M14PEngines-List Digest: 3 Msgs - 02/10/11
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List
sapril001(at)hotmail.com
PostPosted: Fri Feb 11, 2011 8:47 am    Post subject: M14PEngines-List Digest: 3 Msgs - 02/10/11 Reply with quote
Hi,
Thanks for the information, 2.5  X  the engine RPM.
I am using an Odyssey MGL EFIS , it can accept a variety of signal of many type, I am actually using a tacho generator 2 pole AC generator on the air starting distributor which is half the speed of the engine. it is to slow and I dont have a good steady reading below 1000 RPM. Also with a low frequency the Odyssey is slow to update the reading, I am told that it would be improved using a higher frequency.
My alternator is a Jasco 24V unit, I think the rotor have 6 poles, with a stator connection point I should get a good 3 voltage pulses per turn in regard to the engine ground, X 2.5 this will give me 7.5 pulses per engine turn. This should improve the low range and overall response of my readings.
Thanks again.
Sylvain
Murphy Moose.
> Date: Thu, 10 Feb 2011 23:57:01 -0800
To: m14pengines-list-digest(at)matronics.com
Subject: M14PEngines-List Digest: 3 Msgs - 02/10/11
Today's complete M14PEngines-List Digest can also be found in either of the
of the M14PEngines-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2011-02-10&Archive=M14PEngines
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2011-02-10&Archive=M14PEngines
M14PEngines-List Digest Archive
Total Messages Posted Thu 02/10/11: 3
Today's Message Index:
1. 08:42 AM - Re: M14PEngines-List Digest: 0 Msgs - 02/09/11 (Sylvain April)
2. 09:12 AM - Re: Re: M14PEngines-List Digest: 0 Msgs - 02/09/11 (A. Dennis Savarese)
3. 09:23 AM - Re: Re: M14PEngines-List Digest: 0 Msgs - 02/09/11 (Cliff Coy)
Time: 08:42:07 AM PST US
Subject: RE: M14PEngines-List Digest: 0 Msgs - 02/09/11
Hi everybody=2C
Please can anyone tell me the RPM of the alternator in regard with the engi
ne RPM on a M-14P. I need the frequency of the stator to use as a signal to
one EFIS for the engine RPM.
Sylvain
Murphy Moose.
> Date: Wed=2C 9 Feb 2011 23:57:07 -0800
> From: m14pengines-list(at)matronics.com
> Subject: M14PEngines-List Digest: 0 Msgs - 02/09/11
he
or
> HTML Version:
Chapter 11-02-09&Archive=M14PEngines
> Text Version:
> Total Messages Posted Wed 02/09/11: 0
Time: 09:12:31 AM PST US
From: "A. Dennis Savarese" <dsavarese0812(at)bellsouth.net>
Subject: Re: RE: M14PEngines-List Digest: 0 Msgs - 02/09/11
This may help. From the M14P manual.
> 1.2.13. Generator
> Designation ................................GSR-3000M, series 4
> Type ...................................... DC
> Number per engine ......................... 1
> Drive transmission ratio ................... 2.5
> Drive direction of rotation ................ LH
Dennis
On 2/10/2011 10:19 AM, Sylvain April wrote:
> Hi everybody,
> engine RPM on a M-14P. I need the frequency of the stator to use as a
> signal to one EFIS for the engine RPM.
> Thanks
> Sylvain
> Murphy Moose.
> > Date: Wed, 9 Feb 2011 23:57:07 -0800
> of the
> editor
> > HTML Version:
> http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 11-02-09&Archive=M14PEngines
> > Text Version:
> http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 11-02-09&Archive=M14PEngines
> &g======
Time: 09:23:44 AM PST US
Subject: Re: M14PEngines-List: RE: M14PEngines-List Digest: 0 Msgs - 02/09/11
*Interesting idea Sylvain!
The maintenance manual shows the drive ratio to be 2.5
Let me know how it goes....
Whose tach system uses the stator winding?
Cheers,
Cliff
On Thu, Feb 10, 2011 at 11:19, Sylvain April <sapril001(at)hotmail.com> wrote:
> Hi everybody,
> engine RPM on a M-14P. I need the frequency of the stator to use as a signal
> Thanks
> Sylvain
> Murphy Moose.
Clifford Coy
Border Air Ltd.
629 Airport Rd.
Swanton, VT 05488
802-868-2822 TEL
802-868-4465 FAX
Skyp=======================
&g=======
- The Matronics M14PEngines-List Email Forum -
http://www.matronics.com/Navigator?M14PEngines-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List All times are GMT - 8 Hours
