Who sells 26 gage wire
Geoff Heap
PostPosted: Tue Aug 17, 2010 12:04 pm    Post subject: Who sells 26 gage wire Reply with quote
I've tried Assco, Wicks, B&C specialty and Radio shack. I can't believe I can't find some. I need maybe just one foot. It's for my Dynon ammeter shunt. They suggest using 26 gage to make fusible links for the two connections. It seems by far the simplest way to do it if I can find some............Geoff
longg(at)pjm.com
PostPosted: Tue Aug 17, 2010 12:40 pm    Post subject: Who sells 26 gage wire Reply with quote
Visit Uncle Ray
http://www.rayallencompany.com/products/accessories.html
Glenn E. Long
tomhanaway
PostPosted: Tue Aug 17, 2010 12:41 pm    Post subject: Who sells 26 gage wire Reply with quote
Geoff,
I have a spool of it. Send me your address and I'll put a few feet in an
envelope. tomhanaway***at***Comcast.net
Tom Hanaway
RV-10
Boynton Beach, FL
RV-10. Built and sold
RV-8a. Building
Gig Giacona
PostPosted: Tue Aug 17, 2010 12:49 pm    Post subject: Re: Who sells 26 gage wire Reply with quote
I couldn't find it either. I ended up with an inline fuse.
W.R. "Gig" Giacona
601XL Under Construction
PostPosted: Tue Aug 17, 2010 3:56 pm    Post subject: Who sells 26 gage wire Reply with quote
go up to 24awg and increase size of
lead wires to 20awg. Where did I call
out 26AWG? That's really hard to find
and I can't imagine calling it out.
That works too. But I need to fix the 26AWG callout.
rv10rob(at)gmail.com
PostPosted: Tue Aug 17, 2010 4:50 pm    Post subject: Who sells 26 gage wire Reply with quote
The "they" he refers to is Dynon.  Their harness is 22 AWG.
FWIW, I don't have any protection on mine.
On Tue, Aug 17, 2010 at 4:54 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
--> AeroElectric-List message posted by: "Geoff Heap" <stol10(at)comcast.net (stol10(at)comcast.net)>
st Un/Subscription,
www.matronics.com/Navigator?AeroElectric-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
ronics.com/" target="_blank">http://forums.matronics.com
Matt Dralle, List Admin.
Rob Kochman
RV-10 "Finishing" Kit
Woodinville, WA (near Seattle)
http://kochman.net/N819K
PostPosted: Tue Aug 17, 2010 11:46 pm    Post subject: Who sells 26 gage wire Reply with quote
Okay, use 3A in-line fuses or replace the
22AWG with 20AWG. The fuses are probably
'cleaner'.
Geoff Heap
PostPosted: Wed Aug 18, 2010 4:17 am    Post subject: Re: Who sells 26 gage wire Reply with quote
Correct. "They" are Dynon. Thank you for the advice. I think I prefer Bob's first suggestion. 20awg leads and 24awg for the link....Geoff
aerobubba(at)earthlink.ne
PostPosted: Wed Aug 18, 2010 4:28 am    Post subject: Who sells 26 gage wire Reply with quote
I also have some to share, but for those still wanting to purchase, try B&B
Aircraft Supply out in Gardner, KS. 913-884-5930. Dan is a great and
helpful guy, and what I have found is that whatever materials he has will
be about the best price you will find. 100 foot rolls of tefzel tend to
run $10...
Time: 01:08:31 PM PST US
Subject:
can't
They
seems
Glen Matejcek
aerobubba(at)earthlink.net
PostPosted: Wed Aug 18, 2010 7:01 am    Post subject: Who sells 26 gage wire Reply with quote
At 07:24 AM 8/18/2010, you wrote:
<aerobubba(at)earthlink.net>
run $10...
But 26AWG???? The smallest airframe wire in
general usage for about 70 years has been
22AWG. While 'oversized' for may electrical
situations, this was the smallest gage for
practical application in aircraft wire bundles
intended to be manipulated in the field by
humans with hand tools.
At Raytheon, we jumped into relatively uncharted
waters with Premier I in an effort to reduce
weight and called out a lot of 24AWG wire.
From a bundle assembly perspective, it was
no big deal. But on the assembly line and in
the field, we caught a lot of flak from
the folks who had to work with the stuff.
The complaints have died down . . . as they
will with time and experience but I'd venture
to assert that 24AWG is about the practical
limit for bundles assembled and maintained
with tools and techniques common to the
industry.
I added the fusible link kits to the AEC
catalog a few years back because 24AWG
wire was rarely found in the wilds of
an avionics or airframe repair shop. This
is probably still a relatively rare wire
size. I don't think M22759 even goes down
to 26AWG and the common catalogs like
http://aeroelectric.com/Mfgr_Data/Wire/Standard_Wire_and_Cable/Std_Wire_Cable.pdf
Don't offer it either.
So if it exists in somebody's wire harness,
it's an extra-ordinary material. If it
exists on somebody's drawings, it may be
a figment of their fondest wishes.
>Subject: AeroElectric-List:
>From: "Geoff Heap" <stol10(at)comcast.net>
can't
They
seems
Glen Matejcek
Checked by AVG - www.avg.com
08/17/10 13:35:00
PostPosted: Thu Aug 19, 2010 4:46 am    Post subject: Who sells 26 gage wire Reply with quote
Hi Bob-
22AWG.
Which makes 26 AWG perfect for a fusible link, no?
an avionics or airframe repair shop... ...So if it exists in somebody's
wire harness,
I believe at least some of B&B's business is surplus, and their 100' coils
for sale are pulled off of rather large spools. If I recall correctly, I
have about 99' 6" of the stuff left over...
Glen Matejcek
PostPosted: Thu Aug 19, 2010 12:41 pm    Post subject: Who sells 26 gage wire Reply with quote
Hi Bob-
>22AWG.
Sorta. It's making connections that are problematic.
We already doubled over 24AWG in the red-PIDG
terminals and the insulation grip may not
come down on 26AWG. This is why the shunt extensions
illustrated in the z-figures are electrically "oversized"
and the fusible links are "buffed up" with the
fiberglas sleeving.
I don't doubt that folks do have 26AWG wire
but I don't think it's 22759. It may be some
other, equally suitable wire but it's a good
thing to ask.
In the TC airframe business, smallest wires
are evaluated carefully both for electrical,
mechanical and handling qualities. Largest
wires are too . . . there are a number of
parallel conductors on airplanes to satisfy
electrical design goals for larger fat wires
when more strands of smaller wire were friendlier
to the factory floor and field mechanics.
If one can find the wire and is comfortable with
integrating it into the system . . . have at it!
