OV/LV light (was: UV Light)
nuckollsr(at)cox.net
PostPosted: Wed Mar 22, 2006 6:06 am    Post subject: OV/LV light (was: UV Light) Reply with quote
At 06:24 PM 3/21/2006 -0600, you wrote:
Bob,
I will try this again. The first time I tried to snip. Didn't work.
The OV/LV sensor came from B&C.
The light comes on steady when the mic is keyed. We aslo thought if might be
RF.
Could be. I don't remember details of the design.
It may have some sensitivity to RF . . particularly
from hand held radios.
Today, while doing a cowl off inspection, I noticed that the small stranded
wire from the large post to the small post on the S701-1 over voltage
dissconnect contactor was burned in two.
The S701-1 comes wired for use as a battery master contactor.
For use as an alternator disconnect relay, that wire should
be removed. Looks like the system removed it for you. Check
the schematic.
I did have a OV trip a few months
back while taxi testing, but figured it was a nuisance trip. Without the
small wire the alternator has been functioning.
Yup.
The battery seems to have
full charge. Did not use a tester it was at home. Just looked at the
voltmeter. Turning the master on did not bring up the LV sensor light.
Any ideas?
Use a voltmeter to see if the bus voltage is sufficiently
low to cause the light to come on. I think it's calibrated
to come on at 12.5 and below. Your battery won't drop below
that level until you load it. I.e., turn on some stuff with
the alternator OFF and wait a minute or so.
Jerry Grimmonpre'
PostPosted: Wed Mar 22, 2006 7:17 am    Post subject: OV/LV light (was: UV Light) Reply with quote
Bob ...
How does the alternator disconnect relay do it's job? None of the Z's show
this relay between the alternators and the schematic wiring. Is this relay
an add-on to the ANL approach or the field CB? What is the most reliable
hardware to protect from OV? Slogging through electrical in Illinois ...
Jerry Grimmonpre'
>stranded
the schematic.
PostPosted: Wed Mar 22, 2006 8:07 am    Post subject: OV/LV light (was: UV Light) Reply with quote
At 09:16 AM 3/22/2006 -0600, you wrote:
Bob ...
Jerry Grimmonpre'
Z-24 was temporarily removed from the z-figures when
some folks discovered that a pilot might induce a
load dump failure of the alternator's regulator
by manipulating the control switch at inappropriate
times. Hence the idea for a system that allows
any-time, any-conditions, no-hazard, absolute
control over an IR alternator.
Revision A has been crafted and work is plodding along
to make it a reality. If my boss were as interested in
working on RVs and Kitfoxes as he is in Hawkers and
Kingairs, this project would be moving along faster.
>>stranded
> the schematic.
You can see the old z-24 drawing at:
http://www.aeroelectric.com/temp/Z24_temp.pdf
I presume this is what you have installed if you had
a "nuisance trip" earlier. The fact that you burned the
extra jumper raises concerns about whether or not your
ov module has been damaged.
Send it to me for a checkup.
< with experiment. >
< --Lawrence M. Krauss >
trumanst(at)netins.net
PostPosted: Wed Mar 22, 2006 2:30 pm    Post subject: OV/LV light (was: UV Light) Reply with quote
Thanks Bob.
As always, you have cleared things up. Z24 shows what you are speaking of
with reguard to the small wire.
Again Many Thanks
Kevin
on 3/22/06 8:03 AM, Robert L. Nuckolls, III at nuckollsr(at)cox.net wrote:
<nuckollsr(at)cox.net>
> Bob,
> RF.
the schematic.
Yup.
> Any ideas?
PostPosted: Wed Mar 22, 2006 2:49 pm    Post subject: OV/LV light (was: UV Light) Reply with quote
Bob,
Yes I do have it wired as per Z24.
I would be happy to send the ov Module. Is it OK to fly without it ?
Kevin
> Bob ...
> Jerry Grimmonpre'
>>> stranded
>> the schematic.
PostPosted: Wed Mar 22, 2006 6:09 pm    Post subject: OV/LV light (was: UV Light) Reply with quote
At 04:34 PM 3/22/2006 -0600, you wrote:
Thanks Bob.
Again Many Thanks
Kevin
My pleasure.
At 04:56 PM 3/22/2006 -0600, you wrote:
Bob,
Kevin
sure . . . risks are low but not zero. I'll turn it around quickly.
PostPosted: Wed Mar 22, 2006 6:41 pm    Post subject: OV/LV light (was: UV Light) Reply with quote
Great. I will get it in the mail ASAP.
Kevin
> Bob,
> Kevin
PostPosted: Thu Mar 23, 2006 6:23 pm    Post subject: OV/LV light (was: UV Light) Reply with quote
Bob,
I have the OV module in hand.
What is your mailing address?
Kevin
> Bob,
> Kevin
