Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Mon Dec 29, 2008 5:28 am Post subject: 503 engine fogging-OOPS-Update, got it. |
Does anyone have an idea on how to fish a fogging oil spray can plastic extension tube out of the crankcase on a 503? The engine is mounted spark plugs up and it was not running when the tube shot in there. I took the carb off but still can't see the tube.
_________________ Tom Jones
Classic IV
Ellensburg, WA
olendorf
Joined: 06 Jul 2006 Posts: 140 Location: Schenectady, NY USA
Posted: Mon Dec 29, 2008 6:19 am Post subject: Re: 503 engine fogging-OOPS |
I would try a shop vac.
_________________ Scott Olendorf
Original Firestar, Rotax 447, Powerfin prop
Schenectady, NY
http://sites.google.com/site/kolbfirestar/ |
Posted: Mon Dec 29, 2008 7:02 am Post subject: 503 engine fogging-OOPS |
| Quote: | Does anyone have an idea on how to fish a fogging oil spray can plastic extension tube out of the crankcase on a 503? The engine is mounted spark plugs up and it was not running when the tube shot in there. I took the carb off but still can't see the tube.
Tom Jones
Classic IV
Ellensburg, WA
Tom,
I would recommend trying to get ahold of a boroscope (like the link I've attached), and one
of those 4-fingered claws that Lanny suggested.
If you don't want to buy a boroscope, most "well-equiped" auto repair mechanics have them. Possibly you could buy him lunch or something. Just an idea.
Here's what I'm referring to:
http://cgi.ebay.com/ebaymotors/BORESCOPE-BOROSCOPE-FIBERSCOPE-FIBER-OPTIC-SCOPE-NEW_W0QQitemZ200290098469QQcmdZViewItemQQptZMotors_Automotive_Tools?hash=item200290098469&_trksid=p4506.c0.m245&_trkparms=72%3A543%7C65%3A12%7C39%3A1%7C240%3A1318
Or, if you can get a set of those mechanic mirrors, this might get you by as far as peering into
the crankcase. You can get these locally at any auto parts store. BTW, your best time to use the mirror is at night, with a really bright flashlight (and your 4-fingered claw).
Also, as Scott suggested, you might try the shop-vac idea. I would tape a section of flexible tubing on the end of the hose, say, about 3 feet long, so that you can fish around inside the crankcase. Every couple of minutes, check for the tube inside the vacuum.
Hang in there, you'll get it out.
Mike Welch
MkIII
It’s the same Hotmail®. If by “same” you mean up to 70% faster.
http://windowslive.com/online/hotmail?ocid=TXT_TAGLM_WL_hotmail_acq_broad1_122008
Posted: Mon Dec 29, 2008 7:11 am Post subject: 503 engine fogging-OOPS |
Tom,
Here is the set of mirrors I was suggesting. Very handy to have. Maybe you wouldn't
need the boroscope, if the spray tube isn't too far inside the motor.
http://cgi.ebay.com/ebaymotors/4pc-TELESCOPING-INSPECTION-MIRROR-AND-PICKUP-MAGNET-SET_W0QQitemZ220334412737QQcmdZViewItemQQptZMotors_Automotive_Tools?hash=item220334412737&_trksid=p4506.c0.m245&_trkparms=72%3A64%7C65%3A12%7C39%3A1%7C240%3A1318
Best of luck,
Mike Welch
Life on your PC is safer, easier, and more enjoyable with Windows Vista®.
Posted: Mon Dec 29, 2008 7:48 am Post subject: 503 engine fogging-OOPS |
At 05:28 AM 12/29/08 -0800, you wrote:
Tom,
No experience at this so this just a suggestion. Remove the intake manifold
so that you have as good a view as possible. Then rotate the engine slowly
so that the crank throw sweeps the case from the far side to the bottom and
up. Hopefully this will bring the tube up into your field of vision as the
port opens.
Good Luck!
Jack B. Hart FF004
Winchester, IN
HShack(at)aol.com Guest
Posted: Mon Dec 29, 2008 9:53 am Post subject: 503 engine fogging-OOPS |
Can't you see a lot better with the exhaust manifold removed?
Howard Shackleford
FS II
SC
In a message dated 12/29/2008 8:29:44 A.M. Eastern Standard Time, nahsikhs(at)elltel.net writes:
| Quote: | | Does anyone have an idea on how to fish a fogging oil spray can plastic extension tube out of the crankcase on a 503? |
One site keeps you connected to all your email: AOL Mail, Gmail, and Yahoo Mail. Try it now.
Tom Jones
Posted: Mon Dec 29, 2008 2:12 pm Post subject: Re: 503 engine fogging-OOPS-Update, got it. |
Can't see into the crankcase from the exhaust side, only the side and top of the piston.
I used a small mechanic's mirror to look around in there from the intake and could see the little red bugger but managed to push it down out of sight trying to grab it with a flex claw. Ended up taking the cylinder off to get it out. Just ordered the gaskets to put the engine back together.
It was an expensive lesson from the school of hard knocks.
Classic IV
Ellensburg, WA |
Posted: Mon Dec 29, 2008 2:19 pm Post subject: 503 engine fogging-OOPS-Update, got it. |
Tom Jones
Tom J:
Not a complete waste. Should have given you a good opportunity to inspect
the inside of the 503.
_________________ John Hauck
Titus, Alabama |
Tom Jones
Posted: Mon Dec 29, 2008 3:14 pm Post subject: Re: 503 engine fogging-OOPS-Update, got it. |
| Quote: | Not a complete waste. Should have given you a good opportunity to inspect
john h |
Yes, it is reassuring to see that everything is in order inside the noise maker.
Classic IV
Ellensburg, WA |
Posted: Mon Dec 29, 2008 3:39 pm Post subject: 503 engine fogging-OOPS-Update, got it. |
> Tom Jones
Tom J:
What's a Classic IV?
Titus, Alabama |
Tom Jones
Posted: Mon Dec 29, 2008 4:30 pm Post subject: Re: 503 engine fogging-OOPS-Update, got it. |
| Quote: | Tom J:
What's a Classic IV? |
Kitfox. Not too many people still use the 503 on a Kitfox so with engine questions I usually ask the Kolb list too.
Classic IV
Ellensburg, WA |
Posted: Mon Dec 29, 2008 4:41 pm Post subject: 503 engine fogging-OOPS-Update, got it. |
Tom J:
Several years ago, Rick Neilsen, Scott Trask, John W and I flew from Iron
Mountain, MI, in a gaggle that included a 503 powered Kit Fox. Can't
remember the man's name that flew it, but he was a very big man. Kit Fox
did ok, but would not keep up with the MKIII and Kolbra.
Titus, Alabama |
Posted: Mon Dec 29, 2008 4:51 pm Post subject: 503 engine fogging-OOPS-Update, got it. |
<gaggle that included a 503 powered Kit Fox.
The gaggle flew to OSH.
Titus, Alabama |
