Erich_Weaver(at)URSCorp.c Guest
Posted: Sat Mar 11, 2006 4:37 pm Post subject: p-mag wiring |
Bob:
My level of electrical knowledge is pretty limited, but is it possible that
Figure Z-33 in the 'Connection showing wiring for P-mags has an error?
Z-33 has the p-mag wires labeled by color (grn, red orn, and blk). Power
appears to be supplied to the p-mag from the bat bus through the "orn" wire
when the 2-10 switch is in the up position.
Comparing to the e-magair manual - see pgs 4 and 15 in
http://www.emagair.com/Manual%20L113v8.pdf
the manual seems to indicate that +13.8V power would be supplied by the red
wire (postion 5 on the control plug), and that the "orn" wire (position 4
on the plug) is the P-lead to ground (NOT power). The blk and grn wires
are for ground and tach respectively, consistent with Z-33.
Did I catch you, or am I just too hung up on wire colors?
While I got you cornered (?), I am unclear on how the additional switch you
suggest for ign maintenance would be used. When closed, it appears to
supply power from the bat bus to the p-mags while the two ignition switches
are in the off position. Okay, but what does this do for me?
still learning...
Erich Weaver
This e-mail and any attachments are confidential. If you receive this
message in error or are not the intended recipient, you should not retain,
distribute, disclose or use any of this information and you should destroy
the e-mail and any attachments or copies.
nuckollsr(at)cox.net Guest
Posted: Wed Mar 15, 2006 7:48 am Post subject: p-mag wiring |
Erich,
Sorry to take so long to get back on this. Your questions prompted a review
of some p-mag issues in Figures Z-13/8 and Z-33 along with the text in
the notes which I thought I'd fixed some time ago. In looking over the
originals this morning, I found several things that needed fixing so
I've updated Appendix Z to Revision F and posted the new document at:
http://aeroelectric.com/articles/Rev11/AppZ_R11F.pdf
Thanks for bringing this to my attention.
At 07:33 PM 3/11/2006 -0500, you wrote:
Quote: |
Bob:
still learning...
Erich Weaver
