Oil
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List
HBaker
PostPosted: Fri Feb 12, 2010 4:04 pm    Post subject: Oil Reply with quote
What is the min/max amount of oil that you operate the M 14 I know the reservoir holds 14 quarts The engine start time is soon at hand !!
Henry Moose 294
- The Matronics M14PEngines-List Email Forum -
http://www.matronics.com/Navigator?M14PEngines-List
Currently building a Murphy Moose - any help would be appreciated.
dsavarese0812(at)bellsout
PostPosted: Fri Feb 12, 2010 6:20 pm    Post subject: Oil Reply with quote
Typically, 10-12 liters/quarts. If you put in 14 liters/quarts in the tank after an oil change, you will end up with about 12 - 12.5 liters/quarts after the engine has been run.
Dennis
william(at)netpros.net
PostPosted: Fri Feb 12, 2010 7:41 pm    Post subject: Oil Reply with quote
Pretty sure the Min line on my dip stick is at 9 litres. I'll check tomorrow.
PostPosted: Fri Feb 12, 2010 7:48 pm    Post subject: Oil Reply with quote
On the 52 the min line is 8 liters.
Dennis
PostPosted: Fri Feb 12, 2010 8:17 pm    Post subject: Oil Reply with quote
Should have added: I have a Yak-55
.. will check over the weekend ...
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List All times are GMT - 8 Hours
