m14p to 14pf
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List
jimshaner(at)msn.com
PostPosted: Tue Feb 02, 2010 2:11 pm    Post subject: m14p to 14pf Reply with quote
Is there any external visual indication that a 14p has been converted to a pf?  Logbook does not have any such entry but engine gets 410hp on a dyno....
Jim Shaner
- The Matronics M14PEngines-List Email Forum -
http://www.matronics.com/Navigator?M14PEngines-List
Rhonda(at)bpaengines.com
PostPosted: Tue Feb 02, 2010 2:15 pm    Post subject: m14p to 14pf Reply with quote
Whose dyno?
From: owner-m14pengines-list-server(at)matronics.com [mailto:owner-m14pengines-list-server(at)matronics.com] On Behalf Of james shaner
Sent: Tuesday, February 02, 2010 4:12 PM
To: m14pengines-list(at)matronics.com
Subject: m14p to 14pf
Jim Shaner
dsavarese0812(at)bellsout
PostPosted: Tue Feb 02, 2010 2:20 pm    Post subject: m14p to 14pf Reply with quote
Yes, whose dyno? The external physical indication is the manifold pressure will be about 40" or so. A stock M14P develops about 35" of manifold pressure.
Dennis
george(at)gesoco.com
PostPosted: Tue Feb 02, 2010 2:24 pm    Post subject: m14p to 14pf Reply with quote
No there is no external indication other than the data plate. If it was converted from a “P” to a “PF” or was built originally as a “PF” it should be stamped on the data plate. The log book should also show the model number. Engine test page should also show the higher HP.
George Coy
CAS Ltd.
714 Airport Rd.
Swanton VT 05488
802-868-5633 off
802-363-5782 cell
george.coy(at)gmail.com (george.coy(at)gmail.com)
http://coyafct.com/
SKYPE george.coy
Sent: Tuesday, February 02, 2010 5:12 PM
Jim Shaner
PostPosted: Tue Feb 02, 2010 2:41 pm    Post subject: m14p to 14pf Reply with quote
Hi George:
Your information is true if it has been done at the factory. But, we did recently had an M14 here that had been converted to a PF “in the field” with no log book entry as to the conversion at all. It was converted back to a P after the supercharger failed. Unless it was done by the factory or somewhere like Termikas, I don’t think there’s anyone running them on a dyno . . . . yet!
[i]Rhonda Barrett-Bewley[/i]
[i]Barrett Precision Engines, Inc.[/i]
From: owner-m14pengines-list-server(at)matronics.com [mailto:owner-m14pengines-list-server(at)matronics.com] On Behalf Of George Coy
Sent: Tuesday, February 02, 2010 4:24 PM
Subject: RE: M14PEngines-List: m14p to 14pf
George Coy
CAS Ltd.
714 Airport Rd.
Swanton VT 05488
802-868-5633 off
802-363-5782 cell
http://coyafct.com/
SKYPE george.coy
Jim Shaner
http://forums.matronics.com
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List All times are GMT - 8 Hours
