Robin Marks
Joined: 10 Jan 2006 Posts: 24 Location: San Luis Obispo, CA
Posted: Mon May 08, 2006 5:04 pm Post subject: Off Field Landing |
Does anyone have information about an off field landing of an RV-10 in the west about 2 weeks ago? I heard from a local pilot that a -10 that had recently visited SBP (San Luis Obispo) then later in the week made a forced landing due to engine failure. The local pilot had strong feelings that the failure was related to fuel vapor lock.
I am sorry for the sketchy information but it would be of benefit to learn the particulars.
Robin
RV-6A 300 hours
RV-10 Tail Feathers
_________________ RV-4 Sold
RV-6A 0-360 - C/S Flying |
johnwcox(at)pacificnw.com Guest
Posted: Mon May 08, 2006 5:28 pm Post subject: Off Field Landing |
James Rore (N728DD), Albert Cook (N329BC), Leroy Williams (N231LD), Ed McGinty (N770BD), Mark Christiansen (N104ML), Doug Petersen (N410DP), or Randy DeBauw (N610RV) would be the seven logicals on the West Coast (from the builder names in my database). Sounds like Randy is fine. Mark are you out there?
John – KUAO
Do not Archive
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robin Marks
Sent: Monday, May 08, 2006 6:03 PM
Subject: Off Field Landing
Robin
RV-6A 300 hours
RV-10 Tail Feathers
dlm46007(at)cox.net Guest
Posted: Mon May 08, 2006 6:00 pm Post subject: Off Field Landing |
I just ran the NTSB stats for the last two months. About 25 accidents/incidents for homebuilts but no RV10s.
ericmpmail-rv10(at)yahoo. Guest
Posted: Mon May 08, 2006 9:19 pm Post subject: Off Field Landing |
Might not have been reported.
Even if it did not happen, or was not fuel system
related it is worth mentioning that it is shaping up
to be a hot summer.
As was discussed earlier - autofuel has higher vapor
pressure but even 100LL can run into problems. High
alt, high temp (+ a hot tunnel) can contribute. I
believe the Eggenfellner crowd discovered one weakness
of pumps is they will not pump vapor... One of the
reasons I'm considering a return line to the tank (New
ECi systems requires this). More flow of "cool" fuel
and an outlet for vapor.
Perhaps someone has or could build a table of fuel
temp, altitude and risk of vapor lock? anyone measure
fuel temps at the pump or ? I think the conclusion of
the Egg crowd was to minimize any obstructions before
the pump inlet (as this is usually at an even lower
pressure). They also added a bypass line to the fuel
rail to allow some fuel (or vapor) to bypass the
regulator. Weakness of an auto regulator is it will
hold vapor just as well as fuel at line pressure....
Car's solved this problem years ago - they put the
high pressure pump in the gas tank and also use a
check valve to maintain line pressure. This keeps line
pressurized even with high vapor pressure winter mix
in hot climates.
Petersen (sp?) has a number of STC's for GA auto fuel
and some systems don't qualify as the stock system is
judged marginal with 100LL. My cherokee 180 fits this
description. I recall if vapor lock is suspected the
recovery is to apply > 75% power, full rich, with cowl
vents open, etc. and level flight or decent as able,
etc. Idea is to get more "cool" fuel from the tank to
an engine set up for a configuration that has max air
cooling. Pulling power might makes things worse as
line pressure drops. Stock RV-10 config is low
pressure to the engine pump with a back up electric
(in a hot tunnel for some people)
There is a fuel temp where safe flight is not possible
- it would be good for the RV-10 crowd to work out
what that is and make sure there is a comfortable
margin.
Eric (40150)
--- David McNeill <dlm46007(at)cox.net> wrote:
[quote] I just ran the NTSB stats for the last two months.
RV10s.
rv10(at)sinkrate.com Guest
Posted: Mon May 08, 2006 10:05 pm Post subject: Off Field Landing |
When I test flew the 10 on April 21st and ordered my kit the guys at Van’s had just heard about it. Whoever’s plane it was called to order a new gear leg. Apparently that was the only part “tweaked” in the incident. I think they said it was one that was built by a guy in California and then sold? Tough to say if I have the story right cause I was still grinning from ear to ear after the “launch” off the runway in 410RV.
Ben Westfall
#40579 VS ready for rivets.
Robin
RV-6A 300 hours
RV-10 Tail Feathers
pilotdds(at)aol.com Guest
Posted: Tue May 09, 2006 7:43 am Post subject: Off Field Landing |
It was not me on the off field but I have been running mogas exclusively the last four hours.Would be concerned with vapor lock issues relative toflight conditions.
GRANSCOTT(at)aol.com Guest
Posted: Tue May 09, 2006 11:15 am Post subject: Off Field Landing |
In a message dated 5/9/06 2:07:32 A.M. Eastern Daylight Time, rv10(at)sinkrate.com writes:
| Quote: | | Tough to say if I have the story right cause I was still grinning from ear to ear after the œlaunch off the runway in 410RV |
So how many of us have logged time in 410 Romeo Victor?
Patrick
Tdawson(at)avidyne.com Guest
Posted: Tue May 09, 2006 11:27 am Post subject: Off Field Landing |
How many of us are almost done building and have never flown in a -10 at all? (Time for transition training!)
TDT
40025
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of GRANSCOTT(at)aol.com
Sent: Tuesday, May 09, 2006 3:11 PM
Subject: Re: Off Field Landing
Tough to say if I have the story right cause I was still grinning from ear to ear after the launch off the runway in 410RV |
Patrick
Posted: Tue May 09, 2006 11:50 am Post subject: Off Field Landing |
Other than a somewhat odd stall characteristic (somewhat sharpish break to the left and initial nose down, even with some hard right rudder peddle...and one could go into a stall spin from that point if you're not quick to recover or so it felt) compared to Cessna/Piper it handled like most planes I've flown...but very smooth and gentle in the flair, acceleration very good, good ground handling with a lively rudder instead of toe tappingas in a Tiger, the RV 10 rudder is more responsive IMHO that other castering nose wheel planes I've had the pleasure to fly. But this is only my impression as the flight was fairly short and so was ground handling but I'd give it very good marks, none the less.
Patrick
rvbuilder(at)sausen.net Guest
Posted: Tue May 09, 2006 1:09 pm Post subject: Off Field Landing |
I’m lucky as Alex Dominicis is sanctioned by Van, lives about 20 miles from me, AND he has air conditioning! Woo hoo! Of course not all insurance companies have sanctioned him yet. D’oh!
http://www.rvtraining.com/
Michael Sausen
RV-10 #352 Working on Fuselage
Recent RV-10 Build Activity
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Dawson-Townsend
Sent: Tuesday, May 09, 2006 2:27 PM
Subject: RE: Off Field Landing
TDT
40025
Patrick
10flyer(at)verizon.net Guest
Posted: Thu May 11, 2006 6:29 pm Post subject: Off Field Landing |
Just got home from a week long trip for work. Wasn't me, although I haven't been to my hangar to see if my airplane is still there!! Don't think it would have been Al Cook (my airport) as I don't think his fly-off hours are done yet. My last name is actually "Chamberlain" for who ever cares. Mark (N104ML)
Posted: Thu May 11, 2006 8:27 pm Post subject: Off Field Landing |
I heard through unnamed sources that it was an RV-10 involved in an off field landing near Paso Robles, CA. No injuries (except to a squirrel hole), some damage to wheel fairings and possibly a gear leg. Name of pilot not known as they are not affiliated with any list or group. Apparently, those involved in the investigation ( possibly Vans) are aware that we all want info about the cause as soon as it is available. At this point it sounds like it is engine related, not aircraft or system specific. I'm sure those involved will share any information with us should it be determined that the cause relates to the design or construction of the 10 or is operating specific to the 10. Mark.
