Market Survey Phase II
nuckollsr(at)cox.net
PostPosted: Sat Mar 11, 2006 7:19 am    Post subject: Market Survey Phase II Reply with quote
Okay, the list is pretty complete. Now what I need
is your ranking of priorities for items on the list.
FORWARD your response to me directly at nuckollsr(at)cox.net
instead of to the List. We don't want go snow the list
with a lot of anecdotal posts. Further, I know there are
lots of folks who watch this list that seldom if ever post
to the list. Please give me the benefit of your inputs too.
I need at least 30 and hopefully 50 or more responses to make it
a statistically significant survey. Just add numbers after
the items on the list in order of priority, #1 being highest.
Go out to as many as 20 but the first 9 are most important
followed by the next 3.
I'll wait about a week and then tabulate the data for
publication on the list. If you have any questions as to the
meaning of any item, email me directly.
The wish list now stands at:
Main Volts Lo
Aux Volts Lo
Left Fuel Lo
Right Fuel Lo
Oil Pres Lo
Fuel Pres Lo
Canopy Latch
OAT Warn
Pitot Heat
Coolant Temp
Coolant Pres
Coolant Low
Oil Temp
Turbo (control malfunction) (yellow)
Boost pump ON (white)
Fire
Flaps Warn
Fuel Pump ON
Starter engaged
P-Mag Maint
Prop Overspeed
Gear extension Warning
Nose Gear
Lt Mn Gear
Rt Mn Gear
Boost Pump
Baggage Door
Ground Power
Chip Detect
BVC Fault
Anti-Ice
Fuel Filter
Oil Filter
Crossfeed closed
< What is so wonderful about scientific truth...is that >
< the authority which determines whether there can be >
< debate or not does not reside in some fraternity of >
< scientists; nor is it divine. The authority rests >
< with experiment. >
< --Lawrence M. Krauss >
George W Braly
PostPosted: Sat Mar 11, 2006 10:22 am    Post subject: Market Survey Phase II Reply with quote
I think it might be better to, initially, group the items into HIGH,
MED, LOW priority.
I have added a category for " ? " because either I don't understand
it, or because it would totally depend upon the installation specific
criticality of the function to be alarmed.
H = HIGH priority, M = Medium, L = Low, as follows.
H Main Volts Lo
M Aux Volts Lo
M Left Fuel Lo
M Right Fuel Lo
H Oil Pres Lo
H Fuel Pres Lo
? Canopy Latch
L OAT Warn
L Pitot Heat
H Coolant Temp
H Coolant Pres
H Coolant Low
H Oil Temp
M Turbo (control malfunction) (yellow)
L Boost pump ON (white)
H Fire
L Flaps Warn
L Fuel Pump ON
H Starter engaged
L P-Mag Maint
L Prop Overspeed
H Gear extension Warning
H Nose Gear
H Lt Mn Gear
H Rt Mn Gear
L Boost Pump
? Baggage Door
L Ground Power
H ? Chip Detect
? BVC Fault
? Anti-Ice
? Fuel Filter
L Oil Filter
? Crossfeed closed
skywagon
PostPosted: Sat Mar 11, 2006 2:32 pm    Post subject: Market Survey Phase II Reply with quote
I like George's category suggestion and offer my priorities.
David
H Main Volts Lo
H Main Volts Hi
L Aux Volts Lo
L Left Fuel Lo
L Right Fuel Lo
H Oil Pres Lo
H Fuel Pres Lo
? Canopy Latch
L OAT Warn
L Pitot Heat
? Coolant Temp
? Coolant Pres
? Coolant Low
H Oil Temp Hi
H Fire
L Flaps Warn
H Fuel Pump ON
H Starter engaged
L P-Mag Maint
L Prop Overspeed
H Nose Gear
H Lt Mn Gear
H Rt Mn Gear
H Boost Pump
? Baggage Door
L Ground Power
H ? Chip Detect
? BVC Fault
? Anti-Ice
? Fuel Filter
L Oil Filter
? Crossfeed closed
PostPosted: Sat Mar 11, 2006 3:43 pm    Post subject: Market Survey Phase II Reply with quote
Understand, but not helpful. If one is going to do a statistical
analysis on data, the data have to be offered in the same form by
every participant. What I need is a 1 to 12 listing of the most important
items. If you want to call your "H" items 1-4 and "M" items 5-7 and
"L" times 8-12, that's fine too but the responses useful to me will
be numbered.
It's interesting that out of the 10 responses received so far, only
4 are useful to the task at hand.
David
> H Main Volts Lo
H Main Volts Hi
> L Aux Volts Lo
> L Left Fuel Lo
> L Right Fuel Lo
> H Oil Pres Lo
> H Fuel Pres Lo
> ? Canopy Latch
> L OAT Warn
> L Pitot Heat
> ? Coolant Temp
> ? Coolant Pres
> ? Coolant Low
> H Oil Temp Hi
> H Fire
> L Flaps Warn
> H Fuel Pump ON
> H Starter engaged
> L P-Mag Maint
> L Prop Overspeed
> H Nose Gear
> H Lt Mn Gear
> H Rt Mn Gear
> H Boost Pump
> ? Baggage Door
> L Ground Power
> H ? Chip Detect
> ? BVC Fault
> ? Anti-Ice
> ? Fuel Filter
> L Oil Filter
> ? Crossfeed closed
