aileron push tubes
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV9-List
Peter Laurence
PostPosted: Mon May 08, 2006 7:21 am    Post subject: aileron push tubes Reply with quote
Question for those of you that have installed the Stick to aileron bellcrank
push tubes.
Did you cut them as per Van's measurments before installing. If so, were the
measurments correct or were you "VANdalized"?
Peter Laurence
9A fuse
- The Matronics RV9-List Email Forum -
http://www.matronics.com/Navigator?RV9-List
Neilekins(at)aol.com
PostPosted: Mon May 08, 2006 7:35 am    Post subject: aileron push tubes Reply with quote
I cut them as per plans. I would add 1/4 inch to them. I had just enough
length for minimum amount threads to screw in..That was after I put the proper
angle of deflection. You can check out my web site. neilsplane.com Im
building a lancair esp now...Neil
jc(at)INFONET.COM.BR
PostPosted: Mon May 08, 2006 8:15 am    Post subject: aileron push tubes Reply with quote
Ive cutted them by Vans manual with any problems. To centralize the sticks Ive got
some difficult. Some trials and errors using an plumb bob in both sticks. One hour job.
To install the washers between the sticks and bell crank it is etter to buy washer tool
at Avery.
PU-JCI
RV-9A
Flying 125 hs
JC - Aracaju - Brasil
websites.expercraft.com/jcmm
Peter Laurence
PostPosted: Mon May 08, 2006 9:31 am    Post subject: aileron push tubes Reply with quote
Thanks Neil
I'm from Tampsa. Where are you located/
Peter
(A fuse
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV9-List All times are GMT - 8 Hours
