Alternator for NSI EA81
Clem Nichols
PostPosted: Fri Aug 01, 2008 10:10 am    Post subject: Alternator for NSI EA81 Reply with quote
I've a buddy who needs a replacement alternator in his NSI EA81 powered Kitfox. The data plate is missing from his, and the owners manual says it's a Nippon Denso 38 amp alternator with a built in voltage regulator. Googling for this particular model has not produced any satisfactory results. Any help will be appreciated.
CN
pwmac(at)sisna.com
PostPosted: Fri Aug 01, 2008 10:54 am    Post subject: Alternator for NSI EA81 Reply with quote
Suspected that it has a heritage from a Geo Metro of the earlier days. Pretty popular for many homebuilts.
Ask the aeroelectric list.
Paul
At 12:07 PM 8/1/2008, you wrote:
[quote]I've a buddy who needs a replacement alternator in his NSI EA81 powered Kitfox. The data plate is missing from his, and the owners manual says it's a Nippon Denso 38 amp alternator with a built in voltage regulator. Googling for this particular model has not produced any satisfactory results. Any help will be appreciated.
CN
Fox5flyer
PostPosted: Fri Aug 01, 2008 12:18 pm    Post subject: Alternator for NSI EA81 Reply with quote
That is a very ubiquitous alternator, but I believe mine is a 50amp. Try googling the 50amp nippon and see what you get. Also, try a Subaru Brat 84-86 vintage.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 385+ TT
"The aim of an argument or discussion should not be victory, but progress."
- Joseph Joubert
Clem Nichols
PostPosted: Fri Aug 01, 2008 1:52 pm    Post subject: Alternator for NSI EA81 Reply with quote
Thanks for your response. This should at least point him in the right direction. Interestingly, one place in the owners manual says it's a 38 amp unit, and another place a few pages later describes it as a 50 amp unit.
CN
wingsdown(at)verizon.net
PostPosted: Fri Aug 01, 2008 3:22 pm    Post subject: Alternator for NSI EA81 Reply with quote
Have him take it to Kragen or similar auto parts store for a rebuild exchange, and with a life time warranty. Remove the pulley first. Don't tell them its for a plane. Dune buggy works well.
Rick
clint_bazzill(at)hotmail.
PostPosted: Fri Aug 01, 2008 4:41 pm    Post subject: Alternator for NSI EA81 Reply with quote
I have a very small alternator.  The one that is used on the 912 series engines.  It's brand new C contact me off line.
Clint
Date: Fri C 1 Aug 2008 16:18:17 -0700
Subject: RE: Alternator for NSI EA81
Have him take it to Kragen or similar auto parts store for a rebuild exchange C and with a life time warranty. Remove the pulley first. Don't tell them its for a plane. Dune buggy works well.
Rick
PostPosted: Sat Aug 02, 2008 9:19 am    Post subject: Alternator for NSI EA81 Reply with quote
Here are a couple pictures.  Neat alternator.
Clint
Subject: Re: Alternator for NSI EA81
Date: Fri C 1 Aug 2008 16:49:20 -0500
Thanks for your response.  This should at least point him in the right direction.  Interestingly C one place in the owners manual says it's a 38 amp unit C and another place a few pages later describes it as a 50 amp unit.
CN
 Filesize:  76.61 KB
 Viewed:  553 Time(s)
 Filesize:  86.47 KB
 Viewed:  586 Time(s)
Clem Nichols
PostPosted: Sat Aug 02, 2008 10:53 am    Post subject: Alternator for NSI EA81 Reply with quote
Certainly a nice size, no question about that. The most obvious problem I see is that the alternator and water pump on the Subaru are run by two belts which obviously requires a double pulley, and the shaft on your alternator doesn't stick out far enough to accomodate a double pulley. Thanks anyway.
Clem Nichols
