RPM pickup and CHT/EGT probes
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List
jbuseman
PostPosted: Sun Feb 28, 2010 3:26 pm    Post subject: RPM pickup and CHT/EGT probes Reply with quote
Hi, what is the best way to get tach information to an EFIS display? Would it be from the P-Lead off the ignition switch or does someone manufacture a device that can convert the info from the tach cable and send it electronically to the EFIS system? Also if you had up to 14 probes that could be used what would the ideal setup as far as number of EGT's, CHT's and their location. Thanks
- The Matronics M14PEngines-List Email Forum -
http://www.matronics.com/Navigator?M14PEngines-List
n35dy(at)bellsouth.net
PostPosted: Sun Feb 28, 2010 4:59 pm    Post subject: RPM pickup and CHT/EGT probes Reply with quote
Hi Joel
I used the GRT EFIS and really like the thing. I picked up the tach signal at the mag switches and ran each into a switch that selects L or R to send back up front to the forward (master) EFIS box. As I recall, GRT gives you a resistor to put in line with the signal from the mag.
For the temp senders, I am looking at all 9 EGT and 3 CHT. I wired senders for all 9 CHT because GRT told me 2 years ago that they were upping the channels to the EFIS to handle 9 + 9 from a radial. Still waiting for them to come through with that mod but don't really care if they don't. 3 CHT's seem like enough and they all run about the same. Having all the EGT's is good for knowing exactly what is going on with each cyl and for IDing where a fouled plug or ign wire might be.
Dan
N12DY
dsavarese0812(at)bellsout
PostPosted: Mon Mar 01, 2010 5:12 am    Post subject: RPM pickup and CHT/EGT probes Reply with quote
From the p-lead off the ignition switch.
Dennis
jbuseman
PostPosted: Mon Mar 01, 2010 9:05 am    Post subject: RPM pickup and CHT/EGT probes Reply with quote
Thanks for the info. What type of CHT fitting do I need?
From: A. Dennis Savarese <dsavarese0812(at)bellsouth.net>
To: m14pengines-list(at)matronics.com
Sent: Mon, March 1, 2010 8:09:52 AM
Subject: Re: M14PEngines-List: RPM pickup and CHT/EGT probes
Dennis
PostPosted: Tue Mar 02, 2010 5:54 am    Post subject: RPM pickup and CHT/EGT probes Reply with quote
The CHT probes are placed under the spark plugs much like a spark plug copper gasket.
Dennis
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List All times are GMT - 8 Hours
