Dan.Beadle(at)hq.inclines Guest
Posted: Wed May 03, 2006 6:39 am Post subject: IO390 & Finishing Kit |
I am building an RV8 for use up in the mountains. Normally I would
turbocharge but that is not a simple option for the RV. So we have
decided to put in a larger engine and "de-rate" it for SL to 200 HP,
giving us a little more performance to cross the mountains at 16,000'.
=20
We have also decided to go light up front wherever possible to offset
the weight and moment of the bigger engine. These include:
=20
- Grove Landing gear (-18#, maybe some speed gain)
- Aerocomposite CS prop (-30#)
- James Cowl and Plenum (no change, but 10-15K speed gain)
- James Wheel Pants
- Rear battery
=20
Does anyone know the best way to order the finishing kit and avoid extra
parts from Vans? Do you have any recommendations for changes?
| - The Matronics RV8-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
LessDragProd(at)aol.com Guest
Posted: Wed May 03, 2006 7:10 am Post subject: IO390 & Finishing Kit |
Hi Dan,
IMHO, you'll need to add dual electronic ignition in place of the Mag's.
One of the Lycoming engineers told me that the 360 engine with a light
propeller brings the accessory case gear harmonics below the 2700 RPM level. It
doesn't damage the gears, but the Mag's and fuel pump don't last very long in
this environment. This could apply equally to the 390 engine with the light
propeller.
Jim Ayers
In a message dated 05/03/2006 7:40:48 AM Pacific Daylight Time,
Dan.Beadle(at)hq.inclinesoftworks.com writes:
<Dan.Beadle(at)hq.InclineSoftworks.com>
=20
=20
- James Wheel Pants
- Rear battery
=20
rv8ch
Posted: Wed May 03, 2006 7:12 am Post subject: IO390 & Finishing Kit |
Quote: | - Grove Landing gear (-18#, maybe some speed gain)
Quote: | Does anyone know the best way to order the finishing kit and avoid extra
I've got an article describing what you can leave out with
the Grove gear here:
http://www.rv8.ch/article.php?story=20040404153921362
While it won't save weight, you may want to ask Grove
about the single piece gear they offer for the RV8, but
didn't have on their website last time I checked.
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
_________________ Mickey Coggins
http://www.rv8.ch/ |
Posted: Wed May 03, 2006 7:30 am Post subject: IO390 & Finishing Kit |
Thanks. Which ignition do you recommend?
