Coil cooling tubes
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Jabiru-List
ianwilson2
PostPosted: Mon Feb 16, 2009 12:51 am    Post subject: Coil cooling tubes Reply with quote
I have a 2200A and in the latest install manual it says to fabricate some cooling tubes for the ignition coils, from the ram air ducts. The ducts already have holes fairly well aligned with the coils, so do I need to add these tubes? My engine isn't running yet, so I'd appreciate some real life experience.
Thanks.
Ian Wilson
- The Matronics Jabiru-List Email Forum -
http://www.matronics.com/Navigator?Jabiru-List
ElleryWeld(at)aol.com
PostPosted: Mon Feb 16, 2009 1:41 pm    Post subject: Coil cooling tubes Reply with quote
Ian
I installed the 2200 Jab engine and I did not install the cooling tubes and it has over 50 hours on it with no problems it has been run in real hot weather also.
Ellery
In a message dated 2/16/2009 3:52:35 A.M. Eastern Standard Time, ianwilson2(at)hotmail.com writes:
--> Jabiru-List message posted by: "ianwilson2" <ianwilson2(at)hotmail.com>
Thanks.
Ian Wilson
http://forums.matronics.com/viewtopic.php?p=230463#230463
A 100126575x1218822736x1201267884/aol?redir=http://www.freecreditreport.com/pm/default.aspx?sc=668072%26hmpgID=62%26bcd=febemailfooterNO62"> See yours in just 2 easy steps!
dhonabach
PostPosted: Mon Feb 16, 2009 2:03 pm    Post subject: Coil cooling tubes Reply with quote
I have about 60 hours on my 3300A without the air tubes and I haven't had any issues (yet) and the manual has the same suggestion.
When I asked the local Jabiru distributor, his answer was that "it depends" and if I remember correctly they might have had more problems with the older version of the coils then the newer ones. Ultimately, just like most everything else, the coils will break down quicker if they are exposed to high heat and having the blast of air should help increase their useful life. However, it might also be overkill if you have enough air movement inside the cowl already or don't live in a hot environment. I personally think it is a bit of overkill - especially for a part that has a back-up in place but that is just my opinion that will probably change the first time one fails Smile
Two things I would highly suggest:
My baffling had two crankcase air holes to help keep the air from stagnating on top of the crankcase. Make sure you don't close those up. It is important to get some air movement on top of the crank case.
Make sure you place a heavy duty or welding gage wire between one of the starter bolts and the engine ground. At least on the 3300 series, the ground connection between the starter and the engine isn't the best and this jumper cable makes a huge difference in the ability to crank over your engine. I believe there is even a bulletin on this now (fyi - assuming same applies to 2200 as it does for the 3300). I chased a starting problem for about a month until doing this - every since, no problems at all.
Don
From: owner-jabiru-list-server(at)matronics.com [mailto:owner-jabiru-list-server(at)matronics.com] On Behalf Of ElleryWeld(at)aol.com
Sent: Monday, February 16, 2009 14:40
To: jabiru-list(at)matronics.com
Subject: Re: Coil cooling tubes
Ian
Ellery
Thanks.
Ian Wilson
http://forums.matronics.com/viewtopic.php?p=230463#230463< - List Contribution Web Site ;
lizholloman199(at)q.com
PostPosted: Mon Feb 16, 2009 2:53 pm    Post subject: Coil cooling tubes Reply with quote
I have over 750hrs with out cooling tubes on a 3300 #267 C Lee
Subject: RE: Coil cooling tubes
Date: Mon C 16 Feb 2009 15:02:43 -0700
.ExternalClass .EC_shape {;} .ExternalClass p.EC_MsoNormal C .ExternalClass li.EC_MsoNormal C .ExternalClass div.EC_MsoNormal {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman' C'serif';} .ExternalClass a:link C .ExternalClass span.EC_MsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited C .ExternalClass span.EC_MsoHyperlinkFollowed {color:purple;text-decoration:underline;} .ExternalClass pre {margin-bottom:.0001pt;font-size:10.0pt;font-family:'Courier New';} .ExternalClass span.EC_HTMLPreformattedChar {font-family:Consolas;} .ExternalClass span.EC_EmailStyle20 {font-family:'Calibri' C'sans-serif';color:#1F497D;} .ExternalClass .EC_MsoChpDefault {font-size:10.0pt;} (at)page Section1 {size:8.5in 11.0in;} .ExternalClass div.EC_Section1 {page:Section1;}
When I asked the local Jabiru distributor C his answer was that "it depends" and if I remember correctly they might have had more problems with the older version of the coils then the newer ones. Ultimately C just like most everything else C the coils will break down quicker if they are exposed to high heat and having the blast of air should help increase their useful life. However C it might also be overkill if you have enough air movement inside the cowl already or don't live in a hot environment. I personally think it is a bit of overkill - especially for a part that has a back-up in place but that is just my opinion that will probably change the first time one fails Smile
Make sure you place a heavy duty or welding gage wire between one of the starter bolts and the engine ground. At least on the 3300 series C the ground connection between the starter and the engine isn't the best and this jumper cable makes a huge difference in the ability to crank over your engine. I believe there is even a bulletin on this now (fyi - assuming same applies to 2200 as it does for the 3300). I chased a starting problem for about a month until doing this - every since C no problems at all.
Don
Sent: Monday C February 16 C 2009 14:40
Ian
Ellery
In a message dated 2/16/2009 3:52:35 A.M. Eastern Standard Time C ianwilson2(at)hotmail.com writes:
I have a 2200A and in the latest install manual it says to fabricate some cooling tubes for the ignition coils C from the ram air ducts.  The ducts already have holes fairly well aligned with the coils C so do I need to add these tubes?  My engine isn't running yet C so I'd appreciate some real life experience.
Thanks.
Ian Wilson
0 [quote][b]
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Jabiru-List All times are GMT - 8 Hours
