gengrumpy(at)aol.com Guest
Posted: Sun Nov 22, 2009 6:50 pm Post subject: inner tubes |
Has anyone found a stop leak inner tube for the main gear with a 90
degree valve stem?
Grumpy
N184JM
partner14
Posted: Sun Nov 22, 2009 7:18 pm Post subject: inner tubes |
From the people I've talked to, with a stop leak type tube, don't worry about the stem.... you don't have to mess with air pressure but twice a year.... when the weather changes from hot to cold, and cold to hot.... and by then you should ck out your brakes anyway.
Don McDonald
--- On Sun, 11/22/09, Miller John <gengrumpy(at)aol.com> wrote:
Subject: inner tubes
Date: Sunday, November 22, 2009, 6:48 PM
--> RV10-List message posted by: Miller John <gengrumpy(at)aol.com (gengrumpy(at)aol.com)>
Has anyone found a stop leak inner tube for the main gear with a 90 degree val= the Contribution link below to find out more about
f="http://www.matronics.com/contribution" target=_blank>http://www.matr -Mat href="http://www.matronics.com/Navigator?RV10-List" target=_blank>httphttp://forums.matronics.com/" target=_blank>http://forums.matronics.com</================
40636 |
Eric_Kallio
Joined: 29 Jan 2006 Posts: 149 Location: Baton Rouge, LA
Posted: Mon Nov 23, 2009 4:45 am Post subject: Re: inner tubes |
I was able to get some from Desser tires about 4 months ago (http://desser.com/). I have heard, but not confirmed they aren't stocking them anymore, but worth a shot.
Eric Kallio
40518 waiting for engine and prepping panel
