Auto Engine - compression ratio vs. octane
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Engines-List
bk_maynard(at)yahoo.com
PostPosted: Wed May 13, 2009 7:24 am    Post subject: Auto Engine - compression ratio vs. octane Reply with quote
  Would someone have a rough idea of what compression ratio I could run on my chevy auto<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Conversion if I run 100LL instead of regular unleaded?
Specs for my 3.4 V6 are 9.0:1 for regular.
Thanks, Brad
- The Matronics Engines-List Email Forum -
http://www.matronics.com/Navigator?Engines-List
s_korney(at)hotmail.com
PostPosted: Wed May 13, 2009 8:18 am    Post subject: Auto Engine - compression ratio vs. octane Reply with quote
At least 10:1 with 100LL
Best... Steve
Date: Wed C 13 May 2009 08:17:42 -0700
Subject: Auto Engine - compression ratio vs. octane
To: engines-list(at)matronics.com
Thanks C   Brad
http://www.matronics.com/N========================http://www.matronics.com/contrib===============
HotmailŪ has a new way to see what's up with your friends. Check it out. [quote][b]
jrccea(at)bellsouth.net
PostPosted: Wed May 13, 2009 8:34 am    Post subject: Auto Engine - compression ratio vs. octane Reply with quote
Theoretical limit is 11.2:1 with premium autofuel. I don't think I'd go that high. I do know from experience that 9.5:1 is OK on premium with 28 degrees advance on an O-200, but I have trouble on shutdown with regular.
JimC
MONTY(at)bpaengines.com
PostPosted: Wed May 13, 2009 8:53 am    Post subject: Auto Engine - compression ratio vs. octane Reply with quote
I don't think I would use 100 LL in an auto engine for a couple of reasons.
1. Avgas burns at a slower rate
2. One of the products of combustion with leaded fuel is lead bromide, which is somewhat corrosive and abrasive.
Aircraft lubricating oil has an additive package to deal with lead bromide whereas motor oil does not.
an interesting side note. I rebult a Ford Flathead for a 46 Coupe I have and the engine is considerably pumped up. I ran it on the dyno here in the BPE shop and ran it on 100 LL. mixture was not quite right and during the process of straightening out power valves, jetting, etc. I also tested with 91 Oct mogas. The CR on this engine is 9.25:1 which is quite a bit for a flathead. The engine made slightly more power on mogas with the timing not changed. FYI
Monty Barrett
Barrett Precision Engines
GrummanDude
PostPosted: Wed May 13, 2009 8:59 am    Post subject: Auto Engine - compression ratio vs. octane Reply with quote
If compression were the only consideration, it would be so simple. It
isn't that simple.
Cam design plays more of a roll in detonation limits than compression
alone. You can easily make 8.5:1 compression produce 145 pounds
cranking pressure if you know what you're doing. Likewise, 11:1 can
produce less than 140 pounds with the right lobe separation angle.
I recommend measuring the cranking pressure. 145 pounds cranking
pressure is easy with 100LL. 155 would be a little on the edge.
Anything in the 130 range (125 to 135) is a piece of cake.
Gary
AuCountry Aviation
Home of Team Grumman
frank.hinde(at)hp.com
PostPosted: Wed May 13, 2009 9:13 am    Post subject: Auto Engine - compression ratio vs. octane Reply with quote
Interesting..And seems to be evidence that mogas is better for an aircraft engine too, assuming its not a turbo'ed 540.
I know my IO 360 loves mogas and runs well even with 10% Ethanol blends...Although I have not flown it above 15000ft so cannot attest to vphase seperation, water fallout predictions.
Frank
From: owner-engines-list-server(at)matronics.com [mailto:owner-engines-list-server(at)matronics.com] On Behalf Of Monty Barrett Sr
Sent: Wednesday, May 13, 2009 8:41 AM
Subject: RE: Auto Engine - compression ratio vs. octane
Monty Barrett
larry(at)macsmachine.com
PostPosted: Wed May 13, 2009 9:35 am    Post subject: Auto Engine - compression ratio vs. octane Reply with quote
Hi Frank,
I've used 87-octane with 10% ethanol for the last two years and only on
one occasion did "phase separation" occur. The aircraft had set for 4 months
with less than a gallon in the tank after the pre winter annual
inspection. The small amount of fuel did look nearly opaque and gray. I
drained the remaining
and added new fuel when flying weather returned. No telling how long the
gas had set in the retailers tank before I got it.
Frank
[mailto:owner-engines-list-server(at)matronics.com] *On Behalf Of *Monty
Barrett Sr
*Sent:* Wednesday, May 13, 2009 8:41 AM
*To:* engines-list(at)matronics.com
*Subject:* RE: Auto Engine - compression ratio vs. octane
reasons.
Monty Barrett
PostPosted: Wed May 13, 2009 11:14 am    Post subject: Auto Engine - compression ratio vs. octane Reply with quote
Good input Larry..Sounds like the remaining fuel absorbed the water from condensation.
Fit for the lawnmower only after 4 months is a certainty now..Smile
Frank
Ed Anderson
PostPosted: Wed May 13, 2009 1:53 pm    Post subject: Auto Engine - compression ratio vs. octane Reply with quote
Given that the lower the octane rating, the more energy a specific volume of gasoline has, I am not surprised that with auto fuel you got more power than with 100LL. The higher octane fuel has less energy content and only real purpose is prevent detonation with high compression engines. Many believe that higher octane means more power than lower octane fuels, but only if you are able to run higher compression or forced induction systems (which in effect increase compression ratio).
100LL contains approx 120,000 BTU/Gallon whereas 87 Octane contains approx 125,000 BTU/Gallon or about 4% more energy.
Ed
Ed Anderson
Rv-6A N494BW Rotary Powered
Matthews, NC
eanderson(at)carolina.rr.com
http://www.andersonee.com
http://www.dmack.net/mazda/index.html
http://www.flyrotary.com/
http://members.cox.net/rogersda/rotary/configs.htm#N494BW
http://www.rotaryaviation.com/Rotorhead%20Truth.htm[url=http://www.dmack.net/mazda/index.html][/url]
Sent: Wednesday, May 13, 2009 11:41 AM
Monty Barrett
Ed Anderson
Matthews, NC
eanderson@carolina.rr.com
andrew(at)oc384.net
PostPosted: Wed May 13, 2009 3:12 pm    Post subject: Auto Engine - compression ratio vs. octane Reply with quote
In that case is there an aviation oil including the additive that can be run in auto conversion engines? Or can the additive be bought and added when filling up with 100LL? If you’re flying into places w/out mogas it sounds like you need it.
-Andrew
Sent: Wednesday, May 13, 2009 10:41 AM
Monty Barrett
dean.psiropoulos(at)veriz
PostPosted: Thu May 14, 2009 7:49 pm    Post subject: Auto Engine - compression ratio vs. octane Reply with quote
The big automotive engines of the 1960s took compression ratios to their
ultimate state of the art with premium leaded auto gas. Ratios from 10.5 to
11.5 to 1 were common place with 100 octane auto fuel. Since the unleaded
mandate, computer analysis has advanced the state of the art in combustion
chamber technology so that 9.5 to 1 ratios are possible on regular unleaded
fuel (87 octane) without detonation. If you use computerized engine control
with knock sensing you could probably go even higher. And with avgas being
the equivalent of somewhere around 110 octane autofuel, the sky should be
the limit (not quite but it would be an interesting exercise to see how high
one could go using a modern auto engine with avgas).
Dean Psiropoulos
RV-6A N197DM
Struggling with erratic idle on 0-360
Float Flyr
PostPosted: Fri May 15, 2009 5:58 am    Post subject: Auto Engine - compression ratio vs. octane Reply with quote
I had a friend who regularly ran his 426 Hemi Charger on high octane Avgas
before the advent of 100 LL.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Engines-List All times are GMT - 8 Hours
