bughntr(at)comcast.net Guest
Posted: Thu Mar 26, 2009 5:56 pm Post subject: Door Strut Kit |
I am getting ready to install a door strut kit on my model II. I was hoping to get some pictures and measurements from someone to simplify my installation. Does anyone have some pic's and measurement I could use? I am also interested in a possible back of door installation. Does anyone have pictures etc for this?
Bryan Quinton
582 Model II
henrysfork1(at)msn.com Guest
Posted: Thu Mar 26, 2009 6:24 pm Post subject: Door Strut Kit |
I have a model II with door struts and would be glad to help if you like. I will have to take a couple of pictures and do some measuring. I will try to get it done tomorrow for you.
Dee Young
Model II
Subject: Kitfox-List: Door Strut Kit
Date: Thu C 26 Mar 2009 18:58:56 -0700
Thanks C
Bryan Quinton
582 Model II
| Quote: | http://www.matronics.com/Navigator?Kitfox-List
ronics.com
ww.matronics.com/contribution
Guy Buchanan
Posted: Thu Mar 26, 2009 8:08 pm Post subject: Door Strut Kit |
At 06:58 PM 3/26/2009, you wrote:
| Quote: | | Does anyone have some pic's and measurement I could use? I am also interested in a possible back of door installation. Does anyone have pictures etc for this? |
I have some information now. Pictures later. First is the geometry. Note that my struts are at the back of the door. The upper attachment is 5.16" out the door, the lower is 13.66" down the frame tube. (Both measured from the pivot centerline.) The strut centerline is offset 1 5/16" from the tube's centerlines. The gas strut is 8.5" long closed, 12" long fully extended, with a 4" throw.
[img]cid:.0[/img]
These are drawings of my strut attachments. I bought the tabs and balls from Guden and welded them to pieces of tube which were then pop-riveted to the airframe and door frame. The pictures show the tabs and struts bought from Guden.
[img]cid:.1[/img]
[img]cid:.2[/img] [img]cid:.3[/img]
I don't have any more pictures, for some reason, but will try to remember to take some tomorrow.
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 300 hrs. and counting
17.02 KB |
5310 Time(s) |
28.38 KB |
5310 Time(s) |
31.21 KB |
5310 Time(s) |
7.76 KB |
5310 Time(s) |
Deceased K-IV 1200
A glider pilot too. |
815TL
Posted: Fri Mar 27, 2009 3:29 am Post subject: Re: Door Strut Kit |
Bryan,
if you need any other pictures or measurements, let me know. I have them on my model II as well.
Andrew
akflyer
Posted: Fri Mar 27, 2009 8:37 am Post subject: Re: Door Strut Kit |
http://avidfoxflyers.com/index.php?topic=252.0
Shows the struts in place.
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
