sparrowhawk2(at)mac.com Guest
Posted: Thu Mar 02, 2006 2:25 pm Post subject: Changing the mag switches out for emag and pmag |
Quote: |
> I'm ditching my old Slick mags and going to one Emag and one Pmag. My
> wiring from switches to mags is from the old Z-9 drawing (same mag
> wiring as in
> Z-11). Emagair says that you should switch off power to both the
> emag and the pmag because there is a drain on the battery when they
> are powered up, so direct wiring from the battery bus without a
> switch is out. Both
> ignitions should be ON during start, as opposed to the disabling of
> the right mag during startup now. Is there a way to retain the
> switches I have, including the momentary "start" function on the left
> mag switch rather than replace the switches with 1-3 switches as in
> Z-12?
> Thanks
> Jerry Carter
> RV-8A approaching 500 hrs
