Ok guys another part needed
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> L29-List
Bcolombo(at)twcny.rr.com
PostPosted: Wed Mar 22, 2006 11:27 am    Post subject: Ok guys another part needed Reply with quote
I am looking for the overpressure dump valve for the rear canopy nitrogen system. If you are sitting in the rear cockpit with the canopy closed it is over your right shoulder. It is a simple spring loaded overpressure dump with a rubber seal inside. My rubber seal is old, dry and cracked and just will not seal. I either need a new seal for it or a new or used serviceable unit. All my nitrogen is gone in 20 min and I here it coming from there. I could prob. just make a new rubber seal but I figured I would check if anyone had this unit or the seal first. Thanks as always. you guys are really great when it comes to helping a newbie such as myself.
Brian Colombo N6235M
- The Matronics L29-List Email Forum -
http://www.matronics.com/Navigator?L29-List
colyergreg(at)aol.com
PostPosted: Wed Mar 22, 2006 12:15 pm    Post subject: Ok guys another part needed Reply with quote
Brian,
will look but don't think so. How did the limit switch work out? Greg
schwartzcompany(at)worldn
PostPosted: Wed Mar 22, 2006 12:38 pm    Post subject: Ok guys another part needed Reply with quote
this is the RV 50 reduction valve.
Robert E. Schwartz
Email: schwartzcompany(at)worldnet.att.net
This information is intended for the use of individual named above. If you
are not the intended recipient, you are hereby notified that any disclosure,
copying, distribution, or the taking of any action in reliance on the
content of this information is strictly prohibited.
PostPosted: Wed Mar 22, 2006 1:27 pm    Post subject: Ok guys another part needed Reply with quote
greg, limit switch was perfect. No gear indicator issues anymore. Thanks
again.
Colyergreg(at)aol.com
PostPosted: Wed Mar 22, 2006 7:05 pm    Post subject: Ok guys another part needed Reply with quote
glad it worked out for you...I just finished my 02 install today. It's
pretty awesome...
Greg
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> L29-List All times are GMT - 8 Hours
