M14PEngines-List Digest: 0 Msgs - 08/10/09
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List
javiercarrascob(at)yahoo.
PostPosted: Tue Aug 11, 2009 5:49 pm    Post subject: M14PEngines-List Digest: 0 Msgs - 08/10/09 Reply with quote
Hello Guys,
Open Question: any buid knows what are the minimun values for oil pressure on an m-14p in a conventional gear plane, after landing?
There is nowhere in my manuals that I can find that and the values are going into the yelow arc.
Thanks.
- The Matronics M14PEngines-List Email Forum -
http://www.matronics.com/Navigator?M14PEngines-List
westcoastkitplanes(at)gma
PostPosted: Tue Aug 11, 2009 8:50 pm    Post subject: M14PEngines-List Digest: 0 Msgs - 08/10/09 Reply with quote
Here's a bit of info I have, hope it helps:
Main line oil pressure (measured through special connection on oil pump):
Operating ratings ............................... ..................................... 4 to 6 kgf/cm
Minimum speed of rotation ........................ ............................. Hot less than 1 kgf/cm
When gliding at idle rating, oil pressure should not drop below 1 kgf/cm , Short-time
(up to 0.5 s) engine inlet oil pressure drop to 0.5 to 1 kgf/cm at near-zero and
negative accelerations as well as to a pressure of 1.8 kgf/cm for up to 5 s is allowed in flight. The total
time of engine operation under such conditions shall not exceed 5 min during service life.
Jeff
On Tue, Aug 11, 2009 at 6:47 PM, Javier Carrasco <javiercarrascob(at)yahoo.com (javiercarrascob(at)yahoo.com)> wrote:
[quote] Hello Guys,
Thanks.
st" target="_blank">http://www.matronics.com/Navigator?M14PEngines-List
tp://forums.matronics.com
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List All times are GMT - 8 Hours
