nuckollsr(at)cox.net Guest
Posted: Wed Apr 05, 2006 5:18 pm Post subject: D-sub pins for low bulk splicing |
At 08:22 PM 4/5/2006 -0400, you wrote:
Quote: |
Listers,
Anything wrong with using machined pins for splicing 20-22AWG wires with a
heatshrink cover? Just seems neater and quicker than soldering or butt
splices..
Obviously the "weak" link is that heatshrink offers less grip on
the pins than do connector bodies . . . but it is surprisingly high.
I just tried it with some clear heatshrink and found that tension
on the wires stretched the shrink and the pins did
not slide inside the heatshrink. I put several pounds
of pull on it causing the pins to disengage slightly but when
I relaxed the pull, the shrink slowly returned to original
length and full engagement of the pins.
Do some experimenting with the materials you have. Odds are
it will be fine.
< What is so wonderful about scientific truth...is that >
< the authority which determines whether there can be >
< debate or not does not reside in some fraternity of >
< scientists; nor is it divine. The authority rests >
< with experiment. >
< --Lawrence M. Krauss >
