Door locked inflight by pip-pins.
raimo.toivio(at)rwm.fi
PostPosted: Wed Nov 18, 2009 2:19 am    Post subject: Door locked inflight by pip-pins. Reply with quote
"Are you serious ? In an accident, how would a potential rescuer get the doors open ?"
Karl,
I understand your point but I have thought it very carefully and I am very serious and happy with my always locked doors when inflight (I have pip-pins both side)!
The risks of the unlocked doors when inflight are heavier than the risks of the pip-pin locked doors when crash landed.
Consider this:
1) An unthinking passenger can easily lift the lever and ask "what is this?". Shit happens, really.
The pip pin prevents accidents like this - a pilot has more time to react and say no no no.
The function of the pip-pin is in this case to be a retarder!
2) Pilots´s or co-pilot´s sleeve could easily lift the lever by accident - pip pin prevents this.
The guard alone is good but not 100% guaranteed. The function of the pip-pin is in this case to be a safety catch.
3) Passenger side´s pip-pin is a good, simple and effective door lock when grounded.
The function of the pip-pin is in this case to be just a lock.
4) I have in my POH: before emergency landing remove door pip-pins.
5) In the case of emergency landing and the doors are still locked: do you really think it is difficult to open the door? Just kick the window and it is gone, surely! For "potential rescuer" it is not a problem at all! It is the smallest worry in this case! Those pip-pins are clearly visible and understandable.
BTW both of the C172´s doors are inflight lockable. I know some people lock them and some do not. I locked them always when flying but that was for personal comfort only. When locked the lever was levelled and the armrest was usable. I am not sure what do they say in Cessnas POH - my guess is "do open the door locks before landing".
Karl, do you accept my (serious) points?
Would you like to see the pick of my pip-pin equipped door lever guards?
Raimo OH-XRT
avi8ordave(at)YAHOO.COM
PostPosted: Wed Nov 18, 2009 5:04 am    Post subject: Door locked inflight by pip-pins. Reply with quote
Gentlemen,
I don't want to add to controversy, but...
I have independently come to the conclusion of using pip pins... actually the little red spring loaded ones from the Andair fuel selectors.
Loosing a door in flight is Bad - Bad - Bad!
External Placcards describing how to open the door, and glider window vents allow access to the internal locking mechanism when on the ground. Gliders don't have external door handles... there is no reason our Europas need external door handles either.
Dave Conrad
A078, Monowheel
914, short and long wings
Building
--- On Wed, 11/18/09, Raimo Toivio <raimo.toivio(at)rwm.fi> wrote:
Subject: Europa-List: Door locked inflight by pip-pins.
Date: Wednesday, November 18, 2009, 5:20 AM
#yiv442352437 hmmessage P { PADDING-RIGHT:0px;PADDING-LEFT:0px;PADDING-BOTTOM:0px;MARGIN:0px;PADDING-TOP:0px;} #yiv442352437 { FONT-SIZE:10pt;FONT-FAMILY:Verdana;} "Are you serious ? In an accident, how would a potential rescuer get the doors open ?"
Karl,
Consider this:
Raimo OH-XRT
* The Builder's Bookstore http://www.matronics.com/co=============
[/b]
[/quote]
rampil
PostPosted: Wed Nov 18, 2009 7:08 am    Post subject: Re: Door locked inflight by pip-pins. Reply with quote
"Loss of door in flight is Bad Bad Bad"
Just to throw a few facts into the mix:
There are a number of cases now, including the Florida factory
demonstrator.
It is embarrassing, It is expensive, It creates a lot of air noise.
It does not impact flight characteristics. The door has not yet
ever hit the empennage. The plane has been flown intentionally
without doors.
Door loss is considered an incident, not accident and so are not
reported to the NTSB.
The factory design is better than you give credit for.
In many countries experimental aircraft builders have freedom to
experiment. There are three rules worth considering:
1: Everything is a tradeoff, a balance of risk and benefit.
2: There are always unintended consequences.
3:(my favorite, direct from B. Rutan): When considering a new
device for an aircraft, place the device in your palm, then
accelerate, said device skyward greater than 1g. If the device
returns to earth, do not install it, it is clearly too heavy!
Ira N224XS
kheindl(at)msn.com
PostPosted: Wed Nov 18, 2009 7:14 am    Post subject: Door locked inflight by pip-pins. Reply with quote
Raimo C
Yes C I accept your reasoning C and I am surprised to read that Cessnas have internal locks. Their checklists probably say to not have them locked on takeoff and landing. My PFA inspector would not have approved the mod C although C my passenger door does have a pip pin lock for locking on the ground only. Of course C if I were to end up inverted C which is very likely in a trigear C in an otherwise successful emergency landing C it wouldn't make any difference whether doors were locked or not C as the doors couldn't be opened anyway C except with brute force. I keep meaning to get one of those emergency exit hammers just for that nightmare situation C and to reroute the fuel vent to the bottom of the fuselage.
Regarding CO alarms C I can only recommend one which shows any presence of the gas in ppm C and with a high pitched alarm when a safe figure and/or duration is exceeded. You can get them in any hardware store.
I had a case not long ago C when a loose exhaust pipe caused some carbon monoxide to leak into the cabin. On the other hand C it also confirmed that fumes which sometimes enter via the flap slots on landing did not register on the instrument.
Karl
Date: Wed C 18 Nov 2009 12:20:53 +0200
.ExternalClass ecxhmmessage P {padding-right:0px;padding-left:0px;padding-bottom:0px;padding-top:0px;} .ExternalClass BODY.ecxhmmessage {font-size:10pt;font-family:Verdana;} "Are you serious ? In an accident C how would a potential rescuer get the doors open ?"
Karl C
Consider this:
1) An unthinking passenger can easily lift the lever and ask "what is this?". Shit happens C really.
3) Passenger side´s pip-pin is a good C simple and effective door lock when grounded.
5) In the case of emergency landing and the doors are still locked: do you really think it is difficult to open the door? Just kick the window and it is gone C surely! For "potential rescuer" it is not a problem at all! It is the smallest worry in this case! Those pip-pins are clearly visible and understandable.
Karl C do you accept my (serious) points?
Raimo OH-XRT
lectric.com
/">www.buildersbooks.com
ebuilthelp.com
ww.matronics.com/contribution
ronics.com
peterz(at)zutrasoft.com
PostPosted: Wed Nov 18, 2009 7:47 am    Post subject: Door locked inflight by pip-pins. Reply with quote
"Of course, if I were to end up inverted, which is very likely in a trigear, in an otherwise successful emergency landing, it wouldn't make any difference whether doors were locked or not, as the doors couldn't be opened anyway, except with brute force. I keep meaning to get one of those emergency exit hammers just for that nightmare situation"
FWIW,
I am planning on installing releasable-hinge pins for the doors....  all attached to a single emergency pull handle via thin/light cables, which will simply pull all the hinge pins out, allowing for the door to more easily pushed out sideways (the strut would still attach them somewhat).
Pete
A239
pete(at)lawless.info
PostPosted: Wed Nov 18, 2009 7:53 am    Post subject: Door locked inflight by pip-pins. Reply with quote
Hi
Just checked the 172R manual from Feb 2000.  The internal door handle has 3 positions – open, close and lock.  The check list calls for doors to be locked prior to flight.  The forced lading check list calls for ‘doors to be unlatched prior to touch down’.
It all adds an interesting extra task at 100 feet after take off when it all goes quiet!
Pete
kheindl(at)msn.com
PostPosted: Wed Nov 18, 2009 8:49 am    Post subject: Door locked inflight by pip-pins. Reply with quote
FWIW C
I am planning on installing releasable-hinge pins for the doors.....  all attached to a single emergency pull handle via thin/light cables C which will simply pull all the hinge pins out C allowing for the door to more easily pushed out sideways (the strut would still attach them somewhat).
Pete C
A very nice idea. When you get it done C I would like to copy it. An individual quick release on each hinge would be adequate for me. [quote]
lectric.com
ebuilthelp.com
ronics.com
PostPosted: Wed Nov 18, 2009 10:12 am    Post subject: Door locked inflight by pip-pins. Reply with quote
Karl,
I checked today Cessna 182 P Skyline´s 1976 POH and there on the page 4-5 they say (check list before take off): " doors and windows must be closed and locked".
Otherwise there would be no reason for internal lock for both doors.
Just wonder that because Cessna´s open cannot open totally during flight because of airflow.
Once it opened slightly during my flight because it was unlocked. That was a passenger side. It was open a little and there was a cap one or two inches. My passenger - my wife actually - did not like that semi-open-door flight at all.
On the page 3-5 (emergency landing instructions) they say "unlock the doors just before touching the ground (!)".
Raimo OH-XRT
PostPosted: Wed Nov 18, 2009 11:33 am    Post subject: Door locked inflight by pip-pins. Reply with quote
All,
so many of you have asked me to show my door security pip-pins that here they are.
Pip-pin connects the guard and the lever together.
Pip-pin has a safety lanyard.
Placards:
1) "do not open during flight" (both sides)
2) "open" with an arrow (both sides)
3) "Warning! Only the pilot is allowed to open - close - lock the door" (passenger side only!).
Last notice is because of security and partly because I do not like an idea to repair the internal parts of the door after somebody has locked it using unnecessary extra force.
They work fine and I feel good with them. I could not imagine possibility to fly without them.
Nice to be with you - Mr. Dave Conrad - in a same club flying with "locked" eh retarded doors...
Raimo OH-XRT
(flying with pip-pinned doors)
 Filesize:  26.14 KB
 Viewed:  10678 Time(s)
 Filesize:  49.86 KB
rampil
PostPosted: Wed Nov 18, 2009 11:56 am    Post subject: Re: Door locked inflight by pip-pins. Reply with quote
Re internal quick-release hinges for door
Hi Peter,
Are you accounting for the compression/tension of the upper door as an
important structural member of the fuselage. It is my recollection that
the upper hinges and door frame are structural, not ornamental. I have
not done a FEA of the Europa but just looking suggests that the cockpit
roof and door members are in tension holding the fuselage from folding
down during flight.
Before committing to a change in aircraft structure, I'd really suggest
that you check with Andy, Dave, or Bud.
Good Luck,
Ira
Ira N224XS
PostPosted: Wed Nov 18, 2009 2:17 pm    Post subject: Door locked inflight by pip-pins. Reply with quote
Hi Ira,
Valid points, but I am not proposing any structural modifications whatsoever - just simply making the *existing* hinge pins removable (tho still captured for normal use) and pulling them out of the hinges in an emergency via thin cables attached to an 'emergency' hanle which would be recessed and ornamentally covered to avoid inadvertently pulling it (during one of those "what's that" passenger mements).
Shouldn't weigh more than a few 10s of grams either. Well worth the capability to exit when upside down.
...but thinking further - you mean I shouldn't plan on flying my long wings with the doors and engine off?  That would have given it a real hang-glider feel Wink
Cheers & thx,
Pete
A239
On Wed, Nov 18, 2009 at 2:56 PM, rampil <ira.rampil(at)gmail.com (ira.rampil(at)gmail.com)> wrote:
[quote]--> Europa-List message posted by: "rampil" <ira.rampil(at)gmail.com (ira.rampil(at)gmail.com)>
Hi Peter,
down during flight.
Good Luck,
Ira
Ira N224XS
http://forums.matronics.com/viewtopic.php?p=273589#273589
-=     * AeroElectric www.aeroelectric.com
omebuiltHELP www.homebuilthelp.com
http:/r generous support!
ronics List Features Navigator to browse
s.com/Navigator?Europa-List" target="_blank">http://www.matronics.com/Navigator?Europa-List
ronics.com/" target="_blank">http://forums.matronics.com
frans(at)paardnatuurlijk.
PostPosted: Wed Nov 18, 2009 2:49 pm    Post subject: Door locked inflight by pip-pins. Reply with quote
Karl Heindl wrote:
Pete,
A very nice idea. When you get it done, I would like to copy it. An
Count me in as well.
Frans
PostPosted: Wed Nov 18, 2009 2:50 pm    Post subject: Door locked inflight by pip-pins. Reply with quote
I think I have read somewhere that the Europa was intended to be
"convertible", i.e. that it should be possible to fly it without doors.
Ok, nobody seems to like it, but the design is there. Apart from that, I
highy doubt that the door could serve as a structural member given the
fact that the hinges are very weak.
Frans
rampil
PostPosted: Thu Nov 19, 2009 8:16 am    Post subject: Re: Door locked inflight by pip-pins. Reply with quote
Hi Franz,
Yes, I know the hinges are weak from the personal experience of
having my open port door blow off the aircraft in a gust of wind
over 40 kts while on the ground, refueling at Norfolk (after business
hours of course) returning home from Sun n Fun 2006.
That is weakness in the open/close axis of the hinge, the structure
relies on the fore/aft axis to add parallel stiffening and tension
path to the roof.
Ira
Ira N224XS
ptag.dev(at)tiscali.co.uk
PostPosted: Thu Nov 19, 2009 9:10 am    Post subject: Door locked inflight by pip-pins. Reply with quote
Hi! I was to understand when Europa took some aerial photos of G-PTAG over
Stauning I had to fly no more than 110kts since they had their door off.
At least the passenger side did!
The only "convertible" that I knew off was the fact that G-PTAG was built to
be easily converted to a monowheel should I ever decide. I actually have
photos of three MAIN WHEELS fitted simultaneously!
Bob Harrison.
