sapril001(at)hotmail.com Guest
Posted: Tue Apr 12, 2011 5:03 am Post subject: Fuel Flow |
Hi all,
Just to clarify, my 133L/hr is free flow from the wing tanks measured at the firewall connection flowing in a jerrycan. The fuel goes from the tank through the wing isolation valves, through a gascolator, through the fuel shutoff valve and through a check valve in parallel with a small fuel pump used for primer pressure.
This flow is just driven by the head of the fuel tank located in the wings. It should be 125% of the max engine flow, this is a recomendation.
I know that when the fuel line is connected to the engine and I am doing my ground test acceleration runs, the engine have all the fuel that it need, the flow must be 155L/hr.
The gravity fuel flow aided by the fuel pump of the engine is more than enough to maintain 7 PSI at the carburator.
My question is: should I modify my piping to ensure a free flow of 125% of the maximum that the engine use at take off.
My understanding of this recomendation is that when an airplane is aging the various strainer will get clogged and the flow could be reduced enough to cause vapor lock problems.
Does anyone know if the M14P fuel pump is suceptible to cavitation problem if the suction pressure is to low?
Sylvain April
| - The Matronics M14PEngines-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?M14PEngines-List |
