: Re: Door Gutter and McMaster Seals |
Kelly, we used seals made by Abby at Flightline Interiors. They are custom made to match the interior colors, in our case she made them from light grey material. They look great, match, and work.we also attached them to the door just a bit differently. We had Velcro sewn to the back of the seal, then attached Velcro to the door. This way we could adjust the seal as required, that has proven to work fine (370 hours). No pictures handy,sorry - Jason
rene(at)felker.com Guest
Posted: Fri Apr 13, 2012 5:01 am Post subject: Door Gutter and McMaster Seals |
I used the ones on this page.
http://www.rvtraining.com/html/atp/html/accessories.html
They work great for me.....a little pricy.
Rene' Felker
N423CF
801-721-6080
Kellym
Posted: Fri Apr 13, 2012 6:39 am Post subject: Door Gutter and McMaster Seals |
Thanks Rene',
That looks like the easiest solution, should eliminate a lot of rework
of the gutter.
Rene' Felker
N423CF
801-721-6080
KCHD |
John Ackerman
Joined: 19 Jun 2006 Posts: 130 Location: Prescott, AZ
Posted: Fri Apr 13, 2012 8:39 am Post subject: Door Gutter and McMaster Seals |
We're very happy with the foam seals that Alex sells. Straightforward installation, expecially compared to the rest of the door work.... ]
http://www.aviationtechproducts.com
John Ackerman
40458
On Apr 12, 2012, at 10:02 PM, Kelly McMullen wrote:
> Thanks Jason
philperry9
Posted: Fri Apr 13, 2012 8:49 am Post subject: Door Gutter and McMaster Seals |
Love'em too. Simple and I've flown with them in past. They're quite tight and I couldn't find any leaks anywhere in the door. I made a point to look for them while we were in route.
They're great.
On Apr 13, 2012, at 11:38 AM, John Ackerman <johnag5b(at)cableone.net> wrote:
John Ackerman
40458
>> Thanks β Jason
