Mike's LED Position lights
william.p.dube(at)noaa.go
PostPosted: Tue Feb 28, 2006 12:34 pm    Post subject: Mike's LED Position lights Reply with quote
Did you compare your measured light output with the FAA required light
output?
You can do a reasonably good job with one-foot piece of string, a
protractor, and a photographic light meter that can read ambient light.
Here is a list of some of the points you should check on the red and
green lights:
+/- Azimuth (off the nose) +/-Elevation CP
0 0 40
0 15 28
0 20 20
0 30 12
0 50 2
20 30 9
25 to 110 30 1.5
Azimuth is the number of degrees off the nose.
Elevation is the number of degrees off the horizon.
The white tail light is even more difficult to get proper light output.
Here are a few points to check on the tail light:
+/- Azimuth (off the tail) +/-Elevation CP
0 to 70 0 20
0 to 70 15 14
0 to 70 20 10
0 to 70 30 6
It takes a LOT of white LEDs to fill the required FAA pattern.
Bill Dube'
mchristian(at)canetics.com wrote:
I used the Nova EPSX - 402 supply for something like $80. It is fully potted for
"extreme" conditions and has two strobe outlets, 3.75 amps draw and 12 diffrerent
selectable flash patterns in a box 4.7" X 4.4" X 1.7" to feed two wingtip
strobes ($18 each). It works great.
For position lights, I used three luxeon stars - one red one green, and you guessed it, one white. They are only $6.00 each. I put them in series with a calculated power resistor and they are so bright it is hard to look at. Total draw for position lights is one amp or less. I thermally bonded them to little thin sheetmetal brackets and mounted them under some Kutzleman clear plastic domes with the strobe heads. Since then, Kutzleman has come out with their streamline combo (www.kestrobes.com) essentially doing the same thing for $94 that I made for less than $40 each.
Total cost of strobe and position light system is less than $180.
Mike
reposting to get subject line to adhere...
mark.steitle(at)austin.ut
PostPosted: Tue Feb 28, 2006 1:06 pm    Post subject: Mike's LED Position lights Reply with quote
Richard,
Thanks for the information (url). Looks pretty simple, until you
actually try it yourself for real!
Thought you would find this post from the Aero-electric list of
interest. Bill Dube makes LED clearance light kits for experimental
a/c. Good info to keep on hand if you're going to build your own LED
lights. The Luxeon lights are much brighter than the regular leds.
See ya,
Mark
Terry Watson
PostPosted: Tue Feb 28, 2006 1:43 pm    Post subject: Mike's LED Position lights Reply with quote
I have the RV wingtip tanks designed for the surface mounted nav lights, so
the option of the enclosed wingtip leading edge lights is not available to
me. Are there any l.e.d. nav/strobe combinations available that meet the FAA
requirements?
Terry
RV-8A
Seattle
sgettings(at)cfl.rr.com
PostPosted: Tue Feb 28, 2006 2:01 pm    Post subject: Mike's LED Position lights Reply with quote
I also used luxeons for position lights (2 high-intensity lambertians on
each side) and presented it to our EAA meeting as well as our local
IA/DAR. The DAR had no problem signing off on the intensity and
distribution of the position lights. I previously provided a link to
the EAA article on this for those who were interested.
Luxeons are really the only practical and affordable LEDS that will meet
the position lighting requirements.
Making strobes using LEDS are another matter, as it is very tough to get
to 400 cp. Even many of the non-aviation strobes and power supplies
won't meet this requirement. There are some options other than
Whelan(=$$$, however.
Scott Gettings
aadamson(at)highrf.com
PostPosted: Tue Feb 28, 2006 2:43 pm    Post subject: Mike's LED Position lights Reply with quote
Might try these guys... I have a set and really like them.
www.gs-air.com
Alan
rtitsworth
PostPosted: Tue Feb 28, 2006 3:28 pm    Post subject: Mike's LED Position lights Reply with quote
Alan,
Do you have the XPAK 604-HR strobe driver listed on their website?
I'd like to put a strobe driver in each wingtip and have a low voltage
synchronizer line between them, rather than 1 central driver and coax (to
minimize noise). The picture of the driver on the website seems to have
several (extra/additional) connectors/pinouts but I can't tell what they do
or if it supports a low voltage synchronizer circuit between multiple
drivers.
Do you know? Beyond the multiple strobe outputs and power/ground, what are
the other connectors for?
Rick Titsworth
Detroit
Terry Watson
PostPosted: Tue Feb 28, 2006 3:57 pm    Post subject: Mike's LED Position lights Reply with quote
Thanks Alan. That's just what I was looking for.
Terry
lhelming(at)sigecom.net
PostPosted: Tue Feb 28, 2006 4:13 pm    Post subject: Mike's LED Position lights Reply with quote
I have the one central control power supply. I do not have any noise. So,
I don't understand you concerns about wanting to minimize it. It is not
there to start with. I wired per the instructions and did nothing special
beyond that.
The extra connectors are for different flashing patterns.
Indiana Larry, RV7 "SunSeeker" 90+ hours flying and XPAK power supply.
"Please use the information and opinions I express with responsibility, and
at your own risk."
PostPosted: Tue Feb 28, 2006 4:48 pm    Post subject: Mike's LED Position lights Reply with quote
I don't have that model, I have a different generation version (actually
still made but only 2 channel). Those other ports are for diagnosis and
flash selection. The manufacturer is www.strobe.com
I got the entire kit from gs-air.com and it included "shielded" hookup wire.
If you want separate PS's all over the place, then the only game in town is
the certified aeroflash units. I'm not sure if they have a discounted
non-certified version or not.
Hope that helps.
Alan
PostPosted: Tue Feb 28, 2006 5:49 pm    Post subject: Mike's LED Position lights Reply with quote
The DAR didn't measure the light output. They very rarely have the
equipment to do so.
If it doesn't bother you to have less light than required by the
FAA, then use whatever position lights will pass muster with your local
DAR. Most folks want position lights that are at least as bright as the
FAA requires, not just bright enough for the DAR to sign them off.
Not so. If you design a light that meets the FAA requirements, you
need quite a few of the Luxeon LEDs. It turns out to be less expensive
to fill the FAA required light pattern with high-brightness 5 mm LEDs.
In lumens per dollar, you are better off with 5 mm LEDs.
You will notice that on the Luxeon spec sheets, they never tell you
the candlepower output. They won't tell you when you call up. You have
to buy one and measure it. They don't tell you because they don't want
you to be able to directly compare the output of their lights with other
LEDs.
The Luxeon LEDs are good if you require a very bright point source,
like for a projector. If it is OK to have the light spread out with more
than one LED, then 5 mm LEDs provide much more light per dollar.
My LED position lights put out more than what the FAA requires in
all directions, and they are less expensive than any other LED position
light on the market (some of which do not put out the light required by
the FAA.)
Bill Dube'
PLaurence(at)the-beach.ne
PostPosted: Tue Feb 28, 2006 7:47 pm    Post subject: Mike's LED Position lights Reply with quote
the FAA.)
Bill Dube'
Bill,
Can will you point me to your web site?
Peter
LloydDR(at)wernerco.com
PostPosted: Tue Feb 28, 2006 8:02 pm    Post subject: Mike's LED Position lights Reply with quote
On their website all of the new version III's and V's all have spec
sheets with Lumen ratings and the appropriate charts to determine
viewing angles, and with more than 80% intensity over 140 degree
spectrum, it would be very easy to get the required fill rate of light
that the FAA requires, and with shaped reflectors, you can even cut off
the angles. Using fog lights from walmart($15) and replacing the halogen
bulbs with 4 Luxeons ($30), plus the power supply ($25) easily meets and
exceeds the requirements for much less money than you would think.
Just my .02
Dan
RV10
PostPosted: Wed Mar 01, 2006 9:05 am    Post subject: Mike's LED Position lights Reply with quote
Gladly!
http://www.killacycle.com/Lights.htm
the FAA.)
Bill Dube'
Bill,
Peter
PostPosted: Wed Mar 01, 2006 9:34 am    Post subject: Mike's LED Position lights Reply with quote
Just my .02
Dan
RV10
The FAA requires specific candlepower in specific directions. (It
only makes sense to do so.)
Lumens don't give you candlepower directly. You can't calculate the
candlepower with the information they provide. Once you buy one, and
measure the candlepower, you realize that you can produce that same
candlepower using several, much less expensive, 5 mm LEDs.
Bill Dube'
