Posted: Wed Oct 22, 2008 1:32 pm Post subject: CH601XL roll sensitivity & aileron control weight |
Hi Kevin,
The aileron movement might be a little stiffer in roll because they
depend on flexing the .016 aluminum rather than hinges.
Cables should not be too tight, but nearer 20-25 lbs rather than
commercial aircraft 30-40 lbs. Likely it's the Zenith flex hinge
but you can remove that if it was done right and put in regular hinges
if you want. With the larger span, I'd expect the XL to
be a little more drawn out on roll response. And yes, the elevator is
pitch sensitive, but you do get comfortable with that quickly..
kevstewart wrote:
Quote: |
Hi All,
I need some advice. Today I flew a very nicely finished XL (with a view to buying it) that has recently had the Y stick changed to the dual sticks.
I have never flown a 601 before but I noted that the aircraft was quite sensitive in pitch on the elevators but very heavy in roll on the ailerons. Is this normal?
I noted on the ground that the aileron movement from the P2 position may have been heavier than from the P1 position.
Is it rigged too tightly or is this just how it is?
Any advice gratefully received.
Kevin
| - The Matronics Zenith601-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
ideaz1(at)sbcglobal.net Guest
Posted: Wed Oct 22, 2008 1:43 pm Post subject: CH601XL roll sensitivity & aileron control weight |
Hi Kevin, I am just starting building (from scratch) an XL and I recently
got checked out in a factory version and indeed the aileron control was very
heavy to the point where I have borrowed a set of RV6 plans to copy their
ailerons whitch are the lightest and smothest I've ever flown. If you're
planning buying a finished plane it might be possible to modify the ailerons
but could be a lot of work.
As this is my 3rd homebuilt I hae learned that the main reason for the heavy
ailerons is that they are not balanced. That means that the hinges are at
the very front of the aileron. If you look at other designs, especially
aerobatic planes the hinge point may be as much as 25% rear of the leading
edge. The effect of this is when deflcted the leading edge pressure offsets
the trailing edge pressure, in the most extreme cases there is literally 0
pressure required at the stick.
Hope thats not too much info, and if not enough, let me know...
Dirk Z
Carson City, Nv. USA
Hi All,
Kevin
Recreational pilot flying out of
EGHD Plymouth, UK.
Posted: Wed Oct 22, 2008 1:51 pm Post subject: CH601XL roll sensitivity & aileron control weight |
