Squeaking nose gear
SteveR
PostPosted: Thu Apr 16, 2009 8:34 pm    Post subject: Squeaking nose gear Reply with quote
The nose gear in an AA5 Traveler I've been flying lately started squeaking after a rain shower (the plane is kept outside currently). The squeak is coming from the nose gear torque tube area (very near the firewall). I think maybe it just needs to be lubricated as I read about this elsewhere. Would anyone agree with that? I'm new to Grummans so I'm not sure if the squeaky nose gear is common or not. Bouncing the nose up and down slightly makes it squeak fairly loud.
What is the proper procedure and lubricant to use on the torque tube/nose gear strut junction, assuming that is where the squeak is coming from? Does the nose gear strut have to be removed from the torque tube in order to lubricate it?
Or if I'm going in completely the wrong direction, I'd be glad to hear about that too. Thanks for any help.
Steve
GrummanDude
PostPosted: Thu Apr 16, 2009 9:04 pm    Post subject: Squeaking nose gear Reply with quote
Hi Steve,
If you had the shocks on the nose gear, I'd say look there first.
You'll need to remove the cowling and locate where the squeak is coming
from. If it's in the nose gear torque tube attach, remove the boot
around the strut and check the attachment bolts. I've seen a number of
planes with AN bolts installed when they should be NAS. Also, if the
bolts have been crowded out, they'll need to be reamed a half size over
and special bolts installed.
Also, I'd suggest you remove the seats and crawl in under the panel and
have someone move the nose up and down and check for squeaking in the
torque tube itself.
Gary
AuCountry Aviation
Home of Team Grumman
flyv35b(at)minetfiber.com
PostPosted: Fri Apr 17, 2009 4:59 am    Post subject: Squeaking nose gear Reply with quote
I'd say there is a very high probability that the squeaking noise you are
hearing is due to a delaminated torque tube. No lubrication was required
anywhere on the strut/torque tube installation. You will need to have
someone help you bounce the plane up and down while you get under the panel
and put your fingers across both sides of the torque tube joint on the
socket and also at the outboard ends near the fuselage sidewall. Do this on
both sides. Delaminated torque tubes can be rebuilt. A failed joint will
put additional load on the opposite site and if that side fails you will end
up with the prop in the ground!
Cliff A&P/IA
SteveR
PostPosted: Fri Apr 17, 2009 5:37 am    Post subject: Re: Squeaking nose gear Reply with quote
Cliff, thanks for your help, I really appreciate it. I think we'll ground the plane until we know for sure what the problem is. If anyone has any diagrams of the torque tube assembly that would help us know what to look for, they would be greatly appreciated.
This is where I got the information on lubricating the strut and torque tube:
http://www.grumman.net/cgrcc/aa5.html
The nosegear demands maintenance and must be lubricated and adjusted strictly by the book. (Not many shops even have the book.) In particular, the strut inside the torque tube should be free of corrosion and well lubricated.
PostPosted: Fri Apr 17, 2009 6:08 am    Post subject: Squeaking nose gear Reply with quote
Good information but not intended to replace the maintenance manual info.
The lubrication Aviation Consumer is referring to is where the nose fork is
mated to the nose strut. This area is where lots of non Grumman shops and
mechanics know very little about and they ignore the maintenance here and
get the fork tension washer installation and adjustment screwed up and the
nose wheel shimmys.
I wouldn't fly the plane until you find out if the torque tube is OK. I'd
also buy a maintenance and parts manual from Fletchair, especially if you
mechanic doesn't have a set.
Cliff
SteveR
PostPosted: Fri Apr 17, 2009 6:43 am    Post subject: Re: Squeaking nose gear Reply with quote
Thanks again Cliff. The owner might have the manual, I'll check with him.
I found the information below (last paragraph) which describes the torque tube assembly. I'm having trouble understanding which part(s) might be delaminated. It sounds to me like everything is bolted or welded, which I know isn't right. Once I'm under there with a light, and a helper is bouncing the nose, will it be pretty obvious?
And finally, if it is a delaminted torque tube, can you recommend any good shops for rebuilds? I am in the Oklahoma City area, any local experts that anyone could recommend would be greatly appreciated.
Here is the paragraph I found somewhere else...I'm having trouble understanding where to look for delaminations here:
The torque tube assembly is made up of three parts: the T connector, the horizontal tube(s), and the sidewall mounting bracket(s). The T connector has a tube in it which connects to the nose gear strut and is bolted to the floor and firewall. It is welded to the horizontal tubes which on the other ends are welded to the sidewall mounting brackets. The mounting brackets are bolted to the sidewalls.
Thanks again for the help,
Steve Ruse
cloudvalley(at)comcast.ne
PostPosted: Fri Apr 17, 2009 6:50 am    Post subject: Squeaking nose gear Reply with quote
Hi Cliff!
Ah yes the torque tube. We had a problem with that also.smile
Brian Preston
grumpyparts
PostPosted: Fri Apr 17, 2009 11:45 am    Post subject: Re: Squeaking nose gear Reply with quote
The torque tube can be of three different make-ups, as far as I know. They are primarily made up of five parts. Two end plates, two torque tubes and a centre yoke, which the nose leg attaches to. If you follow the link below to the forum site you will see a picture of the assembly. In the original Grumman/Gulfstream tubes the two torque tubes were solely bonded into the two end plates. If both failed nothing stopped the nose leg rotating up into the bottom of the engine cowl. Frank Johnson then came out with a STC’ed repaired option where the tubes were bonded and tapered pinned to the end plates. Fletchair’s and AGAC’s torque tubes were similar but instead of the one pin in each end plate and yoke they used two bolts at 90 degrees to each other. Pictures of these three different types are shown in the link below also as well as a failed joint
Diagram taken from parts book
Original bonded end plate
Frank Johnson end plate
Fletchair/AGAC/Tiger end plate
Failure mode of bonded joint on end plate
Comparision between Johnson and Fletchair tubes. One on the right is a failed Johnson tube, notice angle difference of nose leg yoke exit. Sorry about the kitchen background.
Ian
MatAir
SteveR
PostPosted: Fri Apr 17, 2009 11:50 am    Post subject: Re: Squeaking nose gear Reply with quote
Wow. Absolutely great information Ian. It'll be fairly easy to diagnose now, the hard part is just crawling under the panel. Thanks for the great information and pictures everyone.
grumpyparts
PostPosted: Fri Apr 17, 2009 12:44 pm    Post subject: Re: Squeaking nose gear Reply with quote
Pictures tell a thousands words. I only wish more would use the forum instead of the email listings. All those formatting emails finally made me give up on the email option. Use the forum and formatting is not an issue.
SteveR
PostPosted: Sat Apr 18, 2009 6:19 pm    Post subject: Re: Squeaking nose gear Reply with quote
I crawled under the panel today to have a look at the torque tubes. The bonded joints definitely do not appear to be broken, and each side of the tube moves together. The squeaking appeared to be coming from the yoke area, between the rotating center of the torque tube and the bracket that holds it to the floor and firewall. After lubricating this joint, the squeaking went away. I think it is safe to say that the torque tube is fine.
I'm attaching a picture of each of the torque tube bonded junctions. Any comments would be appreciated. Thanks again for everyone's input on this.
I couldn't tell how the torque tube rotates in the firewall/floor bracket. The plane's annual is coming up next month, and we do have the service manual for the plane. Is there anything on that bracket that we should tell the shop to look at or lubricate?
Left Outboard Bonded Junction
 Filesize:  14.22 KB
 Viewed:  19313 Time(s)
Left Inboard Bonded Junction
 Filesize:  11.69 KB
Right Inboard Bonded Junction
 Filesize:  6.91 KB
Right Outboard Bonded Junction
 Filesize:  12.47 KB
SteveR
PostPosted: Sat Apr 18, 2009 7:23 pm    Post subject: Re: Squeaking nose gear Reply with quote
I should probably add that the nose gear boot was torn, which could've let some moisture in right on the bracket/torque tube in question. A new boot is on the way.
GrummanDude
PostPosted: Sat Apr 18, 2009 9:51 pm    Post subject: Squeaking nose gear Reply with quote
pics didn't come through
Gary
AuCountry Aviation
grumpyparts
PostPosted: Sun Apr 19, 2009 12:16 am    Post subject: Re: Squeaking nose gear Reply with quote
Gary
If you go to the bottom of Steve's message you should see a link to the teamgrumman forum, think it reads something like.
http://forums.matronics.com/viewtopic.php?p=240007#240007
The pictures are there.
You will also see a similar message at the bottom of this message as I use the forum for all messages now.
grumpyparts
PostPosted: Sun Apr 19, 2009 2:57 am    Post subject: Re: Squeaking nose gear Reply with quote
The only free moving parts in the torque tube is within the firewall/floor bracket. Held between the two halves of that bracket is a steel collar which holds a bronze split bearing p/n 702058-6. (part 31 in the picture shown on the forum site) When the torque tube twists under loads exerted to the nose leg attached to the torque tube yoke, the tube yoke section rotates within that bronze bearing. Although the steel collar is held tight within the two halves of the centre brackets, if the friction between the bearing and yoke become too tight, there is nothing to stop that collar trying to rotate within the bracket which may also cause squeaking. Why the parts book call out that p/n for the bearing I don’t know because it is not a replaceable/servicebale item. The only way to replace it is to remove the torque tube from the plane and debond/unbolt the end caps of the tube.
I assume by lubricating you may mean spraying so may be that has penetrated within and between the bearing and tube and helped some what.
For pictures of a broken down split bearing follow the “Read this topic online here” link below.
Comlplete split bearing breakdown
 Filesize:  47.36 KB
 Viewed:  19279 Time(s)
Bracket disassembled and steel collar removed with split bearing witin
 Filesize:  47.22 KB
Torque Tube Yoke
 Filesize:  48.49 KB
SteveR
PostPosted: Sun Apr 19, 2009 7:16 am    Post subject: Re: Squeaking nose gear Reply with quote
Here are some direct links to the bonded tubes if anyone still wants to look at them (see the end of my message). I don't think broken bonds are the problem though. I think it was just the bronze split bearing referenced by Ian. When I lubricated that area with some light silicone lubricant, the squeaking went away. I think some moisture had entered the area through a torn nose gear boot...I flew the plane about six hours then it sat outside overnight in a rain shower immediately before the squeaking started. The annual is about a month away, so we'll be replacing the boot, and maybe adding some lubricant to that bearing, although I'm not sure what the proper lubricant would be. I'd say we're really just trying to prevent corrosion there more than lubricating. Would something like LPS-3 be good for this?
Thanks again for the help everyone...this is a great list!
http://www.wotelectronics.com/flying/DSC04958%20-%20right%20outboard.JPG
http://www.wotelectronics.com/flying/DSC04961%20-%20right%20inboard.JPG
http://www.wotelectronics.com/flying/DSC04965%20-%20left%20outboard.JPG
http://www.wotelectronics.com/flying/DSC04972%20-%20left%20inboard.JPG
