Check lists, Was: Master switch warn
BigD(at)DaveMorris.com
PostPosted: Sun Jan 08, 2006 1:49 pm    Post subject: Check lists, Was: Master switch warn Reply with quote
I'll bet you can find schematics for those in Popular Electronics going
back to the mid 1930's.
Dave Morris
At 09:53 AM 1/8/2006, you wrote:
<ykibuess(at)bluewin.ch>
The buzzer idea sounds great! Lights and other devices fed by the always
hot battery bus will empty the battery one day if that bus is not
supervised by an intelligent warning system. Any specialist in
electronics out there who is able and willing to invent and build such a
warning (buzzer) system?
Alfred
-----Ursprngliche Nachricht-----
Von: owner-aeroelectric-list-server(at)matronics.com
[mailto:owner-aeroelectric-list-server(at)matronics.com] Im Auftrag von Ken
Gesendet: Samstag, 7. Januar 2006 18:50
An: aeroelectric-list(at)matronics.com.AeroElectric-List
Betreff: Re: AeroElectric-List: Check lists, Was: Master switch warning,
AeroElectric-List
A universal solution might be a buzzer that detects when more than a few
ma of current is flowing out of the battery. I'll think about it but I
don't think I know a simple way to do that such that it draws no standby
current, and doesn't add failure points to the original aircraft wiring
Ken
AdmID:2C0948FF9BDF762C85D9EF7BC638707F
PostPosted: Sun Jan 08, 2006 2:05 pm    Post subject: Check lists, Was: Master switch warn Reply with quote
Dave Morris
Alfred
AeroElectric-List
Ken
AdmID:C82621AED3CEF810FEFA027F0C8D49B5
PostPosted: Mon Jan 09, 2006 8:17 am    Post subject: Check lists, Was: Master switch warn Reply with quote
Dave Morris
Alfred
AeroElectric-List
Ken
AdmID:BBCFF4AAC41E648D3E5779E0D6BBFE0F
PostPosted: Mon Jan 09, 2006 9:52 am    Post subject: Check lists, Was: Master switch warn Reply with quote
Dave Morris
Alfred
AeroElectric-List
Ken
AdmID:234660C21113D61B4895E5BD9AEBE7CC
PostPosted: Mon Jan 09, 2006 12:00 pm    Post subject: Check lists, Was: Master switch warn Reply with quote
Dave Morris
Alfred
AeroElectric-List
Ken
AdmID:73ED58EF01ECC4F60540EB5146BFE27E
