johnaswanson
Posted: Sun Jan 01, 2012 2:02 pm Post subject: Front strut steering |
I have had two hard landings with my CH701
has anyone solved the problem of the rudder and nose wheel
not self centering?
I am doing an extensive rebuild of the front gear.
Please help solve this problem.
_________________ John ch701 912 |
larrycmcfarland(at)gmail. Guest
Posted: Sun Jan 01, 2012 3:26 pm Post subject: Front strut steering |
Hi John,
I've heard of this problem a good number of times by now and would recommend
you keep landings
exclusively on the mains until the rollout is exhausted and then focus on
getting the nose gear centered
just before it touches down. Not such a difficult thing once practiced a
lot, but I had the same difficulty
initially when first introduced to landings in an 601HD. It can be done and
eventually becomes natural.
If you have wheel fairings on, you might consider that some fairings will
cause over-steer in the air.
My first Zenith round-nosed fairings did this in spades and I eventually
made my own which cut thru the air rather than placing a center of pressure
at the front end of the fairing.
Do fly safe John,
n752ms(at)softcom.net Guest
Posted: Sun Jan 01, 2012 3:54 pm Post subject: Front strut steering |
Do you think the hard landing was a result of the nose gear not centering?
Sent from Mark's iPhone
On Jan 1, 2012, at 2:02 PM, "johnaswanson" <jswanson(at)jamadots.com> wrote:
not self centering?
John ch701 912
http://forums.matronics.com/viewtopic.php?p=362188#362188
johnaswanson
Posted: Sun Jan 01, 2012 8:08 pm Post subject: Front strut steering |
> No, I do not think that self centering the nose gear was a direct result of hitting the nose wheel.
John
Last edited by johnaswanson on Sat Feb 04, 2012 5:46 pm; edited 2 times in total |
klondike(at)megalink.net Guest
Posted: Sun Jan 01, 2012 8:10 pm Post subject: Front strut steering |
John-- have you tried adding a touch of power just before touch down to help
stop the rapid loss of altitude? ---- are they cross wind induced problems?
Dan Wilde
Posted: Sun Jan 01, 2012 9:20 pm Post subject: Front strut steering |
On 1/1/2012 2:02 PM, johnaswanson wrote:
not self centering?
John ch701 912
Sounds like you might be too slow on landing or flaring too high. The
701 sinks fast when you get real slow and no power.
Dan Wilde
ronlee
Posted: Mon Jan 02, 2012 5:59 am Post subject: Re: Front strut steering |
Don't try landing too slow and steep at first as you will not be able to control the nose wheel coming down quickly. Start landing faster until you get the feel of the 701. As you get used to it you will be able to land slower while keeping the nose wheel up much better. Do not let it down (nose wheel) until you can no longer keep it off the runway.
Taking the slats off and add vortex generators, helps do this much easier as the plane will float a bit farther before plunking down. I think you will like your 701 better with slats off. If you must land on VERY short runways then keep them on.
_________________ Ron Lee
Tucson, Arizona |
johnaswanson
Posted: Mon Jan 02, 2012 9:24 am Post subject: Re: Front strut steering |
n801bh(at)netzero.com Guest
Posted: Mon Jan 02, 2012 9:51 am Post subject: Front strut steering |
It has been 25 years since I sold my PA -28-151 but I 'think' the Piper Pa-28 series aircraft have the nose wheel and rudder interconnected...
Ben Haas
N801BH
www.haaspowerair.com
frank goodnight
Posted: Mon Jan 02, 2012 11:02 am Post subject: Front strut steering |
As a newbe to this list. and just starting to build my 701. I have a lot of questions, some
of witch I'm sure have already been asked and answered.Does anyone know the reason Zenith did away with the tail wheel on the 701 ?
Frank Goodnight
Arkansas 701 builder
From: "n801bh(at)netzero.com" <n801bh(at)netzero.com>
Sent: Mon, January 2, 2012 11:45:21 AM
Subject: Re: Re: Front strut steering
Ben Haas
N801BH
Posted: Mon Jan 02, 2012 4:24 pm Post subject: Front strut steering |
Excuse me for replying.
Fritz
graeme(at)coletoolcentre. Guest
Posted: Mon Jan 02, 2012 5:50 pm Post subject: Front strut steering |
I and most other CH701have done hundreds of landings with the serious design
flaw in our CH701 and not bent the front wheel.
Maybe 36years hasn't prepared you for the Ch701 try landing faster with more
elevator control!
graemecns
NYTerminat(at)aol.com Guest
Posted: Mon Jan 02, 2012 6:45 pm Post subject: Front strut steering |
The 701 airplane is nothing like the certified planes that I have flown over the years. It is more like a cross between an ultralight and a regular plane. You need instruction in this plane just like I would need instruction to land a 747. I believe that there is not a design flaw but a pilot flaw in lacking experience in type.
Bob Spudis
N701ZX CH701/912S
In a message dated 1/2/2012 8:50:39 P.M. Eastern Standard Time, graeme(at)coletoolcentre.com.au writes:
[quote]--> Zenith701801-List message posted by: "Graeme(at)Coletoolentre" <graeme(at)coletoolcentre.com.au>
elevator control!
graemecns
----- Original Message -----
To: <zenith701801-list(at)matronics.com>
Sent: Tuesday, January 03, 2012 10:19 AM
[quote] --> Zenith701801-List message posted by: "fritz" <klondike(at)megalink.net>
Fritz
dougsnash
Posted: Mon Jan 02, 2012 7:01 pm Post subject: Front strut steering |
I've been trying to decide "if" and/or "how" to answer this thread. I have been flying for nearly ten years, have about 300 hrs total time with about 125 of that in my scratch built 701. I, like many of the posters here, have not really found this "Serious Design Fault" with the Zenith nose wheel steering that the original poster, John, mentioned. I have landed my little beastie in a gusty 15 kt, 90 degree crosswind with out any aircraft induced issues (I have decided 15 kt crosswind is my personal limit, not necessarily the planes limit). Thus my initial (unvoiced) response to the opriginal poster was simply "learn to fly the plane".
Giving John his due, as he says, he's been flying for well over thirty years, perhaps there is something different or wrong with his 701. Is the steering assembly unusually stiff? Are there VGs on the elevator? Elevator VGs help quite a bit with nose control during landing.
The next question would be, how much time on type does John have? The 701 is an international (as opposed to US) ultralight/ microlight. The CH-701 has very little momentum and is a very high drag plane. As someone pointed out, when the 701's nose comes up in the flare, the plane stops flying RIGHT NOW! unless a little extra power is maintained. This unusual flare characteristic is just one of the many ways the 701 differs from production aircraft, necessitating a proper checkout on type, even for a high time pilot.
John, since there are several of us on the 701/801 list that are satisfied with the nose wheel steering system of our 701s and do not see your "serious design fault", maybe we should discuss the specific details of how your steering system is set up and how that might be causing problems others are not experienceing. Failing that, I suspect many others will chime in with responses similar to my initial gut feeling which will be of absolutely no benifit to you. As others have said, we find the 701 to be a great little airplane.
Hope we can help you out.
Doug M
CH-701 from Scratch
NW Ontario, Canada
| Quote: | > --> Zenith701801-List message posted by: "johnaswanson"
> <jswanson(at)jamadots.com (jswanson(at)jamadots.com)>
> I believe the ch701 has a serious design fault with the design of the
> front strut and the nose wheel and rudder always being linked
> together unlike production aircraft.
> My topic was meant to address this design flaw not to critique our
> landings. 36 years of flying certified aircraft has never resulted in any
> damage or hard landings as in the CH701
> John ch701 912
johnaswanson
Posted: Tue Jan 03, 2012 6:42 am Post subject: Re: Front strut steering |
experience, proficiency,skill, etc aside
has anyone made any mechanical improvements to the
nose wheel, strut, steering etc of the CH701?
I think someone out there has a better idea.
Posted: Tue Jan 03, 2012 7:28 am Post subject: Front strut steering |
John.
Try Larry Martins site www.skyhawg.com. Look for the link spring loaded steering rods.
Just keep in mind while Larry is a talented builder he does not fly. So a lot of his designs have not been extensively tested. Also when using this setup all the foot pressure when applying the brakes goes to your rudder cables and then on to your rudder horn and associated ware points.
For a fairly new guy to the list you have gotten spanked pretty hard the last couple of days. It's probably not a good idea to come on to a list that loves there 701's and say that what they are flying has serious design flaws.
For the little amount of time my nose wheel is on the ground it is just not an issue.
Hope Larry's site helps.
Mark S.
701/912uls 200hrs 122 off airport landings
Sent from Mark's iPad
On Jan 3, 2012, at 6:42 AM, "johnaswanson" <jswanson(at)jamadots.com> wrote:
John ch701 912
http://forums.matronics.com/viewtopic.php?p=362323#362323
johnaswanson
Posted: Tue Jan 03, 2012 8:54 am Post subject: Re: Front strut steering |
before I can do any more flying and landings i need to do some
fixing!
So this is my opportunity to "improve" on "my" airplane.
Has anyone on this list made any changes?
lrm(at)skyhawg.com Guest
Posted: Tue Jan 03, 2012 9:33 am Post subject: Front strut steering |
Actually, the rudder/front wheel spring setup has been extremely well
tested/used. The same setup has been used on the RAF-2000 gyroplane for
many many years. It wasn't exactly my idea, I just put it on a 701. I
have 20+ hours of taxiing on my 701, and it works fine. Larry did fly,
Larry just doesn't care to anymore, as they say, "been there, done
that". When I flew gyros it helped a lot. If you don't think you would
like the setup you can always tighten them up where you have no spring
assistance. Take care, Larry
On 1/3/2012 9:25 AM, Mark S. wrote:
John.
Mark S.
> John ch701 912
john.marzulli(at)gmail.co Guest
Posted: Tue Jan 03, 2012 9:41 am Post subject: Front strut steering |
One thing that I am still not fully happy with in my 701 is the friction in the front nose fork bearings.
To help with this I added a nylon bearing block underneath the strut cap and then heavily lubricated it with teflon.
Others have added nylon blocks to the inside of the lower nose bearing extrusion such that the welded tubes that attach to the push rods ride on the nylon when in flight.
John Marzulli
http://MarzulliPhoto.net/
http://701Builder.blogspot.com/
On Tue, Jan 3, 2012 at 8:54 AM, johnaswanson <jswanson(at)jamadots.com (jswanson(at)jamadots.com)> wrote:
[quote] --> Zenith701801-List message posted by: "johnaswanson" <jswanson(at)jamadots.com (jswanson(at)jamadots.com)>
fixing!
John ch701 912
http://forums.matronics.com/viewtopic.php?p=362333#362333
-List" target="_blank">http://www.matronics.com/Navigator?Zenith701801-List
le, List Admin.
johnaswanson
Posted: Sun Jan 08, 2012 6:23 am Post subject: Front strut steering |
On Jan 3, 2012, at 12:30 PM, Larry wrote:
| Quote: | --> Zenith701801-List message posted by: Larry <lrm(at)skyhawg.com (lrm(at)skyhawg.com)>
Actually, the rudder/front wheel spring setup has been extremely well tested/used. The same setup has been used on the RAF-2000 gyroplane for many many years. It wasn't exactly my idea, I just put it on a 701. I have 20+ hours of taxiing on my 701, and it works fine. Larry did fly, Larry just doesn't care to anymore, as they say, "been there, done that". When I flew gyros it helped a lot. If you don't think you would like the setup you can always tighten them up where you have no spring assistance. Take care, Larry
Larry
Thanks for the reply, I would like to try your spring mod.
on my CH701.
Do your have a parts list?
if not can you tell me more about the parts needed, size of spring etc.
thanks
John
ch701 912
