galinhdz(at)gmail.com Guest
Posted: Fri Apr 22, 2011 6:48 pm Post subject: KIS accidents?? |
After reading about Alfred's incident I was wondering, does anybody know how many serious accidents KIS airplanes have had over the years due to airplane failure? Numbers and probable cause for both the TR-1 and TR-4 where the airplane was a total loss.
Galin
| - The Matronics KIS-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Robert Reed
Joined: 22 Oct 2009 Posts: 331 Location: Dallas/Ft.Worth
Posted: Fri Apr 22, 2011 7:34 pm Post subject: KIS accidents?? |
There have been six or seven with the TR-4 that I am aware of. The original prototype had an engine failure, set down in a plowed field, flipped on it's back but had rather minor damage and flew again. First customer built version had door open, pilot tried to close but jammed seat cushion into controls, crashed knot orchard trees and destroyed plane, pilot injured but ok. Second factory demonstrator which used Cont.IO-360 was destroyed and pilot killed when Solley left it to get upgrade on interior and someone who apparently shouldn't have been flying couldn't land the plane aster more than one attempt. First Subaru version in south Africa had engine failure and had off field landing. It was repaired and engine replaced with Lycoming and is still flying. The plane shown on my website home page had engine failure, set down with damage and burned but no fatalities. The latest report was a Cruiser that I didn't
t even know was in the DFW area that had engine failure on takeoff with fatalities to pilot and his wife. A couple of minor incidents including yours. The only thing I would call a failure of the aircraft might be the problem with the doors opening in flight. I haven't kept up with the TR-1 accidents.
Those are the only ones I have heard about.
On Apr 22, 2011, at 9:44 PM, Galin Hernandez <galinhdz(at)gmail.com (galinhdz(at)gmail.com)> wrote:
[quote]After reading about Alfred's incident I was wondering, does anybody know how many serious accidents KIS airplanes have had over the years due to airplane failure? Numbers and probable cause for both the TR-1 and TR-4 where the airplane was a total loss.
Galin
sstearns2(at)yahoo.com Guest
Posted: Fri Apr 22, 2011 8:34 pm Post subject: KIS accidents?? |
--- On Fri, 4/22/11, Galin Hernandez <galinhdz(at)gmail.com> wrote:
Quote: |
Subject: KIS accidents??
To: kis-list(at)matronics.com
Date: Friday, April 22, 2011, 7:44 PM
Galin
| [quote][b]
lgdavid(at)roadrunner.com Guest
Posted: Fri Apr 22, 2011 9:12 pm Post subject: KIS accidents?? |
My TR1 with a Subaru engine went into limp home mode on my second test flight and I made an off field landing in a celery field. Since the engine was still turning at about 1100 rpm, it tore the nose off as it ground to a halt in the field. Plane protected me and kept me alive, but I never rebuilt it. The left turn in the nose was part of the decision but more importantly Gasohol had eaten into the webbing of the main spar and weakened it so that it snapped on the landing. Strangely, the rear spar was still in tack. So you can add one to the not rebuilt column of damaged TR1s. Larry
On 4/22/2011 8:32 PM, Robert Reed wrote: [quote] There have been six or seven with the TR-4 that I am aware of. The original prototype had an engine failure, set down in a plowed field, flipped on it's back but had rather minor damage and flew again. First customer built version had door open, pilot tried to close but jammed seat cushion into controls, crashed knot orchard trees and destroyed plane, pilot injured but ok. Second factory demonstrator which used Cont.IO-360 was destroyed and pilot killed when Solley left it to get upgrade on interior and someone who apparently shouldn't have been flying couldn't land the plane aster more than one attempt. First Subaru version in south Africa had engine failure and had off field landing. It was repaired and engine replaced with Lycoming and is still flying. The plane shown on my website home page had engine failure, set down with damage and burned but no fatalities. The latest report was a Cruiser that I didn't
Quote: | After reading about Alfred's incident I was wondering, does anybody know how many serious accidents KIS airplanes have had over the years due to airplane failure? Numbers and probable cause for both the TR-1 and TR-4 where the airplane was a total loss.
Galin
| [b]
katebob10(at)yahoo.com Guest
Posted: Sat Apr 23, 2011 4:25 am Post subject: KIS accidents?? |
TR-1, N232AN was totally destroyed on July 30, 2007 due to a failure of the left wing push rod attached to the aileron. NTSB determined the rivets were not installed in the rod where it attached to the aileron. Pilot (me) was seriously injured. I was third owner of this aircraft.
Sent: Fri, April 22, 2011 9:44:59 PM
Galin
BlueSkyFlier
Posted: Sat Apr 23, 2011 12:27 pm Post subject: Re: KIS accidents?? |
I know of three incidents here in the UK where TR-1 doors opened in flight, the last one in latter half of last year. Two doors are still missing in action and nobody the worse for it, the third one came open just after takeoff and was damaged but passenger managed to pull it down again although his headset was flapping out the side. Other than a new hole in the pilot's seat cover, no problems ) These planes are all still flying today.
A quick scan of the UK register shows one TR-1 destroyed in 1997 and one TR4 Cruiser destroyed in 2009. Apparently no fatalities or serious injuries (but I could not find the AAIB report of the 1997 accident) [edited after memory kicked into gear ... there was one fatality in a TR-1, possibly the 1997 incident. It happened off the coast of France whilst the pilot was flying low altitude maneuvres over the sea.]
Other than the destroyed aircraft, three TR-1s without wings here in UK, two of these are tail draggers (damaged in landing incidents) and the third is/was mine (taxi incident).
Seven TR-1s are still on the register her in the UK (incl the three without wings ) John Petrie probably knows the record for South Africa. A good tally of kits were bought by the guys there.
Alfred
_________________ _________________________________________ |
wschertz(at)comcast.net Guest
Posted: Sat Apr 23, 2011 2:23 pm Post subject: KIS accidents?? |
An early newsletter (back when they had newsletters) told of a European
crash into the sea (with fatality) 1997 would have been about right.
Bill Schertz
KIS Cruiser #4045
N343BS
Phase one testing Completed
cody.r.austin(at)gmail.co Guest
Posted: Sun Apr 24, 2011 4:21 pm Post subject: KIS accidents?? |
Here is a website with detail on a KIS Cruiser crash.
http://www.sdsefi.com/air34.htm
- Cody
On Sat, Apr 23, 2011 at 7:20 AM, Bob and Kathy <katebob10(at)yahoo.com (katebob10(at)yahoo.com)> wrote:
[quote]TR-1, N232AN was totally destroyed on July 30, 2007 due to a failure of the left wing push rod attached to the aileron. NTSB determined the rivets were not installed in the rod where it attached to the aileron. Pilot (me) was seriously injured. I was third owner of this aircraft.
From: Galin Hernandez <galinhdz(at)gmail.com (galinhdz(at)gmail.com)>
Galin
Quote: |
et="_blank">http://www.matronics.com/Navigator?KIS-List
tp://forums.matronics.com
bakerocb
Posted: Tue Apr 26, 2011 4:24 am Post subject: KIS accidents?? |
4/26/2011
Hello Larry, You wrote: "..... Gasohol had eaten into the webbing of the main spar and weakened it so that it snapped on the landing."
The above statement is the first time that I had heard of this aspect of your accident. I am puzzled by this conclusion because:
A) Your airplane was so new that I have difficulty believing that the ethanol alcohol (10 percent?) in the gasoline would have had enough time to significantly weaken the spar.
B) I did not believe that cured epoxy would be significantly affected by ethanol alcohol, especially in such a short time as your airplane existed.
C) How did you conclude that the spar had indeed been weakened by the ethanol alcohol.
Can you please educate me? Thanks,
OC
[quote] From: Larry David (lgdavid(at)roadrunner.com)
Sent: Saturday, April 23, 2011 1:10 AM
Subject: Re: KIS accidents??
bakerocb
Posted: Tue Apr 26, 2011 4:42 am Post subject: KIS accidents?? |
4/26/2011
Hello Alfred, You wrote: "A quick scan of the UK register shows one TR-1
1997 accident)"
The October 1996 issue of the KIS and Tell newsletter reported on the loss
of a KIS TR-1 and the death of the two occupants. This could be the 1997
accident that you referred to above.
One of the occupants was Adrian Caple, who was an England representative of
Tri-R Technologies, and was presumably demostrating the airplane to a
prospective builder.
Here is what the newsletter said: "All investigations reported to date have
indicated no evidence of aircraft structure or flight characteristics
contributing to the accident. All damage noted was consistent with a high
speed impact with the water."
OC
From: "BlueSkyFlier" <bleuskyfly(at)teledynamix.com>
To: <kis-list(at)matronics.com>
Sent: Saturday, April 23, 2011 4:27 PM
again although his headset was flapping out the side. Other then a new
flying today.
Other than that, three TR-1s without wings here in UK, two of these are
tail draggers and the third is/was mine.
Seven TR-1s still on the register her in the UK (incl the three awaiting
new wings ) John Petrie probably knows the record for South Africa. A
Alfred
