mag switches
jorear(at)new.rr.com
PostPosted: Mon Jan 09, 2006 5:40 pm    Post subject: mag switches Reply with quote
Group:
I have a quick question regarding how the mags are wired to toggle switches as illustrated in drawing Z-11.
As wired in this schematic, if you place the right mag to "on" and then engage the starter via the left mag/start switch, does this ground out both mags so that you can turn the engine over with the ignition essentially off?
Thanks in advance
Jeff Orear
RV6A
mprather(at)spro.net
PostPosted: Mon Jan 09, 2006 6:37 pm    Post subject: mag switches Reply with quote
Hello Jeff,
The way I interpret the drawing is that when the right mag is "on", the
starter circuit is disabled. In other words, when the right mag is on
(disconnecting 2 from 3), continuity between terminals 5 and 6 is broken,
which disables the starter circuit.
The drawing shows the right mag switch in the OFF-START position.
With the switch selected as drawn, the right mag is grounded out
(disabled) via continuity between terminals 2 and 3.
The drawing shows the left mag grounded out (disabled) via terminals 2 and 3.
The drawing shows the starter circuit is disabled because terminals 4 and
5 on the left mag aren't connected.
As drawn, if the left mag switch is moved, the left mag is disabled. If
it is moved to its full opposite position, the left mag is enabled (no
continuity between 2 and 3), and the starter is enabled (continuity
between 4 and 5).
I hope that helps..
Matt-
<jorear(at)new.rr.com>
Group:
essentially off?
Thanks in advance
Jeff Orear
RV6A
PostPosted: Mon Jan 09, 2006 7:21 pm    Post subject: mag switches Reply with quote
Thanks Matt.
I guess what I really want to know is how do you turn an engine over as
wired in Z11 without the mags hot?
Jeff
PostPosted: Mon Jan 09, 2006 8:54 pm    Post subject: mag switches Reply with quote
Without adding jumpers, or more switches, it won't happen.. In order to
engage the starter, the left mag switch will have terminals 1 and 2
connected, which will enable the left magneto (because terminal 1 isn't
connected to anything). For diagnostic purposes, you could connect
terminal 1 to ground. Then the left mag would be disabled.
Matt-
Thanks Matt.
Jeff
