M14PEngines-List Digest: 1 Msgs - 01/07/12
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List
sapril001(at)hotmail.com
PostPosted: Sun Jan 08, 2012 7:26 am    Post subject: M14PEngines-List Digest: 1 Msgs - 01/07/12 Reply with quote
Are you using compressed air or nitrogen to crank the engine?
I have heard that some peoples have tried to start a M-14P with a bottle of nitrogen before, it does not work.
High air pressure compressors (portable) are not so common, unless you are a fire fighter or a diver.
Date: Sat, 7 Jan 2012 23:57:54 -0800
To: m14pengines-list-digest(at)matronics.com
Subject: M14PEngines-List Digest: 1 Msgs - 01/07/12
Today's complete M14PEngines-List Digest can also be found in either of the
of the M14PEngines-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2012-01-07&Archive=M14PEngines
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2012-01-07&Archive=M14PEngines
M14PEngines-List Digest Archive
Total Messages Posted Sat 01/07/12: 1
Today's Message Index:
1. 04:51 PM - M14P starting issues (waterpro)
________________________________ Message 1 _____________________________________
Time: 04:51:47 PM PST US
Subject: M14P starting issues
Tried starting the engine again.
Now has a Coy electronic "Shower of sparks" system on it that works very well.
Still can not get the engine to start.
Observations:
Engine fires on #7 cylinder every rotation. All other cylinders are cold. Exhaust
comes out well from right side but very little on left
Teaspoon of fuel runs out of manifold drain when opened after trying to start.
Sparks from all plugs in correct order (1,3,5,7,9,2,4,6,Cool when shower of sparks
turned on and engine rotated by hand with plugs out.
Timing at TDC on #4 just about dead on 15 degrees when points open on both mags.
Engine will fire on #7 and then nothing until rotation comes back to #7.
Engine has not run in 14 years.
Engine had 7 hours running on it after major overhaul and was pickled up until
now.
Fuel is correct to the pump and then direct to carb. Fuel filter in carb is clean.
Fuel is getting to carb. but from there????
Has M9 mags. Air start.
Any ideas you may have to get her going would be truly appreciated. The owner
would love to see this engine run.
Peter
http://forums.matronics.com/viewtopic.php?p=362688#362688
- The Matronics M14PEngines-List Email Forum -
http://www.matronics.com/Navigator?M14PEngines-List
mark.bitterlich(at)navy.m
PostPosted: Sun Jan 08, 2012 9:05 am    Post subject: M14PEngines-List Digest: 1 Msgs - 01/07/12 Reply with quote
I have heard the exact same thing, so I tried it myself. I emptied the bottle and re-filled with 100% nitrogen. (Yak-50)
The engine started normally. Maybe just mine is different, I don't know... but it started.
No arguments intended.
Mark Bitterlich
From: owner-m14pengines-list-server(at)matronics.com on behalf of Sylvain April
Sent: Sun 1/8/2012 10:21 AM
To: M-14P
Subject: RE: M14PEngines-List Digest: 1 Msgs - 01/07/12
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 12-01-07&Archive=M14PEngines
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 12-01-07&Archive=M14PEngines
Observations:
now.
Peter
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List All times are GMT - 8 Hours
