Ralph Hoover
Joined: 09 Jan 2006 Posts: 206 Location: Central Ohio
Posted: Thu Jan 12, 2006 4:36 pm Post subject: 40 MPH Stall |
Kolbers. I have a problem. My 1990 Kolb Firestar KXP single seat, with 503 DIDC has a stall speed of 40 MPH plus. Now this is in calm air in late fall. Twice my instructor has flown it, as I am still in the instruct-ee's seat. And both time, because I have specifically asked "what speed does it stall?", the reply has been the same...40 ish!
There are no holes anywhere. It has a complete enclosure, with the exception of backside. It has the alerons stits covering (underside) between the alerons and the wing. According to my instructor it flys like a home sick angle. He said that it doesn't have any side to side misallignment and the stick stays streight for streight flight. I have looked under the motor to see if perhaps the motor is raised or lowered from flat. It's not.
HELP !!!
I won't mind landing at 45-50 in calm air if I have too. But when I hear the average from the Kolb site and from THNK Company and Travis as being closer to 25 MPH, I gotta think I have a problem. Now my instructor weighs in about 190# and I and the previous owner at around 230 #. There is nothing different about the plane from the origional plans that I can find except the longer legs, which would not or should not effect it's flight charistics to any degree. I have not weighed it or checked its balance for location of center of gravity, but again my instructor didn't feel that it was very far off if at all. Somehow I have to gets my hands on three 300# mechanical scales to check this area out. But still where in your humble opinion(s) does the problem lie (or lay)? My last thought might be something regarding adjusting the aleron rods in or out (up or down on the alerons). Could these be the calprets! (^%$^%#$%^ spell checker)!!
New Kolber with a desire to know (as well as a need).
Richard Pike
Posted: Thu Jan 12, 2006 5:16 pm Post subject: 40 MPH Stall |
Get a good GPS and go fly some 120 degree triangles in the stillest air
you can find, take notes, fly at 45, 55, 65, and see if your airspeed
indicator is flawed. Ours was.
Also, we tried having the pitot come out above the nose cowling and
curve forward, and never got a decent result. It has to either come out
the nose or below the nose to work right ( at least that was out
experience) Eventually we learned that the pitot has to be in an
acceptable place, (and we also have the static air right beside it) and
a faulty airspeed indicator will really waste a lot of your time.
Richard Pike
MKIII N420P (420ldPoops)
FSII N582EF
Ralph Hoover wrote:
[Evil or Very Mad]
HELP !!! [Crying or Very sad] [Crying or Very sad]
spell checker)!!
New Kolber with a desire to know (as well as a need). [Idea]
http://forums.matronics.com/viewtopic.php?p=3450#3450
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
ul15rhb(at)juno.com Guest
Posted: Thu Jan 12, 2006 5:20 pm Post subject: 40 MPH Stall |
Ralph,
I think your ASI is not reading right.
Ralph B.
Original Firestar
19 years flying it (stalls at 25mph, ASI reads 20 due to AOA)
[Evil or Very Mad]
spell checker)!!
Try Juno Platinum for Free! Then, only $9.95/month!
possums(at)mindspring.com Guest
Posted: Thu Jan 12, 2006 5:24 pm Post subject: 40 MPH Stall |
[Evil or Very Mad]
I'll bet either he hasn't really stalled it or your air speed
indicator is wrong.
Mine is heavier than yours could possible be and I've got the stall
or "mush" down to about 28 mph.
BTW : I would always land a little fast if I were you, we don't get no
extra points for three point landings here.
There are very few things that you can do to
your plane that does anything at all for the performance -
after spending lots of time and money it
sometimes actually degrades the performance of what you
were trying to do anyway.
I've spent lots of $ for nothing several times.
I've got over 670 hours on this one
I was just surprised at what these little things would actually do
for the amount of
time and money invested. I fly my plane slow - a lot. I fly my plane
at stall speed at lot.
http://www.mindspring.com/~possums/
http://www.landshorter.com/index.html
A lot more control a just above stall. I used the little lexan
"Landshorter" ones - about 42 + per wing, used the pattern they
sent for the layout. They're even hard to see unless you look close.
It takes two of these to make one of the homemade ones some of the guys use.
URL: <http://sos.photosite.com/Album1/>http://sos.photosite.com/Album1/
James Tripp
Posted: Thu Jan 12, 2006 5:34 pm Post subject: Re: 40 MPH Stall |
Ralph,
My FSII also stalls right at 40MPH IAS. I'm 200 lbs and the empty weight of my FS is 445 lbs. I'm almost certain my ASI reads at least 5 MPH high and probably does so because I don't have a static port. I haven't bother to fix it because it just doesn't matter. I just need to know what the stall speed is with the indicator I have.
_________________ James Tripp
FSII
Millbrook AL |
flht99reh(at)netzero.net Guest
Posted: Thu Jan 12, 2006 5:50 pm Post subject: 40 MPH Stall |
Ralph B. I wish you were right. However, according to my instructor who has
been flying for years and knows appearances of air speed, he says NO WAY! I
would know if it were that far off. A few MPH perhaps but not that much. He
typically lands his trainer a (yuk) Challenger at his filed at around 50
with the two of us in it. But just to eliminate that as a problem, once
reassembled, I have both a new Winter ASI and the MGL avionic Flight-2 glass
gauge to tell me. And if they both lie or dispute, then it's the gumball
machine on the outside of the side windscreen.
I wish you were correct. I even have added since the second (last flight) a
static line to the outside of the cockpit, per TNK advise. This may have
been part of the culprit. We shall see. Thank you for your help. A
Are we to continue to use the words do not archive in this new BBS?
Ralph "the other Ralph" Hoover
Posted: Thu Jan 12, 2006 5:57 pm Post subject: 40 MPH Stall |
Thanks Richard. I replied to the "Good" Ralph on this site and added a few
comments of which included static line (as full cockpit exists on this
plane), and changing ASI's to a new Winter. So are you to say that now, you
are stalling at 25 range? That sure would make my heart rate a tad milder.
By the way, my predecessor in ownership did install the Pitot tube in the
center of the bull's eye on the nose cone and it is approximately one foot
long. I'll add that I have not yet changed the fuel tank to anything
different than the factory 5 gallon, should weight dispersement be anything
to concern myself about.
Posted: Thu Jan 12, 2006 6:06 pm Post subject: 40 MPH Stall |
Possum, ya make my eyes water! Your web site and that jacket is way too
much. As far as the Vortex goodies, I have read a lot about them on this
site. I may add them at a latter date along with some other goodies.
However, that still doesn't explain why the high stall rate. I appreciate
your input and will keep a copy of your answer. Thanks
lstavenhagen(at)hotmail.c Guest
Posted: Thu Jan 12, 2006 6:10 pm Post subject: 40 MPH Stall |
Mine also stalls around 40 as well, actually about 42 or 43 IAS with full
gas. Mine is 440lbs empty weight and I'm about 185lbs.
So doesn't sound to me like there's a problem. We got 140 sq feet of wing
area on the FSII after all, so even heavy-ish planes like mine have plenty
of lift for good climb rates and slow landings.
Remember also that in the flare your stall speed will be even lower due to
ground effect, so you should still be able to touch down quite a bit slower
than 40mph.
LS
N646F
Posted: Thu Jan 12, 2006 6:13 pm Post subject: 40 MPH Stall |
James, you know when someone tells you something and it doesn't make any
sense and then someone else tells you the same thing in a different way, a
light comes on. Well the light came on. The problem still exists but now I
see where someone said "just need to know what the stall speed is with the
indicator I have." And now I understand. It could read eighty and still be
twenty-five (of courses that would mean that I would typically fly at around
115 when cruising). HA, HA!
Thanks. I would rather fix it rather than continue with it in that way. I
think! Thanks for you advise.
planecrazzzy Guest
Posted: Thu Jan 12, 2006 6:30 pm Post subject: Re: 40 MPH Stall |
Hi,
You wrote to me after my first flight in my Kolb....
Like I had told you when you were wondering about my stall speed...
Like I said to you then.... When you go up , Your first flight should be a short one.....get up to 3000 ft and "APPROACH" a stall ......NOT A FULL STALL...... then you'll have the info you need to be safe....
And it does sound like a "STATIC" problem that your having...
Got a digital camera ??? lets see PICTURES , CLOSE UPS.....
Gotta Fly...
Mike in MN FSII / N381PM
I bought one of those "Hall" mechanical wind guages as a "Check" because I couldn't believe how SLOW I was flying before stall...
Description: |
Filesize: |
59.97 KB |
Viewed: |
655 Time(s) |
Posted: Thu Jan 12, 2006 7:19 pm Post subject: 40 MPH Stall |
How many "Ralphs" we got??
Anyway, my wings are 9 inches shorter than my old
1989 KXP. The ribs are the same as yours. the wing tips are
different - so the lift should be about the same.
I'm sure my plane weighs in just under 400 LBS -- Oooch.
I hate to admit that - it's like asking some little thing
if's she's pregnant (she'd better be). Or how old are you honey?
Posted: Thu Jan 12, 2006 8:00 pm Post subject: 40 MPH Stall |
Oh -- BTW I've got a $35 "Hall ASI" on my nose cone, Air Speed Indicator
in the Instrument panel and Garmon GPS 295 inside.
So I'm pretty sure my airspeed is right, but the Hall is the most accurate.
Before the VG's my stall speed was only around 36 mph - so don't
expect miracles.
Possum
Posted: Thu Jan 12, 2006 8:33 pm Post subject: Re: 40 MPH Stall |
Just a test....
expect miracles.
Actually got a glass panel - but still have my "Hall" as
a back up. Ha Ha
Description: |
Filesize: |
52.28 KB |
Viewed: |
673 Time(s) |
wcm(at)tampabay.rr.com Guest
Posted: Fri Jan 13, 2006 4:59 am Post subject: 40 mph stall |
My problem was just the opposite, when I first got my FS II, I could fly all
day long at 30 mph IAS with absolutely no tendency to stall. After I bought
a new ASI the plane stalls at a true 30 mph.
If your installation of a static line doesn't change your reading, try a new
instrument.
Mallory
Richard Pike
Posted: Fri Jan 13, 2006 6:51 am Post subject: 40 MPH Stall |
Around 25 would be pretty awesome, but no, it stalls at 32 power on, 35
power off.
It is heavy at 488, (lights, transponder, mode C, bulletproof Lexan
floorboards, etc.)
(not how I would have done it, but it's not my airplane, so...)
which is why it doesn't stall slower, however it handles great,
and a 35 mph power off stall is very easy to live with.
Here is the airplane and the mods we made to it -
http://www.bcchapel.org/pages/0003/kolb.htm
Richard Pike
Kingsport, TN 3TN0
Richard Pike
Posted: Fri Jan 13, 2006 7:31 am Post subject: 40 MPH Stall |
Our original flawed airspeed indicator read ok at 50, but false at high
and low airspeeds, so when you got up to an indicated 75, you were
actually going 90. Stuff like that will get a man killed...
Richard Pike
Kingsport, TN 3TN0
Posted: Fri Jan 13, 2006 7:35 am Post subject: 40 MPH Stall |
expect miracles.
Can you provide a link to the $35 hall asi product?
cartejy(at)mtn-state.com Guest
Posted: Fri Jan 13, 2006 9:24 am Post subject: 40 MPH Stall |
Ralph, where are you located in Ohio, I am at East Liverpool,I own a 91 KXP
and it lands slower than you mention.I would not get to excited about it,may
be no problem..or may be air speed indicator ,you will have lots of fun with
the KXP and they fly great. Jay Carter KXP /503. do not archive
Possum
Posted: Fri Jan 13, 2006 10:23 am Post subject: Re: 40 MPH Stall |
http://www.hallwindmeter.com/wind.php
Description: |
Filesize: |
112.81 KB |
Viewed: |
596 Time(s) |
