Endurance Bus Diode & Voltage leak
sjhdcl(at)kingston.net
PostPosted: Fri Mar 31, 2006 7:40 am    Post subject: Endurance Bus Diode & Voltage leak Reply with quote
Is it normal for a diode to leak voltage back onto the MAIN bus?
With the EBus X Feed Switch on (no MAIN bus) it get 12.8V at the Endurance
bus and about 6.85 V at the MAIN bus terminal. With the MASTER Off.
I understand the forward voltage drop when the MAIN bus is powered and I
measured it to be 0.6V. But I can't find any reference to this backwards
'leak' of voltage by the diode.
The diode is the standard 1" by 1" block (D-25) from B&C.
Another question: Some diagrams show only attaching 2 of the tabs on the
diode. One to Endurance and one to MAIN.
Other diagram shows joining the two terminal on the diode and then going
to the Endurance Bus. Is this for redundancy since these 2 terminals are
electrically the same?
Steve
RV7A
mprather(at)spro.net
PostPosted: Fri Mar 31, 2006 8:18 am    Post subject: Endurance Bus Diode & Voltage leak Reply with quote
Reverse biased diodes _do_ leak (current). Maybe a few microamps.
The voltage behind a reverse biased diode will depend on what it's
connected to. Presumably, the bus that your diode is connected to has all
of the switches turned off - very light loading with which to discharge
the leakage current through the diode. I would guess that if you
connected a 1kohm resistor between the bus and ground and remeasured the
voltage, it would be very low (V = IR = 0.000005A * 1000ohm = 0.005V).
Matt-
Endurance bus and about 6.85 V at the MAIN bus terminal. With the MASTER
Off.
are electrically the same?
Steve
RV7A
nuckollsr(at)cox.net
PostPosted: Fri Mar 31, 2006 8:41 am    Post subject: Endurance Bus Diode & Voltage leak Reply with quote
At 10:40 AM 3/31/2006 -0500, you wrote:
Diodes are not 'perfect' . . . they have forward voltage drop
and reverse leakage. Keep in mind that the input impedance of
a digital voltmeter is on the order of 10-20 MEGohms. To get
a reading of 6.85 volts due to leakage, you need only
6.85/10,000,000 or 685 NANOamps. If you turn on any single load
on the main bus, the reading will drop like a stone.
I went to the bench and wired a Fluke multimeter, 12v supply
and several diodes in series with a voltage measurement crafted
to show the effects of diode reverse leakage. From a selection
of parts in the bins, I got reverse leakage voltage readings from
.3 to 7.5 volts on regulator power silicon junction diodes.
When I measured a Shottky device, the leakage reading was 12V! I put
a 10,000 ohm load across the voltmeter and the reading dropped to
.25 volts. This shows that Shottky device leakage is several orders
of magnitude greater than for silicon junctions.
Bottom line is that your readings are understandable and not
significant in the grand scheme of things.
The four diodes contained in a bridge rectifier are identical.
If you noodle out their position in the device, you can use any
of 4 combinations of terminals to effect the desired operation.
But you can't go wrong with wiring per:
http://www.aeroelectric.com/Pictures/Wiring_Technique/diode_wiring.jpg
http://www.aeroelectric.com/Pictures/Misc/s401-25.jpg
< What is so wonderful about scientific truth...is that >
< the authority which determines whether there can be >
< debate or not does not reside in some fraternity of >
< scientists; nor is it divine. The authority rests >
< with experiment. >
< --Lawrence M. Krauss >
jebrick(at)comcast.net
PostPosted: Fri Mar 31, 2006 9:54 am    Post subject: Endurance Bus Diode & Voltage leak Reply with quote
Another source of voltage to the main bus, with the master (and alternator
field) off, is the alternator when the engine is running. There is enough
residual magnetism or something...at least on my L-40 alternator, to produce
about 3.5 volts at high rpm and about half a volt at low rpm. This is with
minimal load on the bus. Significance in my case was that a shunt relay
powered by the main bus would not unlatch in flight when the Bat/Alt switch
was turned off, but it would on the ground at idle.
jb
