Center Y stick
ter_turn(at)yahoo.com
PostPosted: Thu Nov 20, 2008 7:04 pm    Post subject: Center Y stick Reply with quote
Hey builders, question. On 6-B-17 "4" Control stick torque tube where the control column bolts onto the torque tube through the 1/4 in. bushing within a 3/8 in.welded bushing, what are the two bearing surfaces. The two bushings or the bolt and small bushing? Hey, you think I've just confused you!!
Terry Turnquist
601-XL-Plans
St. Peters MO
bryanmmartin
PostPosted: Fri Nov 21, 2008 1:58 pm    Post subject: Center Y stick Reply with quote
The bolt and nut should tighten down on the 1/4" bushing, holding it
immobile. Then the two bushings act as bearing surfaces.
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
Bryan Martin
do not archive.
