Float Flyr
Posted: Thu Sep 04, 2008 4:48 am Post subject: Floats with the new exhaust pipe. |
Dave:
Do you have any video to compare take off with and without your new pipe on
the 582?
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
dave
Posted: Thu Sep 04, 2008 11:56 am Post subject: Re: Floats with the new exhaust pipe. |
| Quote: | Dave:
the 582?
Noel |
Nope, only documentation I can tell you is that oN a GSC prop I run + 2 degrees more pitch that with Stock skystar exhaust. Also the fuel burn seems a bit less ( about 1/2 gallon /hour) less and with more power.
The pipe is very tight inside the cowl but it works well. power band starts about 4800 to 5200 rpm. I am keeping it conservative to ensure the engine has a long life. A 582 you can get about 80 hp out of but life will be shortened and fuel burn would go up. Rotax exhaust makes the 582 run a bit rich with the Mods that Skystar did to the exhaust and hence it had likely about 56 to 58 HP i figure. I would figure that I am around 65 to 68 hp here.
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Float Flyr
Posted: Fri Sep 05, 2008 4:12 am Post subject: Floats with the new exhaust pipe. |
Thanks Dave.
2 deg. Is a lot of pitch so I can see the power increase must have been
considerable.
I was looking at the vid of the L'iLL Buzzard. Certainly doesn't seem to
clear the runway as fast as the 'Fox. Has anyone put one on floats yet?
Noel
Kitfox III-A
akflyer
Posted: Sat Sep 06, 2008 4:51 am Post subject: Re: Floats with the new exhaust pipe. |
I was looking at buying a lil buzzard before I found my Avid. I sent countless emails and left more messages on their answering machine than I did on Airdales, did not get one single return call. I was ready to go buy 3 of them for me and two buddies.. Looks like a nice bird at a great price, but after 7 months of no contact, I forgot about them.
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
