Stabiliser ribs question
Jugle
PostPosted: Fri Aug 01, 2008 11:29 pm    Post subject: Stabiliser ribs question Reply with quote
Hi folks,
I'm wondering how you scratchbuilders went with the stab ribs end flanges.
I made mine some time ago and am at the stage of assembling the skeleton.
What I found was that the height of the end flanges needed a good 3mm trimmed off the top and bottom to fit inside the spar flanges to clear the inside radius. Not a huge problem, but this meant my relief holes had to be opened out to be quite large and elongated.
What did you find?
Glenn.
Glenn Andressen
601XL- Rudder, Stabiliser parts completed, Wing ribs, nose ribs done, 70% Fuselage parts made.
rsteele(at)rjsit.com
PostPosted: Sat Aug 02, 2008 6:02 am    Post subject: Stabiliser ribs question Reply with quote
Sorry, no help but a point of reference: I built mine from a kit, but
damaged on of the Stab ribs and so fabricated one from the plans. I
found that if fit perfectly.
