ssssskippy
Posted: Sun Apr 17, 2011 9:38 am Post subject: Oil press indicator : unstable |
Hi
I had a problem with my oil collector that was broken. So there was an air entry In the oil system that induced a very low oil pressure : 1 at low rpm 2 at 45%.
I changed the collector this week end and the air pénétration is fixed yet. Oil pressure= 5 at 45%
However I notice that the oil press indicator oscillating quickly: not stable
Is that normal? Is there some air In the oil circuit or Is that a reliability problem with the indicator?
Olivier
Le 17 avr. 2011 à 11:46, "philg" <philgower(at)rappsystems.com.au> a écrit :
KingCJ6(at)aol.com Guest
Posted: Sun Apr 17, 2011 1:48 pm Post subject: Oil press indicator : unstable |
If it is moving quickly, it may be a bad connection or sending unit. Check the cannon plugs and try to swap front-to-rear sending units to isolate.
Dave
In a message dated 4/17/2011 10:38:44 A.M. Pacific Daylight Time, ssssskippy(at)gmail.com writes:
| Quote: | --> Yak-List message posted by: ssssskippy <ssssskippy(at)gmail.com>
Hi
Olivier
| Quote: | --> Yak-List message posted by: "philg" <philgower(at)rappsystems.com.au>
Paul, I have been trialling a LED light and reflector obtained on ebay for the tail light, see attached pic. Contact me off list if you want more details on this project. Cheers, Phil Gower.
http://forums.matronics.com/viewtopic.php?p=337188#337188
http://forums.matronics.com//files/p1270024mod_151.jpg
========================e ties Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp; ===================================================
ssssskippy
Posted: Sun Apr 17, 2011 2:04 pm Post subject: Oil press indicator : unstable |
Thanks for the answer.
You can see the shaky moove of the indicator at the beginning of this video:
http://www.youtube.com/watch?v=2f6TfU5T8dY&feature=youtube_gdata_player
Olivier
Dave
In a message dated 4/17/2011 10:38:44 A.M. Pacific Daylight Time, ssssskippy(at)gmail.com (ssssskippy(at)gmail.com) writes:
| Quote: | --> Yak-List message posted by: ssssskippy <ssssskippy(at)gmail.com (ssssskippy(at)gmail.com)>
Hi
Olivier
Le 17 avr. 2011 à 11:46, "philg" <philgower(at)rappsystems.com.au (philgower(at)rappsystems.com.au)> a écrit :
Cliff.Coy
Posted: Mon Apr 18, 2011 7:25 am Post subject: Oil press indicator : unstable |
It's appears you have an electrical issue with the aircraft as all of the powered gauges are oscillating at the same frequency.
Check your charging system first- bad diode in alternator, or current reversal in the generator.
Cliff
On Sun, Apr 17, 2011 at 18:01, ssssskippy <ssssskippy(at)gmail.com (ssssskippy(at)gmail.com)> wrote:
| Quote: | Thanks for the answer.
Olivier
Dave
Hi
Olivier
========================e ties Day ======================= - MATRONICS WEB FORUMS ======================= - List Contribution Web Site sp; =
| | Quote: |
et="_blank">http://www.matronics.com/Navigator?Yak-List
Clifford Coy
Border Air Ltd.
629 Airport Rd.
Swanton, VT 05488
802-868-2822 TEL
802-868-4465 FAX
Skype: Cliff.Coy
ssssskippy
Posted: Mon Apr 18, 2011 7:37 am Post subject: Oil press indicator : unstable |
ok thanks!
2011/4/18 Cliff Coy <cliff.coy(at)gmail.com (cliff.coy(at)gmail.com)>
[quote] It's appears you have an electrical issue with the aircraft as all of the powered gauges are oscillating at the same frequency.
Cliff
Olivier
Dave
Hi
Olivier
Clifford Coy
Border Air Ltd.
629 Airport Rd.
Swanton, VT 05488
802-868-2822 TEL
802-868-4465 FAX
Skype: Cliff.Coy
Posted: Mon Apr 18, 2011 7:54 am Post subject: Oil press indicator : unstable |
A quick check to see if the charging system is at fault is to simply turn it off and run the aircraft on batteries alone and see what happens.
Mark
