Rear Heat Duct (Scat Tube) - SOLUTION
Goto page 1, 2  Next
partner14
PostPosted: Wed Oct 08, 2008 12:28 pm    Post subject: Rear Heat Duct (Scat Tube) - SOLUTION Reply with quote
OK, guys, this is Don, the harness and headset bracket guy.... anyone interested in the perfect solution to this problem. My brother is designing and then will make a plenim type system that will slip right over the fuel selector valve on both sides, then convert back to the 2" round to match up to the scat tubing. The total area will be slightly more than the original scat.... not counting if you do it like Van's suggest, and smash it. A little rubber on the bottom and top, and it will be held perfectly in place. Just let me know how many would be interested. Will have pictures of a completed part within a week or so.
Don
--- On Wed, 10/8/08, AirMike <Mikeabel(at)Pacbell.net> wrote:
Subject: Re: Rear Heat Duct (Scat Tube)
Date: Wednesday, October 8, 2008, 9:49 AM
--> RV10-List message posted by: "AirMike"
I wound up taking Aaron's suggestion and routing the line under the fuel
valve. Worried about chafe, and took some measure to prevent it. Thanks again to
all the great suggestions. I do not think that I could get through this project
without this web site. Remember Matt when it is time for his annual donation.
OSH '08 or Bust (busted) be there in &quot;09
Q/B Kit - wiring and FWF
http://forums.matronics.com/viewtopic.php?p 7912#207912
Don A. McDonald
40636
rickbarnes(at)highlandden
PostPosted: Wed Oct 08, 2008 1:06 pm    Post subject: Rear Heat Duct (Scat Tube) - SOLUTION Reply with quote
We’re with Tim. If you wrap the tube with a thin heat barrier type fabric you can run it anywhere in the tunnel. We’re using a product from http://www.chapmaninnovations.com/. You can use the product on the firewall too.
Rick
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Don McDonald
Sent: Wednesday, October 08, 2008 2:27 PM
Subject: Re: Re: Rear Heat Duct (Scat Tube) - SOLUTION
Don
--> RV10-List message posted by: "AirMike"<Mikeabel(at)Pacbell.net> I wound up taking Aaron's suggestion and routing the line under the fuelvalve. Worried about chafe, and took some measure to prevent it. Thanks again toall the great suggestions. I do not think that I could get through this projectwithout this web site. Remember Matt when it is time for his annual donation. --------OSH '08 or Bust (busted) be there in &quot;09<Mikeabel(at)Pacbell.net>
5
6
7
8
9
AV8ORJWC
PostPosted: Wed Oct 08, 2008 2:37 pm    Post subject: Rear Heat Duct (Scat Tube) - SOLUTION Reply with quote
Cox is in for Two Sets.
John Cox - #40600
Sent: Wednesday, October 08, 2008 1:27 PM
Don
5
6
7
8
9
8[quote]http://www.matronics.com/Navigator?RV10-Listhttp://forums.matronics.comhttp://www.matronics.com/contribution [b]
patrick.pulis(at)seagas.c
PostPosted: Wed Oct 08, 2008 3:51 pm    Post subject: Rear Heat Duct (Scat Tube) - SOLUTION Reply with quote
fixitauto(at)aol.com
PostPosted: Wed Oct 08, 2008 4:28 pm    Post subject: Rear Heat Duct (Scat Tube) - SOLUTION Reply with quote
I would like one also.
Kelly McMullen
PostPosted: Wed Oct 08, 2008 4:57 pm    Post subject: Rear Heat Duct (Scat Tube) - SOLUTION Reply with quote
I'll take one.
Kelly
On Wed, Oct 8, 2008 at 1:27 PM, Don McDonald <building_partner(at)yahoo.com> wrote:
Don
again to
project
donation.
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
johngoodman
PostPosted: Thu Oct 09, 2008 4:50 am    Post subject: Re: Rear Heat Duct (Scat Tube) - SOLUTION Reply with quote
Don,
Count me in for one as well. I've been trying to fabricate something like that for the past few days and keep running into problems with materials.
davidbowman1(at)verizon.n
PostPosted: Thu Oct 09, 2008 9:38 am    Post subject: Rear Heat Duct (Scat Tube) - SOLUTION Reply with quote
I'm in for one
Bowman-40831
DLIUDVINAITIS(at)aol.com
PostPosted: Thu Oct 09, 2008 11:30 am    Post subject: Rear Heat Duct (Scat Tube) - SOLUTION Reply with quote
count me in for one
DLUDD #40466
In a message dated 10/9/2008 12:40:42 P.M. Central Daylight Time, davidbowman1(at)verizon.net writes:
[quote] I'm in for one
Bowman-40831
ron.mcgann(at)baesystems.
PostPosted: Thu Oct 09, 2008 1:32 pm    Post subject: Rear Heat Duct (Scat Tube) - SOLUTION Reply with quote
Don - I'm interested too but will wait for pictures.
cheers,
Ron
[quote] From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Don McDonald
Sent: Thursday, 9 October 2008 6:57 AM
Don
http://forums.matronics.com/viewtopic.php?p=207912#207912
"'>http://www.matronics.com/Navigator?RV10-List
matronics.com
"Warning:
The information contained in this email and any attached files is
confidential to BAE Systems Australia. If you are not the intended
recipient, any use, disclosure or copying of this email or any
attachments is expressly prohibited. If you have received this email
in error, please notify us immediately. VIRUS: Every care has been
taken to ensure this email and its attachments are virus free,
however, any loss or damage incurred in using this email is not the
sender's responsibility. It is your responsibility to ensure virus
checks are completed before installing any data sent in this email to
your computer."
whadath(at)rogers.com
PostPosted: Fri Oct 10, 2008 3:54 am    Post subject: Rear Heat Duct (Scat Tube) - SOLUTION Reply with quote
Am interested too but would like to see pictures.
Wayne
F1 Rocket 290 hrs
SARL Racer 14
Checked by AVG.
08/10/2008 7:01 AM
partner14
PostPosted: Fri Oct 10, 2008 7:45 am    Post subject: Rear Heat Duct (Scat Tube) - SOLUTION Reply with quote
OK Wayne, pictures it is.... when we get er done. Unfortunetely, there's no easy way to make this one.... welding necessary. But I'll guarantee that it'll look cool and work perfectly.
As an F1 pilot, thought you might like this photo of my project. (scoop)
Don McDonald
#40636
Finishing the finishing
--- On Fri, 10/10/08, Wayne Hadath <whadath(at)rogers.com> wrote:
Subject: Re: Rear Heat Duct (Scat Tube) - SOLUTION
Date: Friday, October 10, 2008, 4:52 AM
Wayne
F1 Rocket 290 hrs
SARL Racer 14
Checked by AVG.
08/10/2008 7:01 AM
 Filesize:  106.2 KB
 Viewed:  291 Time(s)
Don A. McDonald
40636
jesse(at)saintaviation.co
PostPosted: Fri Oct 10, 2008 8:06 am    Post subject: Rear Heat Duct (Scat Tube) - SOLUTION Reply with quote
Do you have any idea of what it will cost. I would definitely be interested. Will it be aluminum or stainless?
Jesse Saint
Saint Aviation, Inc.
Cell: 352-427-0285
Fax: 815-377-3694
Don McDonald
#40636
--- On Fri, 10/10/08, Wayne Hadath <whadath(at)rogers.com (whadath(at)rogers.com)> wrote:
From: Wayne Hadath <whadath(at)rogers.com (whadath(at)rogers.com)>
Wayne
F1 Rocket 290 hrs
SARL Racer 14
Checked by AVG.
08/10/2008 7:01 AM
<IMG_2263c.jpg>
partner14
PostPosted: Sun Oct 12, 2008 11:33 am    Post subject: Rear Heat Duct (Scat Tube) - SOLUTION Reply with quote
Cost is a good question.... just like the other brackets I offered up to all the guys building, the idea is to provide them, not make a living. Because of the welding involved, at shop rate, and of course, depending on how many we make, the cost could be $150 for one... but since that one would be mine, it would be free!!! My brothers company has some of the best welders in the country, and they have built many parts used by Lockeed, Aerojet, etc, even parts that have been to the moon.
Hopefully, we can keep the PRICE low enough to make it worthwhile for everyone. Notice, I didn't say cost....
I'll try and get them to produce 20 of them and I'll guess and say the price would then be below $50.
Will keep everyone informed.
Aluminum, will be the material.
Don
Date: Friday, October 10, 2008, 9:06 AM
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
Don McDonald
#40636
Wayne
F1 Rocket 290 hrs
SARL Racer 14
Checked by AVG.
08/10/2008 7:01 AM
<IMG_2263c.jpg>
Don A. McDonald
40636
partner14
PostPosted: Mon Oct 13, 2008 5:16 pm    Post subject: Re: Rear Heat Duct (Scat Tube) - SOLUTION Reply with quote
OK guys here it is. Still not sure of the cost/price. It has about 40 minutes of welding, not counting any time for shearing, and the brake work. Definitely over $50, but certainly under $100. We'll do the best we can..promise.. but boy is that a nice piece!
If we get one done, I'll bring it to Copperstate.
Don McDonald
If interested make sure I get your mailing address.
and..... I'm so sorry if the file is too big.... get a bigger computer. I did compress it.
 Filesize:  13.48 KB
 Viewed:  309 Time(s)
Don A. McDonald
40636
msausen
PostPosted: Mon Oct 13, 2008 5:50 pm    Post subject: Rear Heat Duct (Scat Tube) - SOLUTION Reply with quote
Whew, that much welding and throwing in bending for under $100 out the door!?! I need to get me some of the fabricators you have access to for that price!
Michael
ricksked(at)embarqmail.co
PostPosted: Mon Oct 13, 2008 6:12 pm    Post subject: Rear Heat Duct (Scat Tube) - SOLUTION Reply with quote
Nice piece Don,
The price is smokin if anyone knows what this type of work costs...I can't use it though, I used the standard Andair mounted to the top of the tunnel with braided lines run to one side of the tunnel and the scat run to the other side. If it is designed to use the standard Vans CRAPPO valve, (I know some love that boiler equipment) or the Andair with the handle extension it looks like the way to go...
Rick Sked
40185
PostPosted: Mon Oct 13, 2008 6:18 pm    Post subject: Rear Heat Duct (Scat Tube) - SOLUTION Reply with quote
Ummm... yeah...how much do those 12 year old welders get an hour?
Tim Olson
PostPosted: Mon Oct 13, 2008 6:46 pm    Post subject: Rear Heat Duct (Scat Tube) - SOLUTION Reply with quote
Do you have a drawing showing how the fuel valve fits into the picture?
Does this require the Andair valve or the standard valve or either?
If it's the andair valve, I can see that the stem fits through the hole
and I think with some shielding you can keep the heat off the valve,
BUT you're probably going to want to wrap the whole plenum in the
reflective insulation. If it's for the standard valve I can't see
exactly how the heat is kept away. I found a significant amount of
heat is spread to the seat area through the tunnel when the rear
heat was turned on...and that it was significantly lessened once I
wrapped completely my SCAT tubing and the aluminum T's with the
reflective insulation. So having an aluminum plenum might make it
easy to direct airflow, but it may become a very large heat box
to heat the fuel valve and tunnel unless the builder takes the
precaution to insulate the plenum.
I know personally that the whole tunnel top will get pretty warm
with the rear heat on with an uninsulated SCAT tube. I also know
that from talking to a couple other builders with lots of hours
on their planes like I have, that during extended climbs there is
some sort of issue going on with the fuel system...probably vapor
in the system, that causes reduced fuel pressure. Climbs of
maybe 6000' or more. I haven't figured out if this is on the
forward side of the firewall, or the aft, but keeping the entire
fuel system as cool as possible is an important thing. Just would
like to get an idea how this fits around the valve, to know if
it has any need for added heat shielding.
the best we can..promise.. but boy is that a nice piece! If we get
one done, I'll bring it to Copperstate. Don McDonald
-------- Don A. McDonald 40636
http://forums.matronics.com/viewtopic.php?p 8629#208629
http://forums.matronics.com//files/heater_plenumc_797.jpg
partner14
PostPosted: Mon Oct 13, 2008 9:07 pm    Post subject: Rear Heat Duct (Scat Tube) - SOLUTION Reply with quote
Thanks Rick.
--- On Mon, 10/13/08, Rick Sked <ricksked(at)embarqmail.com> wrote:
[quote]From: Rick Sked <ricksked(at)embarqmail.com>
Date: Monday, October 13, 2008, 7:10 PM
[quote]--> RV10-List message posted by: Rick Sked <ricksked(at)embarqmail.com> Nice piece Don, The price is smokin if anyone knows what this type of work costs...I can't use it though, I used the standard Andair mounted to the top of the tunnel with braided lines run to one side of the tunnel and the scat run to the other side. If it is designed to use the standard Vans CRAPPO valve, (I know some love that boiler equipment) or the Andair with the handle extension it looks like the way to go... Rick Sked 40185 ---
Don A. McDonald
40636
Goto page 1, 2  Next
Page 1 of 2
