rv8ch
Posted: Sat Apr 01, 2006 6:35 am Post subject: power for headsets |
I'm about to install the headset and mic jacks, and I'm
wondering if there is an "industry standard" way to
provide power for ANR type headsets. I've got the
Bose, and they want USD 31 for a special jack, and
USD 195 for the new headset cord. That would buy
a lot of batteries.
Is there a better way?
Thanks!
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
_________________ Mickey Coggins
http://www.rv8.ch/ |
aadamson(at)highrf.com Guest
Posted: Sat Apr 01, 2006 7:27 am Post subject: power for headsets |
Mickey,
I sourced the "jacks" from the manufacturer a few years ago and bought a
couple for a Cessna 172. The jacks alone were as much as the $31 kits from
ACS. My vote is to use an "inline" fuse and get the jacks and wiring
harnesses all made up from ACS - they are $31 and that may be the price you
mentioned? In the long run, that is the cheapest way to go.
My .02,
Alan
rv8ch
Posted: Sat Apr 01, 2006 8:34 am Post subject: power for headsets |
Quote: | I sourced the "jacks" from the manufacturer a few years ago and bought a
Hi Alan,
Thanks for the info. I'm a bit confused. From what I understand,
I need to modify my current headsets, which have the standard jacks
and the AA battery pack, to use a different cable, which is USD 195,
or USD 164 (can't tell which) and I need to buy two USD 31
installation kits for the aircraft.
http://www.aircraftspruce.com/catalog/avpages/bosehdst.php
After I've done this, I think my aircraft jacks will only work
with Bose headsets.
I am curious if there is a more "generic" way to get power to
ANR headsets, since I may experiment with other types of headsets
down the road, and I don't want to have a "bose only" installation.
Also, the investment seems to be substantial. I can't see myself
paying USD 200 to replace a few AA batteries.
Mickey
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
BobsV35B(at)aol.com Guest
Posted: Sat Apr 01, 2006 9:15 am Post subject: power for headsets |
Good Morning Mickey,
I went through that exercise a couple of years ago and I did install Bose
jacks and used the Bose interface cord.
I think I made a mistake.
Now, I can only use my Bose headsets in the airplane that has the special
Bose Jacks.
Our number one son decided to live with batteries so that he could use his
Bose headsets in any airplane desired. Works fine for him. The Bose X
headsets automatically shut of the power if the unit is not used so the batteries do
last a long time
A very close friend had another idea.
He made a small plastic device that fit in the Bose battery compartment and
picked up the connection to the battery terminals. From that he extended a
cord that fit in a small two and half or three and a half millimeter power
receptacle. When he wanted to use the Bose headsets in his airplane he used his
homemade attachment to provide power from the aircraft system. For use in other
airplanes, he just stuck in the batteries.
I believe my friend's solution is the most elegant of all!
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
Brookeridge Air Park LL22
Downers Grove, IL 60516
630 985-8503
In a message dated 4/1/2006 10:35:59 A.M. Central Standard Time,
mick-matronics(at)rv8.ch writes:
Hi Alan,
with Bose headsets.
Posted: Sat Apr 01, 2006 9:52 am Post subject: power for headsets |
Ah, what version of the Bose do you have? I have the series II's and they
have the panel jack on them... BUT, they also came with a battery pack and
an adapter harness so that they could be powered from either source (battery
or ship). If you have the X's, you are screwed, you either buy the other
cable, or you keep feeding them batteries. Sorry, I don't think there is
anyway to added ship power to those with out going to to the panel
connector.
Alan
flyeyes(at)mac.com Guest
Posted: Tue Apr 04, 2006 6:39 pm Post subject: power for headsets |
On Apr 1, 2006, at 8:33 AM, Mickey Coggins wrote:
Quote: |
matronics(at)rv8.ch>
a lot of batteries.
Thanks!
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
Mickey--the Bose (a.k.a. "Redel") connectors are rapidly becoming a
de facto standard in new factory GA aircraft. I have flown or ridden
on four fixed-wing aircraft and two helicopters built since '03 and
all had the "bose" connectors paralleled to the old standard headset
jacks. They work fine in parallel, and you can mix and match
headsets on then intercom.
When I fly the Cirrus, I use Telex ANR headsets with the new
connector, and I usually use an old Bose headset in the RV with a
battery pack.
As I type this, I have two of the Bose connectors sitting on my desk,
waiting for a rainy day to install them in the RV-8.
All of the headset manufacturers (Bose, Telex, Lightspeed, and Peltor
at least) will sell a headset wired this way. If you can build an
airplane, you can install the connector yourself.
You could also buy a female plug like the one in the battery pack for
your Bose and wire that for power (If you have the old ones with a
separate battery pack)
James
Posted: Tue Apr 04, 2006 7:00 pm Post subject: power for headsets |
one note on this.
I believe the DC also uses a similar jack - HOWEVER, there are 8 pin and 6
pin. To my knowledge, only DC uses the 8. Everyone else uses the 6 (better
known as the Bose connector).
Alan
rv8ch
Posted: Wed Apr 05, 2006 12:49 am Post subject: power for headsets |
Quote: | Mickey--the Bose (a.k.a. "Redel") connectors are rapidly becoming a
OK, I found the manufacturer for the connector, they're about
an hour drive from where I live. Now I know why these plugs
are so expensive - they're made in Switzerland!
http://www.lemo.com/
The price for the raw plugs in units of one are about USD 40
each. I think I'll just stick with the batteries for now.
http://www.distrelec.com/ishopWebFront/search/luceneSearch.do?dispatch=find&showImage=on&artnrPhrase=116248
Many thanks for the details, gentlemen!
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
