M14PEngines-List Digest: 0 Msgs - 07/10/11
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List
sapril001(at)hotmail.com
PostPosted: Mon Jul 11, 2011 3:31 am    Post subject: M14PEngines-List Digest: 0 Msgs - 07/10/11 Reply with quote
Hi all,
I have this question about the oil temperature for the M-14P, My oil temperature is reaching 200 Deg F on take off and come down to 190F in flyght. The maximum should be 185 F acording to the manual.
I had a look at the air ducting to the cooler and behind it, it is as good as I can get it. May be my oil cooler is not big enough.
What would be the size of the oil cooler on a M-14P in a Moose aplication.
Sylvain April, C-GFFO  Murphy Moose.
- The Matronics M14PEngines-List Email Forum -
http://www.matronics.com/Navigator?M14PEngines-List
george(at)gesoco.com
PostPosted: Mon Jul 11, 2011 5:20 am    Post subject: M14PEngines-List Digest: 0 Msgs - 07/10/11 Reply with quote
The first question is where are you measuring the oil temperature. The Book values are oil inlet temperatures. That is the temperature of the oil as it leaves the tank and is pumped into the engine.
  If you are really reading continuous oil temps at 190 deg during flight then you may need to get more air through your oil cooler or get more cooling capacity.
George Coy
CAS Ltd.
714 Airport Rd.
Swanton VT 05488
802-868-5633 off
802-363-5782 cell
802-868-4465 Fax
george.coy(at)gmail.com (george.coy(at)gmail.com)
http://coyafct.com/
SKYPE george.coy
From: owner-m14pengines-list-server(at)matronics.com [mailto:owner-m14pengines-list-server(at)matronics.com] On Behalf Of Sylvain April
Sent: Monday, July 11, 2011 7:28 AM
To: M-14P
Subject: RE: M14PEngines-List Digest: 0 Msgs - 07/10/11
Hi all,
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List All times are GMT - 8 Hours
