Fuel Selector
jkreidler
PostPosted: Wed Dec 10, 2008 11:17 am    Post subject: Fuel Selector Reply with quote
I have had fuel selector valves on my brain, and have a few questions. Why can't a low wing airplane draw from both tanks at once? To me if the fuel is available at the inlet of the pump it should draw from both, just as well as a high wing with gravity working for it. Probably something obvious I am missing.... Has anyone ever considered using an electrically activated fuel selector valve like the ones used in dual fuel tank trucks? Switching tanks would then just be the flip of a switch. I think the failure mode of this device would be to stay open on whichever tank is selected. I will admit, complicating something as critical as fuel management any more than is absolutely necessary does make me nervous. Just got stuck on my brain for some reason..... Any thoughts?
Thanks, Jason Kreidler
N44YH - #40617 Finishing - 4 Partner Build [quote][b]
Jason Kreidler
4 Partner Build - Sheboygan Falls, WI
Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler
N44YH - Flying - #40617
rene(at)felker.com
PostPosted: Wed Dec 10, 2008 11:55 am    Post subject: Fuel Selector Reply with quote
Here is my opinion on why we can not have a “both” position……..not enough pressure (short column of fuel) on the fuel line at the valve to insure balancing of fuel between the tanks. This could result in the “un-porting” of one of the lines.
Rene' Felker
RV-10 N423CF Flying
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jason.kreidler(at)regalbeloit.com
Sent: Wednesday, December 10, 2008 12:15 PM
Subject: Fuel Selector
coop85(at)cableone.net
PostPosted: Wed Dec 10, 2008 3:21 pm    Post subject: Fuel Selector Reply with quote
Jason,
I can’t speak with authority on why not both tanks at once, but I would suspect you would still need a left/right only option as you will most certainly get a fuel imbalance over time due to a number of factors. I would be very hesitant to use an electric fuel valve, even if it does stay on one tank when failed, you may not realize you’ve lost control of the valve until you really need the fuel out of the other tank.
Marcus
Sent: Wednesday, December 10, 2008 1:15 PM
rnewman(at)tcwtech.com
PostPosted: Wed Dec 10, 2008 3:41 pm    Post subject: Fuel Selector Reply with quote
One of the issues regarding a "both" position for a fuel selector value on a low wing plane is as follows:
When a tank is low, and you turn in that direction you risk unporting that fuel pick up tube, with the selector set on both it will not draw from the tank that has its pick up tube nicely bathed in fuel. As an experiment try this, put two drinking straws in your mouth and drink some water out of two cups, pull one straw out of one of the cups of water while leaving the other straw submerged and try to suck on both straws, you'll get nothing but air, no water: that's how your engine would feel Sad
-bob newman
jkreidler
PostPosted: Wed Dec 10, 2008 5:57 pm    Post subject: Re: Fuel Selector Reply with quote
Bob, that makes sense.... Following that theory I have attached a picture of an experimental apparatus showing why I believe high wing aircraft are allowed to have a 'both' selection.
[quote="rnewman(at)tcwtech.com"]One of the issues regarding a "both" position for a fuel selector value on a low wing plane is as follows:
-bob newman
 Filesize:  5.8 KB
 Viewed:  9813 Time(s)
Jason Kreidler
PostPosted: Wed Dec 10, 2008 6:23 pm    Post subject: Fuel Selector Reply with quote
Ahh yes! a gravity fed system has no issues!
do not archive,
bob
pitts_pilot(at)bellsouth.
PostPosted: Wed Dec 10, 2008 7:31 pm    Post subject: Fuel Selector Reply with quote
-bob newman
I'm not so sure ..... but I don't want to be a test pilot!!! The straw
test fails because it isn't like our fuel system at all. Consider
this: I think we all agree that there's no problem in level flight. In
a truly coordinated turn there would be no difference from a level
flight condition due to the dihedral. In a slipping turn if there's
enough 'force' to cause the 'low' tank fuel to move toward the tip, then
the 'high' side has the same force and would (in the absence of engine
fuel flow) have head pressure and would tend to drain toward the low
tank. The reverse would also be true. As long as the engine doesn't
suck more fuel than would flow, then the 'low' port wouldn't 'unport'.
At least that's my reasoning. Show me where I went wrong!
Linn
PostPosted: Wed Dec 10, 2008 7:36 pm    Post subject: Fuel Selector Reply with quote
Sorry for the multiple posts .... clock screwed up again and I didn't catch
it! See below.
Linn
-bob newman
Linn
ricksked(at)embarqmail.co
PostPosted: Wed Dec 10, 2008 8:00 pm    Post subject: Fuel Selector Reply with quote
Umm...Just curious but is there something so complicated about Left-Right-Off that I'm missing? And unless you are using individual boost pumps per tank on a low wing setup...don't think your single boost pump will have the ummph to draw and provide adequate pressure off a two line system. The high wing aircraft have an age old solution to the "both" issue...it's called gravity, which if you go messing around with using a single boost pump, dual tank, low wing fuel system you may be introduced to that age old solution on terms that you may not like. Experiment away, just don't cause the rest of us to have to fight for our right to fly out of our local airports by screwing the pooch into a "congested" area.
Rick S.
40185
Paint prep
Liking the wheel just like it is, no need to reinvent!
partner14
PostPosted: Wed Dec 10, 2008 10:53 pm    Post subject: Fuel Selector Reply with quote
Rick, the supply line coming from the valve to the boost pump..... notice the verbage "line"..... not lines... it shouldn't matter whether you have 20 lines feeding into the valve, if you only have one going out. But I'm in total agreement with the scenario of running out in one tank before the other, the system would just suck air.
Don
--- On Wed, 12/10/08, Rick Sked <ricksked(at)embarqmail.com> wrote:
Subject: Re: Re: Fuel Selector
Date: Wednesday, December 10, 2008, 7:59 PM
--> RV10-List message posted by: Rick Sked <ricksked(at)embarqmail.com>
Rick S.
40185
Paint prep
Don A. McDonald
40636
Albert Gardner
PostPosted: Wed Dec 10, 2008 11:19 pm    Post subject: Fuel Selector Reply with quote
I once was doing a very aggressive slip in my RV-9A trying to show my wife
something one the ground on my side of the plane while sucking gas out of
the left tank. Suddenly, the loudest no-sound I ever heard when everything
was quite. Wings level, switch tanks, boost on, the fan started up. My wife
said, "Don't EVER do that again!" I'm leaving my valve as Left/Right/Off. As
far as I'm concerned, this wheel has been invented.
Albert Gardner
Yuma, AZ
RV-9A N872RV
RV-10 N991RV
msausen
PostPosted: Thu Dec 11, 2008 4:06 am    Post subject: Fuel Selector Reply with quote
The things that usually get me in the most trouble involve something motorized and the phrase "hey honey, check this out". Smile
jkreidler
PostPosted: Thu Dec 11, 2008 5:06 am    Post subject: Fuel Selector Reply with quote
Nearly the only thing that determines how hard a pump has to suck to get fuel is the difference in height between the outlet of the tank and the inlet of the engine. The lowest intake fuel port determines this number, not the number of lines.
Rick, there is nothing complicated at all about Left - Right - Off. That is why there has never been a pile of aluminum laying on the ground with one empty tank of fuel, and one not so empty tank of fuel adding to the fire. Please remind those families that there is nothing complicated about Left - Right - Off. The point of my question was simply to ask why it is done this way in low wing aircraft; I know there must be some reason I am missing, which Bob, Linn, and Albert helped me understand. I for one will never stop asking why things are done the way they are. I am happy to know that your airplane has been built 100% per plans, you are a flawless robot of a pilot, and are at no risk of making me have to fight for my right to fly out of my field. Mistakes happen, there are defects in material and workmanship, and sometimes luck just isn't on our sides. Fortunately we have places like this to ask simple questions like these to help us understand why. Your absolutely right, the wheel is perfect, that is why I can't figure out why we ever invented wooden wheels, rubber wheels, then wheels filled with air, the stone wheel was perfect, it rolled just fine. If it ain't broke don't fix it, I get it, but I need to understand how and why. Sorry.....
Thanks, Jason [quote][b]
Jason Kreidler
bhughes(at)qnsi.net
PostPosted: Thu Dec 11, 2008 5:11 am    Post subject: Fuel Selector Reply with quote
You can tie the tanks together with a transfer pump and timer. Requires one extra hole in your left tank unless you are already returning fuel back to the tank anyway. The cooling loop through the right tank is not needed with avgas.
Bobby
40116
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
DA40.pdf
 Filename:  DA40.pdf
 Filesize:  42.05 KB
 Downloaded:  413 Time(s)
PostPosted: Thu Dec 11, 2008 5:51 am    Post subject: Fuel Selector Reply with quote
Well, that blows my theory. Thanks Albert, for being our test pilot!!!
Wink
Linn .... hopefully with correct clock!!!
Albert Gardner
Yuma, AZ
PostPosted: Thu Dec 11, 2008 6:21 am    Post subject: Fuel Selector Reply with quote
True .... I use the term 'head pressure' a lot ...... but in the case of
a pump sucking uphill I'm at a loss for a term. Any ideas??
Well, remember that what I said was in theory ..... In Albert's case,
he unported his ONLY source of fuel at that point (I hope) since he
probably has a left/right/off selector. I didn't think of that when I
answered his email. The next time he does the slippy thing I'll bet
he'll at least select the 'inside' tank!!! Another educational
experience shared with the group.
I'm glad for that!!! I can't come up with all the questions!!! We're
all still learning .... it's just that some have learned more than
others. Your question was a good one ..... because the conventional
wisdom just may be 'urban legend'. Out very tough job is to separate
out the truth from the fiction (especially on a list) and arrive at a
safe, sound, reasonable answer. The answer to your question just might
have boiled down to: It's the 'safest' or 'simplest' or .....
whatever. I've never asked the question because I just accepted it.
why. Sorry.....
Hmmm. I detect a slight 'I been flamed' reaction. I have learned to
take what I perceive as a 'negative reaction' to an email with a grain
of salt. I just give the writer the benefit of the doubt and attribute
the 'nasty comment' to his having a bad day. Whether he had one or not
just doesn't matter. To me, he was, and I'm the one that counts!!! And,
it could have been ME that woke up on the wrong side of the bed .....
but I never do that!!! Wink
Linn
Thanks, Jason
Tim Olson
PostPosted: Thu Dec 11, 2008 7:02 am    Post subject: Fuel Selector Reply with quote
I for one am happy to have the left/right/off as an option. It
does one thing that a Both position doesn't....it ensures that
I have full control over knowing what quantity is left in each
of my tanks. With a both position, you may not know the exact
quantity in each tank. The pressure coming out of the tank
isn't just a function of the height of the tank outlet, but
a function of the height of the column of fuel above it, and
that column is a sloshing variable.
As for the un-porting of fuel, it's a real problem, which is
why many certified planes are placarded or have POH warnings
about minimum takeoff fuel and such. Coordinated approaches
are very important too, and while they teach you in your private
pilots course that you can choose between crabbing on final
and kicking the crab angle out at the last second, or slipping
to keep the nose aligned with the runway, you really have to
be wary of what you do when you're carrying less than 5 or
maybe even 10 gallons in a tank.
So that is why I personally love having just left/right/off,
and not both. I have a totalizer and two float gauges,
and can roughly mentally calculate my fuel levels that I
should have burned. Keeping them isolated helps me
ensure that I know more positively what my tanks hold.
Incidently, even in high-wing planes, I think the "both"
position perhaps promotes sloppy fuel management in some
cases. Myself, I don't have rarely....extremely rarely,
landed with less than 5 gallons of fuel in a tank. Maybe
only 2 or 3 times, and 2 of them where when I purposely
ran the tank dry having a near-full opposite tank. But,
when I am on a long flight, I alternate fuel tanks a couple
times during the flight and then as I get lower in quantity
I keep one tank set to arrive in the terminal area with
at least 10 gallons of fuel, whereas I don't mind at that
point if the other tank has only 5 or 6 gallons left.
But, being conservative, there have actually been very few
times I've landed with under 16-18 gallons, because I set
my high alarm to go off at 7 gallons per side. Fuel and
spark are the 2 most important things to making it safely
to the ground, as far as I can tell.
It's funny that experimentals have such a nasty accident
rate in the "fuel management" category. I can only
wonder if this is because people tend to try to experiment
on their fuel system, rather than just going with the old
proven methods.
Sorry.....
Thanks, Jason
PostPosted: Thu Dec 11, 2008 7:29 am    Post subject: Fuel Selector Reply with quote
Thanks for posting that Tim,
It's kinda what I was trying to say but not as well written.
There are certain things I feel you just shouldn't with, especially if it's not broke although I did use steel braided flex lines on my -10 but they have been proven to be reliable and I plan to have them on a time change item on my condition inmspections. If I were to do it again I may have only used the flex line from the fuselage side to the tank. It would be easier to replace. I think we need to just make sure we do it better than the certified fleet sometimes. The fiasco here in Vegas is a good reason for that. I was talking to an owner of a Aerocommander this weekend and he was so frustrated at the shop performing work on his aircraft, he went in and found a "kid", maybe 19 in his words "hacking" on his airplane. The shop has three "mechanics" and one A&P/ with IA that "supervises" all the others who are not certified. He was upset about the fact he is paying top dollar for A&P services but in the end, the A&P only makes sure it was done right and signs it off. Now I was a 19 year old aircraft mechanic at one point but I would bet that I had much more training and I know I had more direct supervsion than what was being described to me last weekend. The twin Baron (I think it was a Baron) that went down had very recently been in the shop for engine work...but they continue to focus on the experimental and student pilots as the high risk activities. I can only recall one accident related to training and that was few years ago and was the result of a stall spin after the engine failed during of all things..engine out procedures. I can tell you there have been a bunch of incidents related to certifed aircraft and I know of no other incidents except the Velocity for exp[erimentals at VGT. Guess I rambled but we can't afford to not do it better than everyone else when it comes to experimental aviation. The fuel management issue still amazes me because a large percentage of that is a result of flying with air in the tanks.
Rick S.
40185
Tim Olson
PostPosted: Thu Dec 11, 2008 8:02 am    Post subject: Fuel Selector Reply with quote
Regarding the braided lines....I don't think that in that
case it's quite the same as changing the fuel distribution
method. With the lines, I actually think there's a good
argument that the braided lines will be more reliable
and basically immune to flex fatigue cracking, whereas
there are many of us who found first-hand that there have
been bad batches of aluminum tubing from Van's in that
3/8" size. (and even the good batches aren't necessarily
all that fantastic) I think that probably the best
someone can do would be to use conductive teflon lines
that are overbraided with stainless and have anti-chafe
covering. That would probably be the ideal. The
drawback to the braided lines is just weight. The
additional drawback to the various rubber type braided
lines is even more weight, and a life limit. But those
things aren't really in the same ballpark as some of
the other mods. After all, what kind of lines are used
from the firewall forward? No matter what kind of lines
are used, they need protection, and need to be well
secured. I actually plan at some point to replace
my lines with braided conductive teflon, and go all
the way from tank to firewall that way with some
exceptions.
Regarding that maintenance fiasco, I think that's
just another example of how businesses react with payroll
when the economy tightens...not to mention our ever
decreasing worker quality that the country produces.
It amazes me how poor the work ethic is in many of
the people that are turned out today. I know when
we go hiring, the "Good help is hard to find" saying
really holds true. Funny that unemployment is starting
to be such a big thing again, yet around here we
really have trouble finding top notch skills.
Sorry for the rambling, but yep Rick, you're
preaching to the choir. If the news could only
be balanced and give perspective to crash reporting,
people would have an entirely different opinion
about flying.
It's kinda what I was trying to say but not as well written. There
was done right and signs it off. Now I w! as a 19 year old aircraft
Rick S. 40185 do not archive
