Posted: Sat Apr 03, 2010 2:49 pm Post subject: fuel-safe "grease" for Viton o-rings |
I'm mounting fitting adapters on my Andair gascolator and they seal to the body with Viton o-rings. I'd like to replenish the film of grease on the o-rings and am wondering what kind of grease to use. Searching on the web indicates that silicon grease can be used on Viton o-rings but it is not clear if the grease is fuel-proof. I'll send a query to Andair on Monday but I was wondering if anyone had any advice. If there is a recommended product a source would be useful too.
-- Craig
Z601c(at)anemicaardvark.c Guest
Posted: Sat Apr 03, 2010 3:32 pm Post subject: fuel-safe "grease" for Viton o-rings |
I'm not certain about gas slowly removing it, but I can tell you that the only
thing I was ever intentionally able to remove silicon grease with was MEK.
On Saturday 03 April 2010 17:48:46 you wrote:
| Quote: | I'm mounting fitting adapters on my Andair gascolator and they seal to the
-- Craig
Jim B. Belcher
BS,MS Physics
A&P/IA
General Radio Telephone Certificate
Instrument Rated Pilot
Retired Aerospace Technical Manager
Semi-proficient Househusband
Terry Phillips
Joined: 11 Jan 2006 Posts: 346 Location: Corvallis, MT
Posted: Sat Apr 03, 2010 9:20 pm Post subject: fuel-safe "grease" for Viton o-rings |
Craig
My memories from years in the lab and industry is that Viton is the el primo elastomer. It is a fluropolymer, like a rubbery teflon, and it is impervious to most solvents. I cannot imagine that silicone grease would cause any problem. My home water filter has common neoprene or whatever O-rings and they recommend silicone grease for them. However for my fuel system fittings, I'm planning on use EZ-Turn which is supposed to be fuel resistant. EZ-Turn might be a good choice for your O-rings.
Terry
At 03:48 PM 4/3/2010 -0700, you wrote:
| Quote: | I'm mounting fitting adapters on my Andair gascolator and they seal to the body with Viton o-rings. I'd like to replenish the film of grease on the o-rings and am wondering what kind of grease to use. Searching on the web indicates that silicon grease can be used on Viton o-rings but it is not clear if the grease is fuel-proof. I'll send a query to Andair on Monday but I was wondering if anyone had any advice. If there is a recommended product a source would be useful too.
-- Craig |
Terry Phillips
ttp44~at~rkymtn.net
Corvallis MT
ZU-601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail & flaps are done;
Upgrading my wings & flaps per the AMD Safety Directive
http://www.mykitlog.com/N47TP/ [quote][b]
_________________ Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings. |
Posted: Sat Apr 03, 2010 9:38 pm Post subject: fuel-safe "grease" for Viton o-rings |
I'm using EZ-Turn on my metal-to-metal pipe thread fittings. But I think part of the purpose of the existing grease on the o-rings is just that: to grease the parts to allow them to slide together without pinching the o-ring. EZ-Turns is great stuff but is very sticky and doesn't strike me as a very good grease. Anyway I'll give Andair a chance to reply next week.
-- Craig
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Terry Phillips
Sent: Saturday, April 03, 2010 10:18 PM
Subject: Re: fuel-safe "grease" for Viton o-rings
Craig
Terry
-- Craig |
Terry Phillips
ttp44~at~rkymtn.net
Corvallis MT
href="http://www.matronics.com/Navigator?Zenith-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
flyadive(at)gmail.com Guest
Posted: Sun Apr 04, 2010 5:30 am Post subject: fuel-safe "grease" for Viton o-rings |
Craig:
Viton & Buna -N are very similar to each other with Viton have a
ability to hold up against radiation.
I don't think your plane runs off of nuclear enegery yet
There are two lubes that can be used VERY successfully and EVERYONE
that has a fuel selector should
have one in their took box - Parker Lube <--- VERY EXPENSIVE and I
stay away from ANYTHING
Parker - Hanifin makes, produces, sells or distributes. The other is
EZ-Turn which is FANTASTIC stuff
and very reasionable ($12) a 5 oz tube will last you for years.
When you touch it you will swear this stuff is like rubber cement.
But once applied you will love the feel
and action of the turning qualities.
PLEASE refrain from using it as a sex jell.
Barry
On Sat, Apr 3, 2010 at 6:48 PM, Craig Payne <craig(at)craigandjean.com> wrote:
-- Craig
goodings(at)yorku.ca Guest
Posted: Mon Apr 05, 2010 6:57 am Post subject: Fuel-safe "grease" for Viton O-rings |
Craig and Barry:
"Viton & Buna-N are very similar to each other . . ." This is NOT true,
in my opinion. Viton is much more inert (and much more expensive). Also,
I think that silicone grease is fuel-resistant. But, TRY IT. Stick some
silicone grease on a stick or whatever, and swish it around a lot in
gasoline (with or without ethanol additive). I don't think it dissolves
very much at all.
John Goodings, C-FGPJ, CH601HD with R912S, Carp/Ottawa/Toronto.
Posted: Mon Apr 05, 2010 1:46 pm Post subject: Fuel-safe "grease" for Viton O-rings |
John:
The term INERT does not fit into the description of these O rings.
Inert is a one word description of something that is non-reactive with
oxygen. As for expensive YES it is, but purchasing an O ring is not
the issue (Come On... $0.50 Vs $0.20), since the O Ring is supplied
with the unit.
And, your "opinion"... Nor mine matter, when it come to physics and
chemistry. It is the function of the material for this operation and
others that takes precedence. Also consult a chemical reactivity
chart for Viton, Buna-N and Neoprene the differences will become
apparent. Yet when compared against GAS and especially MoGas Neoprene
takes the hit.
I do not know what is in EZ Turn but it is both fuel resistant and
slippery and ... Even though it does not matter to many home builders,
it is even FAA acceptable. GEE! I wonder what the manufacture
recommends? Since the manufacture requirements must meet or exceed
FAA requirements AND the manufacture sets the preference. This part
of aircraft building is really an oxymoron. The manufacture sets the
requirements yet the FAA controls the requirements, or something to
that effect. Sort of the fox watching the hen house?
Barry
On Mon, Apr 5, 2010 at 10:56 AM, John Goodings <goodings(at)yorku.ca> wrote:
Craig and Barry:
"Viton & Buna-N are very similar to each other . . ." This is NOT true, in
my opinion. Viton is much more inert (and much more expensive). Also, I
very much at all.
Posted: Mon Apr 05, 2010 2:15 pm Post subject: Fuel-safe "grease" for Viton O-rings |
I haven't heard back from Andair yet. But on a small piece of paper that
came with the fittings they say "use any light grease. Looking at the design
the grease is there to ease assembly (so the o-ring isn't pinched or
damaged). But ultimately the o-ring seals the joint.
BTW: these are the adapters I am talking about. Although the pictures below
don't show it the backside of these adapters have a raised shoulder and an
o-ring which seals into a circular depression on the main body:
http://www.andair.co.uk/pix/accessories/MF25.jpg
http://www.andair.co.uk/pix/accessories/FF25.jpg
-- Craig
Posted: Tue Apr 06, 2010 5:59 am Post subject: Fuel-safe "grease" for Viton O-rings |
Barry and Craig:
"The term INERT does not fit into the description of these O rings. Inert
is a one word description of something that is non-reactive with oxygen. .
. ." Not true. INERT, to a chemist, simply means unreactive to a wide
variety of substances, not simply oxygen. This is true of Viton; in my
experience, it is unreactive to a wide variety of substances, certainly in
a laboratory context. Personally, I should have no hesitation in using a
Viton O-ring smeared with a silicone grease in the presence of fuel, both
Avgas and Mogas (with or without ethanol additive). I think this is what
the original question was about.
John Goodings, C-FGPJ, CH601HD with R912S, Carp/Ottawa/Toronto,
Professor Emeritus of Chemistry.
moorecomp
Posted: Thu Apr 08, 2010 7:58 am Post subject: Re: fuel-safe |
The EZ Turn is to lubricate the valve itself. The use of simple petrolatum (petroleum jelly) is commonly approved by almost all engine manufacturers for o-ring lubrication in oil and fuel systems.
C. Moore
A&P
Mancelona, MI
