701 Top Window 7F19-1 bubble for more headroom
dons701
PostPosted: Wed Apr 28, 2010 5:37 am    Post subject: 701 Top Window 7F19-1 bubble for more headroom Reply with quote
Has anyone customized this top window to allow more headroom and seat cushioning ? I have seen few pictures of this window being bowed and wondered if there were any other customized or heat formed top windows out there. I am long in the torso and with very little seat cushioning for head clearance, It feels as though I'm sitting in a forty gallon trash can. The diagonal tube would then be the only obstruction for tall passengers, unless someone has modified this tube also. Pictures ??
Thanks, Don
Zenith 701 #76120
Jabiru 2200A #2456 95 hours
Sensenich Wood 64-PJ-36 Prop
Geoff Heap
PostPosted: Wed Apr 28, 2010 5:50 am    Post subject: Re: 701 Top Window 7F19-1 bubble for more headroom Reply with quote
Don. I started building from plans in 1991. Hope to be finished Late summer this year. My reason for mentioning this? In 19 years I have not heard of this top window being modified in any way. Maybe someone else has...Geoff
lvuman(at)gmail.com
PostPosted: Wed Apr 28, 2010 8:04 am    Post subject: 701 Top Window 7F19-1 bubble for more headroom Reply with quote
Hi Don,
I'm 6'2" and 205 lbs.  I heated the flaberon rod that is under the pilot seat and made a slight bow to it allowing the seatpan to conform to the new curve. Then I lowered the seatpan several inches.  I still have several inches of head room left with a dense cushion that is about 1.5 inches thick.   Jim
On Wed, Apr 28, 2010 at 7:37 AM, dons701 <burdon1(at)comcast.net (burdon1(at)comcast.net)> wrote:
[quote] --> Zenith701801-List message posted by: "dons701" <burdon1(at)comcast.net (burdon1(at)comcast.net)>
                                    Thanks, Don
Zenith 701 #76120
Jabiru 2200A #2456  67 hours
http://forums.matronics.com/viewtopic.php?p=296014#296014
-List" target="_blank">http://www.matronics.com/Navigator?Zenith701801-List
le, List Admin.
mcjon77
PostPosted: Wed Apr 28, 2010 7:36 pm    Post subject: Re: 701 Top Window 7F19-1 bubble for more headroom Reply with quote
IIRC, Mark Townsend mentioned this as one of the mods to make for a bigger guy to fly the 701 (the others being lowering the seat pan and moving the rudder pedals forward).
The 750 has this type of top window that is more bubble than flat. It is one of the reasons why there seems to be such a vast amount of additional headroom in the 750, as opposed to the 701.
If I build a 701, I will definitely do the same.
Jon McDonald
Building Sonex #1287
Next up CH 701 Very Happy
JohnDRead(at)aol.com
PostPosted: Thu Apr 29, 2010 4:52 am    Post subject: 701 Top Window 7F19-1 bubble for more headroom Reply with quote
Hello all;
 The 701 top window is bowed. The bow is controlled by the curve of the Diagonal Doubler 7F12-3. This part is crimped to curve it them trimmed and fitted to the diagonal tube of the cabin frame. Dimensions and details are shown on sheet 7-F-12. Hope this helps.
Regards, John
CH701 - Jabiru 3300 - Colorado
kmccune
PostPosted: Wed May 12, 2010 5:53 pm    Post subject: Re: 701 Top Window 7F19-1 bubble for more headroom Reply with quote
Yes they have.
Kevin
This is not mine, but it has or is being done. My take is for more lift rather thin head room. But to each their own.
 Filesize:  2.02 MB
 Viewed:  8539 Time(s)
“Always do what you are afraid to do.�
R.W. Emerson (1803-1882)
Dorothy McCune
dons701
PostPosted: Wed May 12, 2010 8:53 pm    Post subject: Re: 701 Top Window 7F19-1 bubble for more headroom Reply with quote
Hi Kevin, I was thinking along the same lines, more head room and to carry the curvature of the windshield through the top panel. My concerns were to not disrupt the prop blast to the tail too much and possibly add more to the wing area. Thanks for the picture
Zenith 701 #76120
