Radio Noise-Starter switch??
bakerocb
PostPosted: Sun Mar 12, 2006 12:59 pm    Post subject: Radio Noise-Starter switch?? Reply with quote
I have some random radio noise I can't explain. It ranges from
sharp"cracks' to static to every thing in between. Sometimes it is normal
quiet. I have had the radio checked, and it's fine. I don't believe it is
alternator related.
I have a recollection of past correspondence re. the ACS starter switch as
being a radio related problem. True?? Ant tips out there??
Yours for warmer weather flying.
Thanks in advance--Jim Lagowski
nuckollsr(at)cox.net
PostPosted: Mon Mar 13, 2006 8:29 pm    Post subject: Radio Noise-Starter switch?? Reply with quote
> alternator related.
The only hassle I'm aware of concerning the ACS/Bendix OFF/L/R/BOTH/START
switch has to do with internal contact erosion due to the
collapse of the magnetic field in a modern high-force starter
contactor or two stage starter contactor. See:
http://aeroelectric.com/articles/strtctr.pdf
I can't imagine how this switch would have any radio
noise issues.
