C-90 or 0-200 cam.
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Engines-List
fltrbg(at)yahoo.com
PostPosted: Fri Mar 10, 2006 7:12 pm    Post subject: C-90 or 0-200 cam. Reply with quote
Hello all,
I'm about to begin re-assembly of a C-90 and I have both the C-90 and 0-200 cams available.I'd like some advice as to which one to use.
Is it preferable to use the C-90 cam with a slightly higher pitch prop,or the 0-200 cam with less pitch prop to allow higher RPM.The plane that it will power has about 100 mph cruise and I'm trying to maximize short field performance.
Thanks in advance for any advice,
John Koning
C-FGCC
Stits Flut-r-bug.
- The Matronics Engines-List Email Forum -
http://www.matronics.com/Navigator?Engines-List
jrccea(at)bellsouth.net
PostPosted: Fri Mar 10, 2006 9:30 pm    Post subject: C-90 or 0-200 cam. Reply with quote
The 90 with a relatively flat pitch will give you better takeoff and climb
(you won't be able to reach maximum rater rpm with either engine or prop).
The 90 does better at lower rpm.
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Engines-List All times are GMT - 8 Hours
