Marketing research question Annunciated Parameters List
nuckollsr(at)cox.net
PostPosted: Thu Mar 09, 2006 6:57 am    Post subject: Marketing research question Annunciated Parameters List Reply with quote
Just for grins, I'll toss the question out to the list.
From of the list items below, what additional or alternative
points of interest might be important enough to light a light
and/or blow in your ear?
The wish list now stands at:
Main Volts Lo
Aux Volts Lo
Left Fuel Lo
Right Fuel Lo
Oil Pres Lo
Canopy Latch
OAT Warn
Pitot Heat
Coolant Temp
Coolant Pres
Coolant Low
Oil Temp
< with experiment. >
< --Lawrence M. Krauss >
mark.steitle(at)austin.ut
PostPosted: Thu Mar 09, 2006 9:33 am    Post subject: Marketing research question Annunciated Parameters List Reply with quote
Bob,
This seems a good time to bring this up. My Chevy p/u has a cool little
"message center" that tells me that its time to change oil, or that the
cargo light is on, etc. It is about 1.5" square. I was wondering if it
would be possible to adapt this to experimental a/c use as a compact
annunciator? I don't have a clue as to how it works, but I thought that
it may be possible to get one from GM, or out of a wreck, and then
program a PIC to provide customized alerts for various things of
interest. It appears to use some sort of LED panel with yellow
lettering. So, does this sound plausible? Has anyone on the list done
this? Am I nuts?
Mark S.
Bret Smith
PostPosted: Thu Mar 09, 2006 9:48 am    Post subject: Marketing research question Annunciated Parameters List Reply with quote
How about a simple "Master ON" reminder?
Bret
Bret Smith
RV-9A (Emp)
khorton01(at)rogers.com
PostPosted: Thu Mar 09, 2006 1:05 pm    Post subject: Marketing research question Annunciated Parameters List Reply with quote
Fuel Pres Lo
Engine (output from an engine monitor, to tell you to look at it to
see what problem it has found).
Kevin Horton
On 9 Mar 2006, at 09:56, Robert L. Nuckolls, III wrote:
<nuckollsr(at)cox.net>
Main Volts Lo
Aux Volts Lo
Left Fuel Lo
Right Fuel Lo
Oil Pres Lo
Canopy Latch
OAT Warn
Pitot Heat
Coolant Temp
Coolant Pres
Coolant Low
Oil Temp
schamber(at)glasgow-ky.co
PostPosted: Thu Mar 09, 2006 5:21 pm    Post subject: Marketing research question Annunciated Parameters List Reply with quote
gear
Jerry Cochran
PostPosted: Fri Mar 10, 2006 12:20 pm    Post subject: Marketing research question Annunciated Parameters List Reply with quote
I would love to have fuel pressure.
Jerry
Subject: RE: Marketing research question Annunciated
Parameters List
Main Volts Lo
Aux Volts Lo
Left Fuel Lo
Right Fuel Lo
Oil Pres Lo
Canopy Latch
OAT Warn
Pitot Heat
Coolant Temp
Coolant Pres
Coolant Low
Oil Temp
highflight1(at)gmail.com
PostPosted: Fri Mar 10, 2006 12:52 pm    Post subject: Marketing research question Annunciated Parameters List Reply with quote
Without stating what I'M going to use for annunciators because I haven't
decided yet, I am thinking of these things so I'll simply add that:
I've seen some people install a "Starter" warning light in case the starter
hangs. That might warrant a red warning light as well.
If you're more paranoid, you might be someone who installs an oil level
sending unit so you could have a warning for "Low Oil".
But there's also some annunciators that are just status annuniators so you
would want them to be Blue or Green or some other non heart pounding color.
These just remind you that you are running these devices so you don't forget
to turn them off when you don't need them.
Like:
"Aux. Batt." (when the secondary battery is in the loop)
"Flaps" (in any position other than up)
"Landing Lights"
"Fuel Pump" to remind you when you have the electric fuel pump turned on.
"Nav Lights"
"Ipod Batt. Low" although you might want to make this a RED alert light.
The only thing limiting annunciation is imagination and panel space. Smile
Vern W.
