Cable load on rear rib 7
dalemed
PostPosted: Sat Nov 08, 2008 12:57 pm    Post subject: Cable load on rear rib 7 Reply with quote
I'm in the process of attaching the Bellcrank Support and Bellcrank Support Channel to Rear Rib 7. I can't help but wonder how RR7 supports 70 (+/-10) lbs of cable force (each cable pulling with 30 (+/-5) lbs.).
It's Saturday or I'd call the factory to ask them if it might be wise to add L angle doublers to the Bellcrank Support Channel.
Am I unnecessarily concerned?
Dale
Zenith Zodiac CH650
leo(at)zuehlfield.com
PostPosted: Sat Nov 08, 2008 1:33 pm    Post subject: Cable load on rear rib 7 Reply with quote
I believe that is only 30 +/- 5 lbs pull on the rib.
Dale
Flying Cessna 170B
Building Zenith 601XL
Leo Gates
N601Z - CH601HDS TDO
Rotax 912UL
Gig Giacona
PostPosted: Sat Nov 08, 2008 1:58 pm    Post subject: Re: Cable load on rear rib 7 Reply with quote
I don't think it would create a combined load like that because the other end is also dealing with half of the tension. It is just 30 (+/-5) lbs.
W.R. "Gig" Giacona
601XL Under Construction
pavel569
PostPosted: Sun Nov 09, 2008 5:26 am    Post subject: Re: Cable load on rear rib 7 Reply with quote
It seems that very soon we will be questioning every single rivet on the plane that is flying in numbers for years already. Keep building according to plans and we'll be fine, IMHO.
Before I riveted the rudder together, I just wondered how this sheet of zerozeronothing aluminum can turn the plane. Try to bend your rudder after its done Wink
Pavel
CA
Zodiac 601XL
Stratus Subaru EA-81
Tail, flaps, ailerons, wings, fuselage, canopy done ...
"do not archive"
bryanmmartin
PostPosted: Sun Nov 09, 2008 11:17 am    Post subject: Cable load on rear rib 7 Reply with quote
Yes, you are being unnecessarily concerned. It may look flimsy with just the skeleton laying there in your workbench but you'll be amazed how much more solid everything gets after the skins get riveted on. I've never heard of any problems in that area and the fleet has accumulated thousands of hours. Build it to plans and fight the urge to add structure and weight where none is needed. You would also be amazed at how quickly those little modifications can add excess weight to the final assembly.
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
Bryan Martin
do not archive.
dalemed
PostPosted: Sun Nov 09, 2008 12:35 pm    Post subject: Re: Cable load on rear rib 7 Reply with quote
I obviously have a problem with addition - 30+30=60, not 70 lbs. However, I think the rib really does see 60 lbs of force (30 lbs each cable).
Thanks to everyone who's reminded me that a lot of planes have flown for a lot of hours with this design without problems. I'll just go back to building Smile
Dale
Zenith Zodiac CH650
